carb LT1 swap parts
Car: 86 Trans am
Engine: LG4
Axle/Gears: 3.27 9 bolt posi
carb LT1 swap parts
thinking about taking my lt1 to carbed set up and was wondering if anyone had some of the parts needed to do the swap. Looking for the GMPP LT1 specific intake, optispark block off plate, 4 barrel carb, HEI distributor non computer controlled on both
Car: 1982 Camaro
Engine: LTX Carb
Axle/Gears: 3.42 Posi
Re: carb LT1 swap parts
After doing the LT1 carb swap I would suggest having your heads re-drilled for the gen 1 sbc bolt pattern, this really helps as far as intake selection which is huge. Also just have a shop weld your opti hole shut or you can measure it and find a freeze/oil galley plug that has a press fit use that try to stick with a 0.002-0.003" press fit and use RTV and you should be good.
