[PA] 1983 Camaro Drivers side window filler panel
Want a title? Post!
Car: 1983 Camaro Sport Coupe
Engine: 406 sbc
Transmission: TH 350
Axle/Gears: Ford 9" 3.73 ratio
Hi all! New to this board, so please let me know if I'm screwing up! I am in need of an early style drivers side window filler panel as mine has been broken in half and poorly repaired somewhere along the way. To be clear, this is the plastic piece that hides behind the mirror and unbolts from inside the door. Mine has 2 square holes where it bolts horizontally to a bracket inside the door and is also separate from the metal window guide. Any help is greatly appreciated!!
1 Post
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
Re: 1983 Camaro Drivers side window filler panel
The window triangle? I've got one for $25 shipped
Want a title? Post!
Engine: 406 sbc
Thanks for the reply. I actually have the other style that is all one piece and I understand that it can be made to work. I have it sitting in the door and the window works but I just need to figure out a top bracket to mount it to. Let me give it a try first and I'll let you know if I need yours.
