[WI] 3rd Gen Parts
#58
Car: 1992 Firebird
Engine: LH0 3.1L V6
Transmission: Automatic 4 Speed w/Overdrive
Re: 3rd Gen Parts
On the drivers side top bolt for the fan on my 1992 Firebird 3.1L the metal bracket that holds the small metal hoses (not the radiator hoses) is broken. I'm looking for a replacement. Do you have one?
#59
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Re: 3rd Gen Parts
I am looking for the spark plug wire heat shields that go below the exhaust manifolds. The only one I have is the rearmost one on the drivers side. I need the rest of them.
#70
Car: 89 Formula 350 Original Owner
Engine: 5.7
Re: 3rd Gen Parts
How about... (1989 Firebird Formula 350)
1) A original set of torx head bolts for the intake runners.
2) All the original spark plug wire looms.
3) Original heat shield on drivers side exhaust manifold.
4) Original throttle loom located on the drivers side stud on top of the intake runner.
5) Original connector for the coolant fan switch located on bottom of the passenger side head above the starter.
#75
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Re: 3rd Gen Parts
I feel like I posted on here before but I didn't see it...
I will just start listing stuff and it will all be shipped to 85022. I will probably be more interested in the cheaper items.
Everything is for an 87 Iroc, but some things obviously are universal.
If you have a pair of front seats from an 87 Iroc I am interested but shipping might persuade me otherwise. Depends on price. The seat design has the cross hatch marks going on a diagnol.
TPI intake tube. The C shaped plastic piece and the hardware associated with it.
Iroc wheels.
ttop headliner in good condition.
manual shift plate for camaro.
grid tailights.
hood louvers.
rear window louvers.
rear sway bar that isn't rusty. I am not sure what size the rear sway bar is on the 87 irocs but mine is a disc posi rear, not sure yet what gear ratio. My 88 base camaro has a 19mm but I don't know if they used a bigger one on the iroc or not.
That's all I can think of for now.
Iroc wheels.
grid tailights.
hood louvers.
#78
#80
Moderator/TGO Supporter
1 Post
Car: 87 IROC 92 Z-28 91 Ragtop
Engine: 5.7
Transmission: 700-r4
Re: 3rd Gen Parts
The 5.7 TPI engine in my 87 IROC will be replaced with a new one soon and I need the AIR pump, hoses and various emissions parts that seem to be missing for some reason. Any help would be appreciated.
#81
Car: 1984 F41 Camaro
Engine: LC1 V6 2.8L
Transmission: 4 Speed Auto
Re: 3rd Gen Parts
If anybody is looking to buy a set of rear window louvers, let me know, comes with mounting hardware and are in perfect condition, willing to ship,asking 250 obo with shipping, pm me for more info or to make an offer
#84
Car: 1991 Camaro RS
Engine: 5.8l Aluminum LSX
Axle/Gears: 10 Bolt 3.42 "Spooled"
Re: 3rd Gen Parts
I need a series 2 open carrier for a 10 bolt?
28 spline*
28 spline*
#87
Car: 1988 Iroc T-top
Engine: 350 w/typical bolt-ons
Transmission: 5 speed
Axle/Gears: 3.42 zexel, TEN chromoly 28 splines
Re: 3rd Gen Parts
What about the headers? Condition? Pictures?
#95
Engine: 350-TPI
Transmission: 700-R4
Axle/Gears: 3.27 Posi
Re: 3rd Gen Parts
I have a 1989 GTA I'm looking for the following:
1. Tail light center filler as per pic:
2. Gas tank heat shields
Let me know. Thanks.
#97
Engine: 350-TPI
#100
Car: '91 Chevy Camaro RS
Engine: 3.1L LHO V6
Transmission: Borg Warner T5
Axle/Gears: GU6 3.42 Open Diff
