A/C issues
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
A/C issues
I'm having/had a couple issues with the AC in my 92 Trans am and I'm no HVAC pro.
First the AC was blowing very cold and had a very noisy blower fan.
Then the AC started cutting out seemingly working at low loads or idle and the fan got worse.
Now the AC doesn't blow cold except maybe 2% of the time and the blower fan makes noise 99% of the time.
To me it sounds like the system is low on charge and I obviously need a new blower fan.
Is there anything I should check or any other cause of this? It seems I have a pretty bad leak when running the AC since it went from working great to not working in a month or two.
Any advice/help anybody can offer?
I also don't even know if this is the right section, but there's a couple AC threads in here ...
1 Post
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
Re: A/C issues
Really need to throw some gauges on it and see whats going on. It most likely has a leak. I usually start with some soapy water in the squirt bottle and spray it on all the connections. I have seen a lot of them leak at the lines going into the back of the compressor.
