Tune up / Overhaul
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Tune up / Overhaul
So I decided the car needed a tune up / overhaul . Here's what has been done . Most of this is SMOG related.
Oil = Mobil 1 Extended Performance Synthetic
Filter = Mobil 1 Extended Performance Oil Filter
EGR Valve
EGR Sensor
Coolant Temperature Sensor
O2 Sensor
New Canister Purge Valve and hoses
Plugs = NGK G-Power Platinum's
Wires = Summit Racing Street Strip Spiro wound 8mm
MSD Cap and Rotor
Check Timing
Reset IACV
Reset Minimum Idle speed.
That's about it.
Its been a busy week but its done.
If it still does not pass SMOG I have to buy a new CA approved Magnaflow CAT and have it installed = $$$
I just wanted to add that this is the first time my car has ever failed SMOG.
EGR Valve
EGR Sensor
O2 Sensor
MSD Cap and Rotor
Check Timing
Reset IACV
That's about it.
