Claimer pan in a 3rd gen?
Old 11-13-2016, 10:53 PM
91Z28_Nightmaro's Avatar
Has anyone put a claimer pan on there 350 in there 3rd gen?
Basically my 350 in my 91 5 speed z28 is in need of some major love (smokes like a train) and I happen to have my stock car motor sitting on my motor stand.
It has a 7 qrt claimer pan for a 80s g body (montie carlo) and was ordering parts for the swap and didn't know if the pan would fit or not.
If not can someone give me a part number for a 70s block stock oil pan and pick up screen for my car.
Motor going in is a 70s 010 4 bolt, steel crank, forged eagle rods, 2 valve releaf flat top speed pro hyper u pistons, molly rings, 6.48 lift cam, 2101 intake, 4 barrel holly, aluminum water pump, under drive kit, double hump heads, 2.05 valves, full roller rockers, screw in studs, guide plates, polly locks, and stud gurtels.
Like I said it's out of my stock car lol.
Old 11-14-2016, 03:07 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: Claimer pan in a 3rd gen?
If it has kickouts it probably won't go, and certainly isn't worth the hassle. The correct pan is common and cheap, selling your current pan should more than cover it.
