headlight
Old 02-16-2017, 07:58 PM
powder white's Avatar
Car: 82 Z28
Engine: 350 LT1
headlight
will the headlight harness from a 89 iroc fit 82 camaro z28
Old 02-16-2017, 08:31 PM
jharrison5's Avatar
Car: '87 IROC
Transmission: WC T-5
Axle/Gears: 3.45 Posi
Re: headlight
It should. Don't really think they changed much during the run. Only issue I see is putting in one that had fog lights on a car that didnt have them.
Old 02-16-2017, 08:40 PM
Car: 82 Z28
Engine: 350 LT1
Re: headlight
thank you very much
how hard is it to install it to the fire wall plug
Old 02-16-2017, 09:30 PM
jharrison5's Avatar
Car: '87 IROC
Re: headlight
Originally Posted by powder white
thank you very much
There is a single 1/4" bolt in the center of the C100 plug that you unscrew and then the harness can be split to get the headlight portion off.
It's sort of a pain to get to but it's not difficult.
Old 02-17-2017, 11:23 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: headlight
I think you ought to do a bit more research before plugging any "non native" (exact year & model) harness into your car and here's why ; Many has been the time that I have read here of folks needing to "Repin" their different year harnesses that they want to use because the configuration of which pin of the C100 connector does which job DID change over the years and you could run into troubles if any of those changes do involve the headlights . I will tell you that I mostly recall it being engine differences (TBI vs TPI for example) that involved needing to be repined but I also have seen differences in the lighting circuits across the various years & models of our thirdgens that would make me want to check pin for pin that it's truly identical before plugging it in .
GOFASTER
09-21-2000 12:08 AM
Quick Reply: headlight
