Rack & Pinion Steering
The 82 Camaro roller I bought has stock steering in it. It now has a big block in it and the steering sucks. I would like to put in a rack and pinion setup but don't know what I might be getting into. Any comments or suggestions would be appreciated.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Rack & Pinion Steering
Why does your current steering suck? I run a manual steering box from an S10 in my drag car and it works just fine.
There's a lot of work to convert to rack and pinion. It's not a simple bolt in conversion. Most people who do the conversion also replace the k-member and a-arms so the rack has proper mounting brackets on the k-member.
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
What about putting in an astro or cherokee steering shaft to give more room around the headers and get rid of the stock rag joint? Lots of how to's on here
Jay
Jay
Car: 86 Camaro IROC-Z
Engine: 565ci 900 hp
Transmission: T56 Magnum by RPM Transmissions
Axle/Gears: Moser 9" w/4:56 Detroit Locker
I have a rack in mine, and alky is right, I bought new K-Member with rack mounts already installed on it. But I love it, I also have shorten arms on my spindles. Steers easier than any manual steering that I have ever driven
sjorgens
10-01-2015 07:54 PM
