Stuff got to get out of garage after stroker swap
$600 takes it all if you can pick it up. You can have the engine stand it is on as well. Also I have a new distributor in box. Great deal if you are in driving distance and can pick up. I don't have time to haul off and I'm so busy now any thoughts of rebuilding and putting this in a truck for my daughter have gone away. I live in Olympia Washington. If your interested can schedule a pick up time and work it out. Hope this helps someone out. Forgot to mention previously have clutch, fly wheels, pilot bearing, etc.
Cat only had 500 miles on it. Have the pilot bearings for the fork. T5 had the same 135 the engine has. Good shape though.
Didn't get picture of the MAF but it is in there as well. It is a Bosch
computer tuned for MAF 305tpi still
This had 135k when pulled out. had a lifter with a slight noise. Would rebuild
took the thermostat and front belt items (power steering, alternator, etc) for the new car. Everything else here though.
Re: Stuff got to get out of garage after stroker swap
I have no idea. Was on the car when I bought it. I bought it in Nampa Idaho and then when I got to Oregon I pulled into a muffler shop and had to have a brand new high flow cat put on because the old one was clogged. Cannot find any description.
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
I need two deus (1/4 turn button bolts) for the louvers. Do you have any?
