Wiring a transducer with EBL
Old 01-14-2017, 07:56 PM
Steve Quinn's Avatar
Car: 1990 Camaro IROCZ
Axle/Gears: 3.45
I'm going to be using an AEM 30-2130-100 100 psi transducer, just want to be sure I'm wiring it right. I'm going to tap 5v power from the tps, run a wire from the tps to the transducer power. Then use one of the EBL ecm's ADC channel Input and one of the grounds on the same bar. Sound right?
Old 01-15-2017, 08:59 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Wiring a transducer with EBL
With the EBL P4 there isn't a ground on the ADC terminal strip. Use the TPS wiring for both the +5 volts and the ground for the sensor.
RBob.
Old 01-15-2017, 09:47 AM
Axle/Gears: 3.45
