[Sold] procharger
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
procharger
P600b tuner kit. Mostly complete less oil lines, crank pulley, and the intake pipe. I had it on my '92 which has the alternator on the drivers side. Not sure if the bracket works with earlier accessory setup $1100
SOLD
SOLD
Car: 92 1500p\u 2wd
Engine: 91 z28 tpi 355
Transmission: 91 700r4
Re: procharger
How many miles are on it? Does it come with anything for the fuel system? Why are you not using it anymore.....did you have problems? Any vids of the car running with it installed? Thanks
Re: procharger
Only has about 5000 miles on it. I switched over to a D1SC. Was running 225 walbro pump, holley EFI, and larger injectors. Never had an FMU for it. Shaft is nice and tight, no play
Re: procharger
Yes with the help of larger injectors and the walbro pump. You can get the other parts from procharger still for the fmu if you want, but not optimal imo
