MSD 6AL
Old 07-02-2007, 06:37 PM
88L035speed's Avatar
Car: 1988 Camaro Coupe
Engine: 305 5.0 L03 TBI
Transmission: T5 - 5 speed
Axle/Gears: open diff. & stock 3.08 gears
MSD 6AL
Im tempted to buy the MSD 6AL but my father thinks that becuase i allready have realy good throttle response from my L03 TBI that it wont effect it much and its not worth the money and that if i do see a diffrence that it wont be big at all, says ill barley knotice i have it. Is this true or will i have a big diffrence and does MSD give more hp? or just throttle response? or bolth, i just would like to have info on it befor i spend $200. thanks
Old 07-02-2007, 10:34 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: MSD 6AL
You wont need it on a stock TBI engine. We tested one on a 330 RWHP tuned port engine, and it made a 2 horsepower difference at peak power only. Your money is better spent elsewhere at this point.
They work great for nitrous/blower cars, or engines that are making power above 6000 rpms.
Edit: This thread will help you:
https://www.thirdgen.org/forums/tpi/...sd-6a-6al.html
Old 07-03-2007, 02:26 AM
Re: MSD 6AL
ok that helps alot, thanks for replying
Old 07-03-2007, 12:10 PM
netfreak's Avatar
Car: 88 firebird
Engine: 305 TBI
Re: MSD 6AL
Agreed. I only put my MSD ignition on because I already owned it from a previous vehicle and I'd rather not have it sitting on a shelf doing nothing. I'm running a mostly stock L03 TBI right now.
Old 07-03-2007, 04:00 PM
Re: MSD 6AL
thats another reason i wanted it, is that becuse i can just put it in any car i get after mine.
Fanatic1074
10-03-2022 05:57 AM
Hotrodboba400
12-10-2019 07:07 PM
RedLeader289
05-28-2019 01:47 PM
meeklay812
10-01-2015 03:46 PM
Hotrodboba400
09-02-2015 07:28 PM
Quick Reply: MSD 6AL
