[NC] Wrecked 1989 Formula 305 TBI Part Out
#51
Car: 1990 Formula Firebird
Engine: 305TBI w/ Functional Sport Hood CAI
Axle/Gears: SLP Posi and 3.23 Gears
Re: Wrecked 1989 Formula 305 TBI Part Out
bump,
I am getting into some serious removal of parts removing the serpentine assembly for a buyer, so now is a great time for anyone that needs anything from a washer fluid jug to a replacement computer.
Thanks Guys.
Thanks Guys.
#52
just removed the headliner and rear seat belts unbolted are laying out and ready to be sold.
this is also a good time for anyone that is looking for T-Top related parts.
#53
bump, finished up most orders and updated the sold list, so ready for any new requests.
#55
Yep I have them for sale, but I am trying to keep the car as a rolling chassis until I pull the motor.
#56
I pulled the 700R4 shifter cable + cable bracket, but the customer found it locally.
If anyone needs it here it is:
I'm asking $25 + SH
I'm asking $25 + SH
#58
I'll have to check
#59
nope, sorry it is not powered
#61
Replied
#62
Pulled Parts:
Complete Steering Column with zero damage (no cracks) $150 + SH
E-Brake Lever: $30 + SH
700R4 Shifter Lever (no ****, sold): $50 + SH
Windshield Wiper Motor: $40 + SH
(some hardware is not in pictures and left on car as not to lose any bolts, for example the steering column mount bracket)
Pics: (see all here: http://ws6zep89.picturepush.com/albu...mer-%2713.html)
#64
I do have the complete tbi and it is in good shape, however right now I can not sell it. When I am able to I will contact you through PM if you are still interested. I ported my original TBI + added an injector riser and until I verify everything is good to go, I need a backup just in case.
#67
Two things on headliner, it has some damage from rats getting into the car before it was sealed off properly and the shipping from my home (NC) to Kentucky was going to be $85 and change.
here is the condition of the headliner that I am referring to, only the one side matters where they ate a hole through, the other isn't visible when installed. The entire thing needs to be reupholstered, but that is pretty much the case with every pulled headliner. I figure a local pickup will end up with the headliner, I am only looking for $40-$50 for it + the SH fee. However that totals about $130 even with me using the cheapest carrier (I've tried all of them and it's FedEx) with a custom made box cut down to size. Oh and I found the missing front clip that isn't in the pictures, in the pictures you only see one of the front clips. Also where the seat belts go through is where the most common damage is when removing a headliner, but that part is pretty much perfect and definitely solid.
Here is what it looks like:
(see damage on both sides towards the front at seat belt holes? with the important damage to the left in the 1st picture?)
(close up of worst side where they ate through)
Find all pics here in full size: http://ws6zep89.picturepush.com/albu...Jan-%2713.html
There are two options on dealing with these holes.
A) I fix it with a mix of the right glue and fiberglass, let it dry and sand it to the right contour.
B) I leave it alone and you just cover over it with the small hole there or you fix it yourself.
Obviously I am not asking much for it because of this damage from a mouse, but the shipping still makes it an expensive item..
#69
I would just charge the materials to fix it, so just say $55 repaired.
I'll PM you a shipping quote.
#70
btw so there was no confusion, the $55 was the total cost of the headliner without the SH included. Not $55 to fix it
#71
Car: '84 Z28
Engine: '02 LS1
Transmission: '02 T56
Axle/Gears: LS1 10-bolt 3.73 w/Auburn Pro
I am looking for a wiper motor if you can confirm that it was a delay type motor and all functions worked properly before being removed. If so, I can make an offer on it. Let me know. Thanks.
#72
Yep it is a delay motor and it did work 100% before pulling. I'm only looking for $40 + SH
#74
Posi rearend? If so what ratio? Thanks!
http://feedback.ebay.com/ws/eBayISAP...ab=AllFeedback
Sold Parts:
Radio Pod
Cat Converter
Complete Headliner
Headlight Module
Dome Light Housing
T-Top Center Bar
Complete Tail Light Assembly w/ Center Trim
Passenger Side Performance Suspension Trim Panel
Both Headlight Motors
Brake Pedal/Pedal Arm (rest of assembly still available)
All Side Moldings
Hatch Motor
Power Mirrors w/ Switch and Harness
Third Brake Light
Torque Converter Cover
Shift ****
Both Door Panels (bare)
Gauge Cluster
Dash Pad
Hatch Struts
Gauge Cluster Trim
Both Sun Visors
Rear View Mirror
Lower Front Interior HVAC Piece
HVAC Interior Control Panel Hoses
Complete Serpentine Assembly (except A/C Compressor)
Headliner
Radio Harness
Hello Third Gen gurus, my name is Keith and I have been apart of these forums for a long time and you guys have really helped me out of jams while restoring my 1990 Formula 305 after this wreck in 2002. Since then I have done small swapping like fuel tanks and some interior. Now I am going to part out the car piece by piece. I am a member of GMMOC and have purchased very cool parts off here, like the air induction box and lid for the power bulge hood.
Here is the 1989 Formula, the black paint on it was brand new when I purchased it and was done by a local talented painter.
I smacked a pine tree going about 30MPH due to ice and that is what was done after removing everything. Anything except the block + internal components and transmission is for sale.
The car has been kept under tarps and always in this dog house covering 90% of the car from the elements, especially rain.
You can see some of the very nice parts at the rear of the car
Thanks for looking and you can contact me at krhallman@gmail.com
Remember, everything except the block + internal engine parts and transmission is for sale, although I have a spare 700R4 tranny for sale
Edit*
I wanted to mention I also sale a lot of computer hardware and I have a Heatware account you can read on things I've sold there worth hundreds, but I just recently started that after moving computer hardware forums:
http://www.heatware.com/eval.php?id=66800
Sold Parts:
Radio Pod
Cat Converter
Complete Headliner
Headlight Module
Dome Light Housing
T-Top Center Bar
All Side Moldings
Hatch Motor
Third Brake Light
Shift ****
Gauge Cluster
Dash Pad
Hatch Struts
Gauge Cluster Trim
Both Sun Visors
Rear View Mirror
Headliner
Radio Harness
Edit*
#75
nah it's a 2.73 Open, I had the 3.23 SLP Posi put together for my other car that actually drives
#76
Recently Sold Parts:
Complete Seat Belt Setup
Seat Guide Trim Covers
T-Top Center Bar
Dome Light Housing
All of those are gone, but still plenty of parts left. If it's not in the list in the OP on the 1st page then I probably have it.
T-Top Center Bar
Dome Light Housing
#77
I also wanted to mention I still have plenty of plastic trim pieces, almost of all which can be seen in this picture:
PM or post here for prices on specific items and I updated the OP with pulled parts list.
#78
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I am looking for the 2 rubber fuel hoses in the engine bay, that connect to the throttle body steel fuel lines. The 2 right under the windshield washer bottle. Do you have those? Mine have rusty connecters, so I am looking for a pair of non-rusty hoses.
#79
I'll have to check, I know what hoses you are referring to, but I need to check on them to make sure they weren't damaged. I pulled the TBI off that car, so let me check tomorrow when I do some other work for buyers.
#80
I've got those two hoses off, one hose on one end has some surface rust, the other 3 ends do not. PM me for photos and price.
#81
I have two parts that fall in between Interior and Engine/Drivetrain:
For All Pictures/Full Size Go Here: http://ws6zep89.picturepush.com/albu...mer-%2713.html
(I have all hardware/accessories that go with these two parts, also including the full shroud for the evap, blower and blower motor)
#82
bump
#83
bump
#84
Pulled Parts prices dropped, some by over 30% (in the OP)
#85
Starting a 3rd Shift job on Sunday, so bump while I still have lots of free time!
#86
1 Post
Car: 1991 Camaro Z28
Transmission: 5 speed
Axle/Gears: alunimum drum limited slip 3.08
Would you have the battery cables? I have a camaro and want to move the battery to the other side like the firebirds.
#87
Yep, I definitely have the battery cables. PM me.
#89
Car: 84 TA Black/ Gold
Engine: 383 With Vortec Heads
Transmission: 700 R4 Lvl2 Performabuilt 9.5 Vert
Axle/Gears: Moser 9" with 3.70
pm and email sent Thanks
#90
I am still selling these items, however I am now working 60+ hours a week for Lowes HQ's IT Dept now. So I am still doing sales, just expect a little longer of a wait than if you bought from me in the past.
Thanks!
Keith
Thanks!
Keith
#92
The engine harness is complete except the wire going to the alternator. The person who bought it requested it in order to buy the complete serpentine assembly. However that is a very common wire to replace, so you can find them separate all over the 3rd Gen websites, or really any GM site.
PM if you are interested.
#94
PS Pump is sold (check OP for sold parts)
my 28 splines are in my SLP Posi for my driving Firebird.
#95
Car: '91 Trans Am GTA / '83 Camaro
Engine: 383 SBC / 430 Buick BB
Transmission: Tremec TR-3550 / TH-400
Axle/Gears: Stock 10-bolt, 3.42 /10-bolt
Are the A/C hoses/tubes left?
Is the dash pad left?
Thanks!
Thanks!
#96
Some of them were removed, you'll have to be more specific.
#97
actually thinking back, they were all sold.
#98
I was looking for all of them actually - everything between the evaporator - compressor - condenser. I need the whole routing. The previous owner deleted the under-hood AC parts on my car and threw everything away. I was hoping to pick up at least the hoses to save some money.
#99
Well I have everything except these hoses which are already sold:
Let me know if you want to buy everything else I have left. I have the entire A/C system like the evap radiator/housing/etc and blower motor. Basically the entire A/C system is still there from the A/C compressor and accumulator all the way to evap radiator shown above.
Keith
Keith
