how to disable VATS???
#51
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: how to disable VATS???
All this resistor nonsense.....
Behind your drivers side kick panel there is relay with 4 wires going to it. I Un mounted the relay, pulled the black plastic cover off of the top of the relay to expose the contacts. Now here I simply wrapped the lever with electrical tape so that it is always in contact with it's contact point. This will give the signal to your computer that says you have the correct key inserted and your car will crank everytime. Hope this helps!
-Sean
-Sean
That relay is called the Starter Enable Relay and is controlled by the Pass-Key decoder module, it does not control the ECM or anything. If you only had a problem with this relay and not the whole Anti-Theft system, then taping this relay closed helped solve your issue. But it wouldn't work for any general VATS problem, specifically missing keys, bad ignition cylinder key contacts, broken key wires or bad Pass-Key decoder module. Your fix only addresses a bad SER, no other VATS issues.
Hope this clears it up.
Lou
#52
Car: 91 Camaro RS
Engine: empty bay (for now)
Transmission: Built T-56
Axle/Gears: 3.42 stock posi disc
Ive lost count at the number of threads were Ive explained the VATS system, but here it is again...
The VATS system works like this. There is a VATS module that is programmed to activate when it reads a correct resistance load on the circuit. This resistance load is created by the chip in your key. When you put the key in the ignition, each side of the "chip" in it makes contact with electrical contacts in the ignition cylinder. THis completes an electrical circuit and current flows though the "chip," and arrives at the VATS module with whatever amount of resistance the key gave it (with a little more from the actual wiring). If the VATS module doesnt interpret this as a correct value, it does nothing. If it does interpret the resistance value being correct and within the tolerance range, it activates. When it activates, it does 2 things. It grounds the start enable relay under the driver side kick panel, allowing current to pass to the starter and spin the motor. It also sends a signal to the ECM that tells the ECM the correct key is inserted and its ok for the injectors to fire. Without BOTH of those happening, your car doesn't run.
The person who just taped the relay together, you most likely have a faulty start enable relay, or your VATS module is malfunctioning or has already been bypassed.
The easiest way to bypass the start enable relay is to ground it permanently and leave it in place. Or you can rewire the starter solenoid wire to not include that relay if the relay is bad or you just want to get rid of it.
#53
1 Post
Car: projects.......
Is there a simple way to "trick" the ECM by sending signal to it? Pos or neg and would it need resistance?
I've got an '87 gta that we put the original harness & ECU from my '89 in. Was planning to have the chip re-flashed to eliminate the VATS, but haven't had much luck getting that done for what I would consider a reasonable price(have been quoted $100+). Also, not really wanting to mess with carrying the '89 column and all the VATS related stuff over either.
#54
1 Post
Car: 1989 IROC-Z28 Camaro
Engine: 403 LSX
Transmission: TH400
Axle/Gears: Moser 9" 3.25's
#55
Engine: TPI
It is easier to burn a chip. Sending you a PM.
Lou
#56
1 Post
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
i recieved last week the vats bypass module from hawksthirdgenparts.com it looks like it was worth the $60
#58
I am about to install a 1991 Firebird TBI engine in a '56 Chevy. I have the engine harness from the donor car and have already cut out the unnecessary wires. I also have a computer from a 1992 Camaro. I'll be using the stock '56 ignition switch to crank the engine but heard from others that it won't fire due to the VATS. I only need the engine to fire, so I'm not concerned with the security. What needs to be done to trick the ECM to thinking it's still in that 1992 Camaro? Will the resistor trick work in my situation? Do I need to get the VATS module from the donor car?
#59
Car: 91 Camaro RS
Unless you get the VATS module from the 91 or 92 donor car, then youll have to either get the ECM chip burned to remove VATS or buy a VATS bypass module. If you do get the VATS module then the resistor trick should work. Youll need the module from whatever cat you got the computer from btw. The VATS module is nearly impossible to get to without tearing the dash completely apart, and the bypass module is like $50. Id suggest just buying the bypass module.
#61
1 Post
yeah i bought the vats bypass from hawksthirdgenparts.com its simple with the help of some of these friendly and smart fellow thirdgen owners
#62
Car: 1 day...a 1990 Rs...
Engine: 3.1 Lt V-6
Transmission: auto
Axle/Gears: yes
#63
I just bought the Hawks bypass for my wifes alero today, but look at this!http://www.gmupfitter.com/publicat/bull/bull26.pdf On the alero the 3 small wires are on top of the ignition switch,I have read that the car should be running when you cut the thin yellow wire to splice in the toggle switch, that way the system is in fail/operate mode and will remain that way. The toggle is insurance that if your battery goes dead or needs to be replaced or disconnected, you can turn on the system to get started again and then turn it off again-----This whole system is a POS!!!!
#64
Car: 91 Camaro RS
"Start the engine with the ignition key (modification switch must be in the OFF
position). Turn modification switch to the ON position (contacts open). The
Security Telltale will light up indicating that the Passlock System is inoperative.
Once the security telltale has been on for at least 5 seconds the vehicle can be
turned off and then remotely started."
The above was quoted directly from your link....this only works if the VATS system is FULLY FUNCTIONAL to begin with. You have to start the car with the correct key then flip the "bypass" switch then kill the car for it to work. This isnt ment to bypass broken systems, its ment to install a remote start like most modern car alarms have provisions for. And its specific to certain 98-06 GM trucks, not your wife's alero or any thirdgen.
#65
Hi y'all ! I bought a 88 Firebird Trans-Am as of a week ago today. Please keep in my mind that this is the first car I've ever owned that was over 10 years old. And I can't start the car and I suspect it's the VATS system fault but I've also been told that they only put those on the 89's and later. Is that true? Could I have gotten a newer Anti theft system and will need to disable the VATS? If so what is the easiest way to do so? I'm only 18 and eventhough I'm handy with a ratchet I'm no where near a prodigy. Could I just get it done professionally?
#66
Car: 89 Formula L98 power
Engine: '96 subaru, opposed 4banger
Transmission: TH700R4, subaru 4WD
Axle/Gears: 3.27, just works
My system is also screwing up. It lets the starter work, but doesn't ground the fuel injectors or fuel pump to prime and run. I saw on my gauge the injectors were primed, and they weren't firing, the exhaust didn't smell like gas. No fuel. I can't by pass that yet to work, thats a more complicated fix at an unltra foods, lol. I'm wondering does that vats module see a problem where then? I read that lead with my meter in my car, it shows my amount & still no fuel action, lol. But 15 times on off ignition resets it? I've never heard that, I just put 10K on my car, and 132+ and it just screwed up last night, lol. I'm all ears
#67
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
And your 88 should not have it.
#68
Car: 91 Camaro RS
Unless your starter enable relay has been bypassed (grounded) then its not a VATS issue. The module grounds the start enable relay and sends the signal to the ECM. If the VATS module grounds the relay, then its functioning. There could be a break in the wire from the VATS module to the ECM or something like that. Or a faulty ECM or prom. Biggest indicator of the VATS malfunctioning is the SECURITY light staying lit when you turn the key. If it lights up then goes off, VATS is fine.
#69
wheres the starter enable relay? I've never heard of that before, my starters working, but the fuel side isn't coming in, which is also part of the vats system as stated on all data
Here's all data:
CIRCUIT OPERATION
The brain of the PASSkey(R) system is a special decoder module that reads the pellet resistance through the lock cylinder contacts. It then compares this key code with its own internal code.
If the codes match, the decoder supplies a ground for the starter enable relay and modulates a 5 volt reference signal (at 2.5 volts) from the ECM or PCM which will then pulse the fuel injectors.
If the codes do not match, the decoder module sets its internal timer which locks out starter operation and fuel enable for up to three minutes.
Here's all data:
CIRCUIT OPERATION
#70
Car: 91 Camaro RS
The start enable relay is located under the kick panel on the driverside, sorta under the hood release latch. Most likely under a black square of goo. If your starter turns it sounds like the VATS module is getting the correct resistance from the key and sending the signal, its just not making it to the ECM, or the ECM isnt functioning correctly. Does the SECURITY light on your dash stay lit when you turn the key to the ON position?
#71
no security light on, crank, no fuel injector relay or pulsing. I primed the pump, and its at like 40psi for 2 dasy now. VATS won't energize the fuel circuit as part of its safety, so its something funny, ed wright mentioned I should remove the vats alarm module all together, so I'll try that soon today, i'll keep you posted...son bich lol
#72
Car: 91 Camaro RS
THe vats module is next to impossible to get to without tearing most of the dash apart. In youre case its either an ECM issue, or a wiring issue. It sounds like your VATS works fine, just that the signal isnt getting to the ECM or the ECM isnt functioning correctly.
#73
Yeah I've pulled quite a few things a part, after disconnecting the module and reconnecting it, I have no power for the computer either, no ses light, so it means its not firing up. So now I'm on that journey, lol
#74
I just found a TSB that there are a lot of electrical connectors, it looks like this now, explaining my problem:
TECHNICAL
Bulletin No.: 09-06-03-004D
Date: December 08, 2010
Subject: Intermittent No Crank/No Start, No Module Communication, MIL, Warning Lights, Vehicle Messages or DTCs Set by Various Control Modules - Diagnosing and Repairing Fretting Corrosion (Disconnect Affected Connector and Apply Dielectric Lubricant)
Models:
2011 and Prior GM Passenger Cars and Trucks
Attention:
This repair can be applied to ANY electrical connection including, but not limited to: lighting, body electrical, in-line connections, powertrain control sensors, etc. DO NOT over apply lubricant to the point where it prevents the full engagement of sealed connectors. A light coating on the terminal surfaces is sufficient to correct the condition.
Supercede:
This bulletin is being revised to update the Attention statement and add the 2011 model year. Please discard Corporate Bulletin Number 09-06-03-004C (Section 06 - Engine/Propulsion System).
Condition
Some customers may comment on any of the following conditions:
- An intermittent no crank/no start
- Intermittent malfunction indicator lamp (MIL) illumination
- Intermittent service lamp illumination
- Intermittent service message(s) being displayed
The technician may determine that he is unable to duplicate the intermittent condition.
TECHNICAL
Models:
Attention:
Supercede:
Condition
#75
Car: 91 Camaro RS
Thats just a general bullitin to put an electrical conducting grease one any electrical connector having intermittent problems.
#76
WELL that was actually written up as a TSB on ALLDATA but I checked the one right near the brake booster, it was fine, theres a tar like substance in there from the factory. I also fixed one terminal by the battery, I got it apart, barely and it was broken inside, usually they're not glued together, but this one was. So I fixed that. At then end I pull the fuse panel down, and the ecm dual wires that usually go to the ECM fuse, were broken, I reconnected, got fuel pressure and she started right up. I knew there couldn't have been some other issue, which is why it was baffling me, lol. I had my whole dash apart to find the problem. At least now I know its fine, mileage happens and mine does have 132,000+ on it now. The copper link from wires to the back of the fuse was just broken free and laying there, hence why it just stopped in traffic, but its all better now
#77
Car: 1989 Camaro RS
Engine: V6 2.8l
Transmission: Automatic
my wire is 2 yellow wires wrapped in black. i did the resistor fix but still doesnt start it.. still has no power to the starter and fuel pump at least thats what the "mechanic" said.. any advice as where to look next? or what it could be.. HELP please
#78
Car: 91 Camaro RS
thats not the coorect wires to start with...it should be a white and black wire, wrapped in an orange case. usually wires wrapped in a yellow case are for the SIR.
#79
1 Post
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
Tell me if this is VATS:
New motor, all new ignition etc.
Cranks but injectors don't spray, turn ignition on and the ses light stays on. I plan on trying the resistor fix in a couple of days and I really hope it's that.
#80
Car: 91 Camaro RS
the cranking and SES light staying on says it could be vats, but more likely something else. what does the security light do?
#81
1 Post
The security light? Damnit I never knew these cars had that? I'm pretty sure it's not coming on... I don't think i've seen it ever come on my digital dash.. I'll have to check tmrw, so it's not the service engine light that when you turn the igniton "on" it should come on briefly then in a few seconds go away?
#82
Car: 91 Camaro RS
yea, theres a ligh on the dash that says "security" it should light up a few seconds then shut off. if it stays lit theres a problem with VATs, or its the wrong key or something alone those lines. if it doesnt have a security light on the dash then youre car may not have a VATS system at all. I dont remember what year they started putting them in, but it was sometime in the mid 80s
#83
Car: 1984 Camaro Z28
i have done it in my brothers 94 bird same procedure you going to want to remove the kick panel under the steering coloum grab a multimeter and find the leads heading up to the ignition you going to want to hook up the multimeter to those wires turn the ignition over with the key the multimeter will give the right resistor reading write down that value head to your nearest radioshack and buy the resistor that the multimeter read out and hook it up to the leads thats how you bypass it which is basically the same as disabling it.
#84
Car: 91 Camaro RS
the resistor trick is only used to bypass a problem with either the key "chip" or the ignition cylinder contacts/wires. if youre getting the correct resistance values on the wires comming from the column, then adding the resistor is pointless since it only mimics the resistor in the key that is either not there, or not contacting right.
this doesnt solve an issue with the VATS module itself. if the VATS moude is bad it has to be either replaced or bypassed with a VATS bypass module (the ones on hawks and other various sites).
#85
1 Post
You just solder your resistors in a series, then stick them in the back of the plug in? Do you unplug it or leave it plugged in?
#86
Car: 1990 Firebird Formula
Engine: LB9 - 5.0 TPI
Axle/Gears: 2.73, LSD
You tell me. Do it in series and tell me what happens please. I've seen a picture a million times of a resistor in parallel and I don't see how that would work.
#87
Car: 91 Camaro RS
you shouldnt need more than one resistor. as long as you get one within the tolerance range of the VATS. if you need more than one you can run them in series (its how i had mine before i got rid of the computer completely). you unplug the column wires and attach the resistors in its place.
again, this doesnt fix a VATS module problem, it only bypass the key/ignition contacts part of the VATS system.
#88
in a way i don't see what the point of vats does sure it makes it hard for the car to be "jacked" but its pointless an alarm system should do the trick better
#89
Car: 91 Camaro RS
its a factory installed theft deterant, not a "theft proof system" the only way to get a VATS equipt car to start without the correct key is to either provide the resistance in the circuit or supply the correct pulse wave signal to the ECM. what theif do you know carries a resistors or a bypass module with them to steal a car?
#91
Car: 95 hyundai 30 mpg no matter what
#92
Engine: TPI
The signal from the PassKey module to the ECM is a specially modulated waveform that cannot be easily bypassed with a screwdriver or a paperclip. Though it can be still bypassed with the right module and adequate training. So as it has been pointed out numerous times before, VATS does not make the car unstealable but it makes it harder to drive away in for a regular thief.
If somebody wants to steal your car, they will. Even if you put chains through the wheels and weld the steering shut. Flatbed, anybody?
#93
Well actually I'm not looking to steal anything. I'm looking to make the L98 tune port engine run in a swap. I have the PASSKEY module and all (yes all) of the wiring harness,engine to gas tank. (gas tank too) So I will either get one of those by.pass deals or the resistors for the lead to the ignition tumbler.
#94
Car: 91 Camaro RS
resistors are cheap and easily replaced. the bypass box is expensive, but good for someone who doesnt know how to use a multimeter. You can always have the ECM tuned to delete the VATS part too.
#95
Well in my car, it wasn't anything to do with the VATS when these cars came out in the 80's they were the most commonly stolen vehicle in america, they didn't use resistors because they were cheap, your wrong on that one. Mine broke because the ECM 10 amp fuse holder, made of copper snapped in half at 134K and since 1989 in 2011. I'm likely going carb soon, my motots gonna be over 600hp on motor, so **** fuel injection, too much money to tune, let alone changing all the wiring and ****, and spend money on dyno tunes, f that!
#96
Car: 91 Camaro RS
Old way of thinking right there. It costs you virtually nothing to tune an EFI system other than your time. You just have to invest the time into learning to do it right, just like tuning a carb. It takes a simple laptop and cable and FREE software. Or you can get an aftermarket system that TUNES ITSELF. I run a carb for 1 simple fact, its cheaper. I dont have $1500 for a complete fuel injection set up so I have a free carb with a $30 rebuild kit sitting on top of the engine.
#97
I have known how to change timing, tps and fuel pressure for years, thats not always "tuning" I meant the knowledge the computer has about the engine. Ed Wright closed his business now, no more dyno, and I'm just gonna run a carb!
#98
Car: 1989 GTA 8,000 original miles
Engine: V8 350
-Sean
-Sean
I checked behind my kick panel and this is what i find. Am I missing something or should I be seeing a relay? BTW, I had to break open the black insulation for the first time to look behind it. Does anyone have an actual picture of the starter relay?
neither one of these can be the starter relay is it? If not, what are they?
#99
Car: 1992 Z28
Engine: 5.0L....for now.
Transmission: Auto.....for now....
Axle/Gears: Yep, they're in there.......
My 92 Z28 looks exactly like your T/A wheel well featuring the same lack of the starter relay. So, if someone can enlighten me as well I would greatly appreciate it.
#100
Engine: V8 350
