no wipers
no wipers
Hey guys, new member here. Recently purchased an 89 RS for my two teenage sons. Ive been upgrading and improving all safety components ie, steering, suspension, etc. Currently trying to get the wipers working. I have no response from wipers or washer pump. I have used a test light at the connection under the column and DO have 12v at the white wire, but have no corresponding voltage at any of the other wires when activating the switch at the column. Not sure if that is the best way to diagnose whether i have a bad switch or not. Any help would be appreciated. I have tilt, non delay...of course no one has that switch available. So, if this is my problem, what are my issues of using a tilt, w delay switch as my replacement? If it just means i would have working wipers w no actual delay, I'm fine with that...lol Just need working wipers!
Re: no wipers
Now , as to whether or not a delay VS no delay switch will work interchangeably , I honestly don't know and wouldn't want to steer ya wrong with an "I think" .
PS , when you change the switch , don't forget to tie a good sturdy piece of string to the switch's wires before you pull the wires and switch up and out of the steering column . Without this string in place you would have no means of pulling the new switch's wires down through the very narrow place the wires need to run , and much swearing will result
Best of luck with it
1Aauto
Sponsored Vendors
09-23-2015 01:09 PM
1Aauto
Sponsored Vendors
09-23-2015 01:00 PM
