data logging with AUP1 AND an LC-2 WB02
Does anyone know if the Innovate LC-2 WB controller can be connected to the APU1 package from Moates where it records A/F ratios directly in the TunerPro program? Im new to this and have not yet started to log but I do have a borrowed APU1 but I also want the ability to see what the A/F ratio is. I plan on using the Innovate 3844 wibeband gauge so I am hoping that Innovate has some sort of package deal where the LC-2 kit can be connected to a gauge when not datalogging
Car: 92 Trans Am Conv
Engine: LB9
Axle/Gears: 3.08
Re: data logging with AUP1 AND an LC-2 WB02
Yes the lc2 can connect to the apu1 directly to datalog with tuner pro.
The lc2 can be connected to the apu1 and the gauge at the same time.
Thanks. I will be trying to get the APU1 hooked up tonight and communicating with my ECM. It didnt go so well last night. Its used and I'm borrowing it so I have no instructions except for what I can find online. I dont need or want to burn right now. I just want to log.
