O2 sensors
1 Post
Car: BMW 735
Engine: 383 W/ SUPERAM
Axle/Gears: 3.64
O2 sensors
I'm using a 727 ecm, and the O2 sensor is in the driver's side header. Could I install a 2nd sensor in the passenger side, and switch back and forth to verify how each bank is performing? My ve's at this point look pretty good, but I'm not satisfied with the drivability.
Car: check
Engine: check
Transmission: check
Re: O2 sensors
Yes, you can do that. Just use a high quality switch for the sensor signal. One with gold plated contacts would be best. The reason is that the O2 sensor impedance is on the high side.
RBob.
RBob.
HoosierinWA
10-07-2015 10:15 AM
