Pontiac 455 swap. sooooo much fun.
Old 05-28-2009, 02:33 PM
  #151
kagtech's Avatar
Car: 1987 Pontiac Firebird Formula
Engine: 350 4BC Vortec
Transmission: 4 Speed
Re: Pontiac 455 swap. sooooo much fun.
What ever came of this build? As it seems to just have fallen off with not much of a write up and or pics of the completed work.
I know someone has documented their engine swap. In the early 80s I know this is what "HARDCORE PONTIAC FANS" were doing. Here is a list of things they had done:
77-79 Firebird/TransAM Motor Mounts $24.99 ea
Custom Headers $1000.00
or Ram Air Exhaust Manifolds $259.00 ea (Re-Man)
Custom 3" drive shaft (to handle the torque)
Splice oil pressure wire (oil pressure sending unit)
Old 07-02-2009, 02:29 PM
  #152
howesbird's Avatar
Car: 1988 Pontiac Firebird
Engine: Pontiac 400
Transmission: 4L80e
i got mine in yesterday and took pics but havent uploaded them.
I used:
My stock frame mounts and 72 catilina engine mounts
72 catilina manifolds both rear exit
i got the adapter plate off of tci for 60 bucks so i got to use my stock tranny
the y-pipe i had an exhaust shop just move the outlets a bit and thats about it
oh when i lowered the motor onto the frame mount the motor was a bit crooked
so i chopped both off and made it not crooked and welded the mounts in place im firing it up in a few days and will be putting plenty of pics i want everyone finishing theres its an easy swap
Old 07-02-2009, 11:25 PM
  #153
92bird92's Avatar
I have a 92 Firebird with a V-6.... I also have a 350 Pontiac out of a 73 Ventura. Is a 455 swap and a 350 swap about the same?
Old 07-03-2009, 01:35 AM
  #154
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
They should be, if im not mistaken the 455 and 350 are almost like a 305 chevy vs a 350 chevy, different block, very similar design. But im not sure, im no Pontiac expert.
Old 07-03-2009, 01:17 PM
  #155
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
same shiite, different displacement. it's the difference between a 305 and a 400 SBC. the physical installation is the same, however. I'd do this if I could afford to build a Pontiac.
Old 07-07-2009, 09:28 PM
  #156
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
all depends on where you look. I picked up my 78 4o0 for a mere $2400. came w/free Formy body
any old Poncho battlewagon or GP/Pheonix should have a nice donor engine, just gotta look. craigslist is a nice source
Old 07-19-2009, 11:42 AM
  #157
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
Just make sure to upload the pics, especially the motor mounts and exhaust. I am thinking about this swap and would prefer NOT to do this one with no insight (like I did the olds/buick swaps) so please help!!
Great job to those who have done it!!
Old 07-21-2009, 01:56 PM
  #158
72vega's Avatar
Car: 2008 Silverado, 73 LeMans, 1987 GTA
Engine: 4.8, 350 Pontiac, 350 LT1
Transmission: 4L65E, TH350, T56
Axle/Gears: 3.42, 2.73, 3.42
any pontiac engine from 65 till 78 or 79 are dimensionally the same. 326, 350, 389, 400, 421, 428, 455. bore, stroke, and crank journal size are the differences (all used 3.00 inch mains except the 421, 428, and 455 which used 3.25 mains.) the 265 and 301s are short deck engines=junk. 64 and before are similar but have many differences (heads, intake, timing/water pump cover etc)the later 70s 400s have weaker blocks as the main webs are thinner. unless its a service replacment block or earlier one, its best not to make huge HP engines out of em.. one way to tell what a pontiac engine is, pull the intake and look in the lifter valley. there will be 2 numbers. like my 72 455 has "5 5" cast into it, meaning its a 455. it is also on the front of the engine on the pass. side (the vehicle VIN and a 2 letter code for the engine) im sure theres much i missing, but its some good info...
Old 07-25-2009, 06:53 PM
  #159
howesbird's Avatar
Engine: Pontiac 400
Transmission: 4L80e
ok i got the car in the lift ill take some pics tomorrow i used the stock frame side mount as factory. Then for engine side mounts i used the saddle or u shaped mounts out of a 74 catalina which was my donar car
I also used manifolds too instead of this header crap which seems like a pain other than that the swap was pretty tit i even used the stock tranny
Old 09-09-2009, 07:00 PM
  #160
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Eagerly awaiting pictures and information.
Old 09-17-2009, 06:25 PM
  #161
kagtech's Avatar
It would be nice if there were pictures to go along with what is being stated about this project. As I have heard of people doing it but have yet to see it documented. Please post some pics.
Old 01-14-2010, 04:27 AM
  #162
Fast Floridian's Avatar
Dude does any one have the old pontiaction motor mounts still around or specs on to build them
Old 03-22-2010, 10:34 AM
  #163
devan92bird's Avatar
did you keep your a/c i have a 1992 f_bird i,m going 2 put a 455 in and i was wondering just how tight a fit is it
Old 03-22-2010, 10:45 AM
  #164
KrisW's Avatar
Engine: 2.8/TBI/TPI
Need those pics...
Old 04-29-2010, 06:21 AM
  #165
howesbird's Avatar
Engine: Pontiac 400
Transmission: 4L80e
just got in a bad bike accident so im gonna be in the hospital for a bit. Once i get out ill take those pics
Old 02-21-2011, 03:44 PM
  #166
face215's Avatar
Car: 89' GTA
Engine: L98 with tpi to carb swap
Axle/Gears: stock
We need pics!!!!!!!
Old 02-21-2011, 05:58 PM
  #167
LT1guy's Avatar
Car: 1987 Trans Am
Originally Posted by face215
We need pics!!!!!!!
Wow, this thread is a blast from the past! I still have the '87 TA, and I'm finally about to get started on it. I have my own shop now, so its been on the backburner. I'll post pics as soon as I have some. Someone talked me out of my 455 years ago, so this time I'll go 400 (stock stroke) and give it a little boost!
Old 02-25-2011, 09:18 AM
  #168
K.C.Kustoms's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.1 l v6
I'm thinking of doing this swap myself. I'm tired of my v6 fuel injection giving me fits, and I am ready to go with an old school carbed engine.
If any one could make a complete guide with some pictures of the motor mounts, transmission mounting & hookup, exhaust manifold clearance as well as exhaust hookup, drive shaft fitment and any wiring that is needed. Also, any other information of the instilation would be helpful.
Thank you guys for all the information and I can't wait to build one myself.
Old 02-26-2011, 07:46 AM
  #169
Car: 1982 Trans Am
Engine: 383 chevy
so basically, you want someone to do all the hard work for you.... gotcha. good luck with that.
instead, read this thread and the Pontiac V8 swap thread, and keep watching for updates.
Old 02-26-2011, 05:39 PM
  #170
Engine: 3.1 l v6
I'm sorry if I offended you but I am new to cars not to mention engines and would just like a little direction. I have read through a bunch of these threads and have gotten a pretty good idea on how everything is put together and what is needed but a lot of them do not show how everything came together with pictures.
Thank you for the information though. I can't wait to get started on this project.
Old 08-02-2011, 12:59 PM
  #171
KrisW's Avatar
Engine: 2.8/TBI/TPI
What ever happened here?
Old 09-02-2011, 05:21 PM
  #172
cortcomp's Avatar
If this thread is still going and you're looking for a good flowing, but fit in tight spaces exhaust, consider oversized repro factory cast headers, guys out there with 500+hp flowing through them:
http://www.ramairrestoration.com/cat...?cPath=31_2_21
Also, hit this site for friendly guys to help pick the right parts:
psp.aquacomp.net
These motors are so fun...with a $400 455 craigslist block, for about 4-5K if you don't do anywork yourself and buy the off the shelf good stuff, you can have a 450-500hp and 550+ torque motor....with all the power by 4500-5000 rpm, and most of it there by 1500rpm. You could do it way cheaper if you can do your short block and find some iron heads and drop 1k into the heads to have them ported, larger valves, and properly setup. no small block 6000 rpm stuff here! and it'd run off of 91 octane and live forever. The problem you'll have is eating transmissions, rears and twisting cars from having too much fun...if you can get traction!
Old 11-29-2013, 07:27 PM
  #173
spdmetl's Avatar
Anybody done one of these lately?
Old 04-06-2014, 07:43 AM
  #174
spdmetl's Avatar
How bout now?
Old 10-28-2015, 12:10 PM
  #175
Dr.Jones's Avatar
Car: 1987 firebird V8 base
Engine: 1968 400 +.060
Transmission: TH400
Axle/Gears: stock 3.08 looking for G80 3.43
Hey spdmetl
I am doing this swap NOW but mine is a 400 puched .060. I have photo documented most of the whole project.
Old 04-02-2016, 05:25 AM
  #176
spdmetl's Avatar
Originally Posted by Dr.Jones
Hey spdmetl
That looks good. Guess I should check in more often!
Old 04-29-2016, 09:01 PM
  #177
Savage Muffin's Avatar
Anyone moved forward? I love following these builds. I think it's awesome people are going outside the box instead of going corporate SBC BBC or LS. Not that there is anything wrong with those, I just enjoy the "outside of normal" approach. Great job folks. Tons of great info on this site, it's definitely one of my favorites.
Old 12-25-2016, 12:30 PM
  #178
Poncho92's Avatar
Originally Posted by lbrohez
It is a big block Pontiac, because the 301 Pontiac was smaller than all the rest of the Pontiac v-8's
in the true Pontiac world the 301 was it's own block, with it having no mechanical relationship with the 326-455s except for the timing chain cover and valve covers,. Most of us old timers never considered it a true Poncho engine just like most Chevy guys hate the 305 like we hate the 301 lol
Old 08-08-2022, 08:49 PM
  #179
wasteland's Avatar
Originally Posted by Kross4031
This is my little piece of big block heaven.
hey I know this is old as all get out but what motor mounts did u use I heard 2gen ones bolt right in
Old 10-27-2022, 02:33 AM
  #180
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
2nd gens work on the set-up, but not a bolt in. Need-ta drill new holes, (in the K-frame cross-member) in the proper location. Altho there are multiple holes down there, "none" are for a Pontiac V-8. At least on my 84. Can't say about 82-83.
Old 11-02-2022, 04:33 PM
  #181
wasteland's Avatar
well this weekend i can let you know if they are there for a 82 or if im drillig got my butler performace motor mounts
Old 11-02-2022, 04:41 PM
  #182
tajoe's Avatar
Car: 84 Trans Am
Engine: Turbo 301
Have fun. Hope to see some pics.
Linson
09-25-2021 07:55 PM
mattcanty
10-12-2015 11:08 AM
paul_huryk
10-01-2015 04:27 PM
Quick Reply: Pontiac 455 swap. sooooo much fun.
