Parting out 1992 z28 tpi 5 speed car
#52
Car: 2002 Camaro SS
Engine: Built LS
Re: Parting out 1992 z28 tpi 5 speed car
I'm looking for positive battery cable in good shape. Want to make sure the nut that connects to the battery isn't stripped at all.
Here is what I need.
#53
Did you sell the rear end yet? If not is it disk and posi and what is the gear ratio....My email is tchome@suddenlink.net
#54
Car: 85 IROC / 92 Z28 Vert / 57 210
Engine: L69 / LB9 / LQ4
Transmission: T5 / T56 / 4L65E
Axle/Gears: 3:73 / 3.73 / ?.??
Looking for the hood release cable (yellow lettering) and the hood latch it attaches to - if they're in good shape - Shipped to 32539?
#55
Car: 1991 Z28
Transmission: 5 Sp
Do you still have the gauge cluster and window switches? How much to 33572
#56
Car: 1989 Iroc-Z
Transmission: Tick Stage 2 T56
Axle/Gears: 2.77
#59
Car: 1991 Camaro RS
Engine: 355 TPI
Transmission: 700R4 or 4L60
would you happen to still have the fuel lines that run behind the alternator? They're the short metal lines that hook up to the TPI fuel rail.
#69
1 Post
Car: 1990 Formula Firebird
Engine: 305 TBI (LO3)
Transmission: WC T-5 out of an 88 T/A
Axle/Gears: 10 bolt, 3.42 & Torsen Posi
I'd be interested in the transmission. Could pick up this weekend.
#71
Car: 1992 Camaro RS
Engine: 5.0 liter v8
Transmission: t5
Still need the wiring if it's available, never got an answer.
#72
Car: 92 camaro RS
Engine: Moded 350 engine
Transmission: 5 speed
Hi
I am looking for a front parking brake cable do you have a working one? Its the one that goes from the lever through the car and out to a balance bar
lmk
Thanks!
lmk
Thanks!
#74
Transmission: Pro-built 700R4
Not required anymore.
#79
Car: 1986 Z28
Engine: 383
Axle/Gears: stock 10 bolt at this time
What do you want for the shift plate for the console if its in good condition. Shipped to 19154
#80
Car: 1986 Z28
Engine: 383
Do you still have the T5 trans? If so what do you want for it
#83
Car: 1991 Z28
Transmission: WCT5
Axle/Gears: Positive 4.10
Was the AC working? If so I would be interested on the AC Lines. I believe they are made of aluminum. Please let me know the price. I am located on the 93036 zip code.
#86
Car: 1986 Z28
Engine: 383
would you happen to still have the transmission cross member. And if so could you send me a total shipped to 19154
#87
By chance, if you are still maintaining this thread how much are you asking for the fuel injectors?
#90
Hi do you know if the torque arms are different t5 vs auto I am doing conversion and the rubber bushing looks different ,don't line up Do you still have the torque arm
#92
Is it possible to still get the brackets and bolts for the a/c, p/s, AIR pump? Also the belt tensioner and idler pulleys? If so, what price shipped to 27596?
#97
Car: 1985 Camaro SC
Engine: 350 carb swap
Parting whole car. Sold alot.
Will sell everything under hood.
5 speed setup 600 picked up. World class t5
Computer with 5.0tpi 5 speed chip 150 shipped
Engine harness 150 shipped
Also have a hypertech thermo master chip 122342 for 5.0tpi auto car ..new is 225
100 shipped
100 shipped
Hello is that a serpentine set up? how much for the brackets and the bolts? thanks
#99
Car: 87 trans am clone
Engine: tbi 350 with corvette heads
Transmission: t56
Axle/Gears: 4.11
im in need of a few things if you still have like the throttle cable braket, fuel rail, 2 rubber fuel lines that run from rail to body lines, t stat housing, ecm with stock prom
