Members post your RPO codes!
#52
Car: 1989 IrocZ Convertible
Transmission: T5 - 5 Speed Standard
Axle/Gears: 3.08
Re: Members post your RPO codes!
I also have the Z49. A cool Canadian ride with the 7-digit odo! (American rides only got 6 , LOL).
Same gauge cluster, other than the speedo top-end. LB9 & 5spd std.
Not to unusual having all the nice performance options, you do also have a G92. Sweet ride.
Originally Posted by Twin_Turbo
Has 5 speed, LB9 high output (5500 redline), 9 bolt axle w/ perf ratio, J65 discs.
#53
Yes, GM3, G92, G80
I know the perf. options are not unusual but it doesn't have any creature comforts apart from power windows, there's not even a cruise control on it.
Wonder why mine has a 240km/h speedo. didn't even know there was a 180 one like yours.
#54
Car: F-Body / Cadillac STS
Engine: 305 TPI LB9
Transmission: TH 700 R 4
...btw...RPO: "V73" is not "ANTENNA, FIXED"
...this is a flaw/error in many decoders/databases...
"V73" stands for "VEHICLE STATEMENT USA/CANADA"
#56
Engine: 305 TPI LB9
...possible....because there are also many f-bodys without tilt...and there is this separate RPO Code "N33" for STEERING COLUMN, TILT TYPE
...maybe it depends on model and/or modelyear...my cars rpo sticker doesn't list the N33...but its got the tilt column...
...I see, you are from Enschede....hello "neighbor" (Gruß aus der Grafschaft Bentheim)
#58
Car: 85 Z28 Vert
Engine: LG4 ENGINE 5.0 4BBL
Transmission: 700R 4SPD
Axle/Gears: 3:08
#59
Engine: 305 TPI LB9
...yes...and as I said before...this isn't correct...this is an old error/flaw/fault and should be fixed...!
example:
...many cars got RPO "U75" ANTENNA POWER and also the "V73" on the sticker...so V73 could not be ANTENNA FIXED... ...that's an antagonism...
...try this:
http://www.compnine.com/research.php?rpon=v73
...or this:
http://www.cadillacfaq.com/rpo/rpo4.php?rpo=v73
...or this:
http://www.camarosource.ca/php/camar...(VIN)_Decoding
...or this:
http://www.team3rdgen.com/modules.php?name=RPO_Decoder
...and even here:
http://www.gmtips.com/3rd-degree/dox/tips/rpo/rpo.htm
V73 is VEHICLE STATEMENT, USA/CANADA
...another example:
...most export cars got the code "V78" ...it's the same "row" and denotes:
V78 is VEHICLE STATEMENT(DELETE)(EXPORT)
example:
...try this:
...or this:
...or this:
...or this:
...and even here:
...another example:
#61
Engine: 305 TPI LB9
...is it the black car with the german "ST" (Steinfurt) license plate?
...he has got an export GTA....
...there should also be an "EXP" (EXPORT), "MAE" (Marketing Area Europe), "VC5" (SHIPPING LABEL, EXCEPT US, US POSSESSIONS, OR JAPAN), "DD9" mirrors and a missing "T93" for the taillamps (90-92 export TA and GTA got the "basic" Firebird tails instead of the typical "smoked" or dark/grid style TA/GTA lamps)
...and some other parts/codes...
#62
Yes, I know the car was originally sold in Germany. There's EXP on it and MAE and D99 mirrors too although those are gone already. The D99 are the same square floppy eared ones used on EXP vettes. I have it on my 90. I think they are the same as what came on some Porsches...not entirely sure.
Here's my 90 w/ the ugly dumbo ear mirrors
It indeed originally had the amber/red/white rear lights, now it has the smoked grid ones. Prev. owner swapped those and lost the originals. Did a nice job of hacking up the rear light harness too. Took me a couple hours to figure out what was wrong. For good measure he cut the wires in not one spot but 3! made damn sure no electron would ever get through LOL
Just wondering what Statement Delete means.
Here's the complete list
A31: WINDOW, POWER OPERATED, SIDE
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8: ORNAMENTATION, INTR, DR MAP POCKETS
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
C49: DEFOGGER, RR WINDOW, ELECTRIC
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4: MIRROR I/S, R/V, TILT, DUAL READING LAMPS
DD9: MIRROR O/S, LH & RH,
RE4 CONT, ELEC, 8REAKAWAY,
D42: SHADE, RR COMPT SECURITY
D5X: GEAR, SPEEDO DRIVEN
D8I: SENSOR, VEH SPD
EXP: EXPORT VEHICLE
E5Z: SPEEDOMETER ADAPTER (DELETE)
E9Z: SPEEDOMETER KEY (DELETE)
FE2: SUSPENSION SYSTEM, RIDE HANDLING
GU5: AXLE REAR, 3.23 RATIO
G80: AXLE POSITRACTION, LIMITED SLIP
IL2: TRIM- INTERIOR DESIGN
JG1: SHAFT, PROP, ALUMINUM
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
KC4: COOLING SYSTEM, ENG OIL
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68: GENERATOR,105 AMP
L98: 5.7 LITER V8 TPI ENGINE
MAE: MARKETING AREA, EUROPE
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5: EMISSION SYSTEM, FEDERAL, TIER O
NP5: LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N10: EXHAUST SYSTEM DUAL
N64: WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
PW7: WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
QLC: TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
R6U: CONTROL SALES ITEM 20
T96: LAMP, FOG
U83: ANTENNA, POWER, CITIZENS SAND/RADIO TRIBAND
UL2: FREQUENCIES, EUROPEAN RADIO
UQ1: RADIO PROVISIONS, FOR STEREO
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
U19: SPEEDOMETER,INST, KILO & MILES KILO ODOMETER
U62: SPEAKER SYSTEM, DUAL COAXIAL
U75: ANTENNA, POWER, RADIO
VAN: ASSEMBLY PLANT, VAN NUYS, CA
VC5: LABEL SHIPPING, EXCEPT U.S., U.S. POSSESSINS, OR JAPAN
VK3: LICENSE PLATE, FRT MOUNTING PKG
V78: VEHICLE STATEMENT DELETE
WS4: MODEL CONVERSION, TRANS AM
WS6: PERFORMANCE PACKAGE, SPECIAL
Y84: MERCHANDISED PKG, GTA, TRANS AM
1SA: Option Package 01
19I: INTERIOR TRIM, BLACK (I) (91)
19Q: MOLDING COLOR (BLACK)
192: TRIM COMBINATION, LEATHER, BLACK (2) (91 )
199: SEAT BELT COLOR, BLACK (91)
41U: PRIMARY COLOR, EXTERIOR, BLACK
52P: WHEEL COLOR, GOLD MET (91)
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING
EXP: EXPORT VEHICLE
T96: LAMP, FOG
#66
1987 IROC
1AY : 1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1HV : COMPONENTS OF IROC-Z PERFORMANCE PACKAGE(CHEV)
1SC : PACKAGE, OPTION 03
62C : TRIM COMBINATION, CLOTH, LT SADDLE (C)
62I : INTERIOR TRIM, LT SADDLE (I)
6ZX : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZX : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
81Q : MOLDING COLOR, BRIGHT RED (91)
81U : PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
88A : STRIPE COLOR, ACCENT, TWO TONE, GOLD/BLACK (91)
8NL : COMPUTER SELECTED REAR LEFTHAND SPRING
92P : WHEEL COLOR GOLD N/A
9NL : COMPUTER SELECTED REAR RIGHTHAND SPRING
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, SIDE
A90 : LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
AC3 : ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9 : ADJUSTER, SEAT, POWER, 6 WAY
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3 : LOCK CONTROL, SIDE DR, ELEC
B18 : ORNAMENTATION, INTR, DELUX
B34 : COVERING, FRT FLOOR MATS CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS CARPETED INSERT
B4Z : IROC PACKAGE
B84 : ORNAMENTATION, EXTR MLDG, B0DY SIDE
B94 : FENDER EMBLEM, Z28
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
C60 : HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
D08 : PAINT, HIGH GLOSS FINISH
D42 : SHADE, RR COMPT SECURITY
D6F : GEAR DRIVEN SPEEDO
D80 : SPOILER, RR END PNL
D88 : DECAL, STRIPE, SPORT
DD8 : MIRROR I/S, R/V, LT SENSITIVE
DG7 : MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
DK6 : CONSOLE ROOF, INTERIOR
E5Z : SPEEDOMETER ADAPTER (DELETE)
E7Z : VEHICLE SPEED SENSOR DELETE
E9Z : SPEEDOMETER KEY (DELETE)
FE2 : SUSPENSION SYSTEM, RIDE HANDLING
G80 : AXLE POSITRACTION, LIMITED SLIP
G92 : AXLE REAR RATIO, PERFORMANCE
GU5 : AXLE REAR, 3.23 RATIO
J54 : ?
K34 : CRUISE CONTROL, AUT0MATIC, ELECTRONIC
K68 : GENERATOR,105 AMP
KC4 : COOLING SYSTEM, ENG OIL
LB9 : ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
MD8 : TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO : MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
N33 : STEERING COLUMN, TILT TYPE
N64 : WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
N96 : WHEEL, 16 X 8, CAST ALUMINUM
NB2 : EMISSION SYSTEM , CALIFORNIA , TIER O
NP5 : LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
P20 : HUBCAPS, WHEEL, STYLED
PB4 : LOCK CONTROL, WHEEL
QDZ : TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
T93 : LAMP, TAIL & STOP, SPECIAL
T96 : LAMP, FOG
TR9 : LAMP, GROUP
TT4 : HEADLAMPS, HALOGEN, 4
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
UX1 : RADIO, AM/FM STEREO CASSETTE EQUALIZER
V27 : GUARDS, BUMPER, FRT,
V73 : ANTENNA, FIXED
V79 : ?
VAN : ASSEMBLY PLANT, VAN NUYS, CA
VG8 : VEHICLE, BUYER NOTICE LABEL
VK3 : LICENSE PLATE, FRT MOUNTING PKG
VQ1 : FLEET PROGRAM DEALER ASSISTANCE, WITH HOLD BACK
YA7 : EMISSION TEST, REQUIRED FOR CALIFORNIA
YF5 : CERTIFICATION, EMISSION, CALIFORNIA
YR1 : SEAT,FRT CUSTOM
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 : MERCHANDISED PKG, SPECIAL PERFORMANCE
B4Z : IROC PACKAGE
J54 : ?
T96 : LAMP, FOG
TR9 : LAMP, GROUP
V79 : ?
#67
Engine: 305 TPI LB9
...wtf...lol...
...the prev. owner better should have spend some money to buy and use the original (now very rare) 91/92 "two-part" TA/GTA grid-tails.......no hacking necessary...
...i know...a good harness job isn't easy...costs me a couple of hours to "convert" my euro-specs STS almost back to the domestic/us-style (lightening...and all the parts, lamps and so on) ...I still don't like the "euro"-conversions...
...for the ugly D99....yes, but they only called "Porsche" style-mirrors...because of their resemblance to them...thats all...(Porsche never ever use such a cheap and cheese low-budget part... )
...never forget this "few months built" early 1987 model GTA, which used this mirrors even in the us-market...as a -quote- "direct reference to the GTA's supposed "euro" predilections"...
...for the codes: ...it looks like every 91/92 MAE export-GTA got the same options/RPOs...only difference is color (int. and ext.)
...and for the euro-conversion....they all got the basic taillamps, DD9, canadian U19 or pure metric U18 speedo...but the worst is...sometimes they rip out the 3rd brake lamp completely (not only the bulb), they pull the fogs or sprayed them black, put on the ugly "Hella"-turn signal cubes on the original turnsignal and some other bad stuff...
#68
Car: 1986 Z28
Engine: ZZ3
I think I'll revive this old post I found while searching for RPO codes. Here are mine.
AR9
AU3
A01
A31
A90
BS1
B18
B3W
B84
B9K
B94
B97
CD4
C4A
C49
C60
C95
DG7
D08
D34
D42
D6D
D80
D88
E5Z
E7Z ?
E9Z
GC5 ?
GC6 ?
GUZ
J50
K22
K34
LG4 (gone)
MD8
MX0
NA5
NK3
N0D ?
N33
N90
P20
QYH
TR9
TT4
T63
T93
UM6
UP8
U21
U25
U26
U29
U75
U79
VK3
V73
YE3
YR1
Y51
YT1
YT9
Z28
1AY
16P
17A
23Q
23U
6ZX
7ZX
8NM
B2C
82I
829
9NM
AR9
AU3
A01
A31
A90
BS1
B18
B3W
B84
B9K
B94
B97
CD4
C4A
C49
C60
C95
DG7
D08
D34
D42
D6D
D80
D88
E5Z
E7Z ?
E9Z
GC5 ?
GC6 ?
GUZ
J50
K22
K34
LG4 (gone)
MD8
MX0
NA5
NK3
N0D ?
N33
N90
P20
QYH
TR9
TT4
T63
T93
UM6
UP8
U21
U25
U26
U29
U75
U79
VK3
V73
YE3
YR1
Y51
YT1
YT9
Z28
1AY
16P
17A
23Q
23U
6ZX
7ZX
8NM
B2C
82I
829
9NM
#69
Car: 1986 Z28
Engine: ZZ3
#70
1 Post
Car: 1989 Camaro RS--
Engine: MPFI
AR9 A03 A01 A90 B18 B34 B35 B84 CD4 C49 C60 DX3 D35 D6H D80 E5Z E7Z E9Z
FE1 GUS IPC J50 K34 K60 LB8 MD8 MXO NB2 NK3 N33 N90 QPH TR9 UA1 UB3 UM6 UQ1
U25 U26 U29 U79 VAN VG8 VK3 V73 WW6 W62 YA7 YF5 IAY ISC ISZ 6XS 66C 661 669
7XS 74Q 74U 8UX 9UX 92P
Bottom # is WA; L9535 09535 66C
Ok now that I added them, maybe some help breaking them down. lol
I am sure it is a easy prosess. Seem to be in alphabetical order.
I ran all my RPO Codes, Never found paint color or rim color.
I have a few that I couldnt find.
#71
Car: 1990 firebird formula 5.0
Engine: 305 tbi
Axle/Gears: 2:73
I need to search around to find what they all are but until then here's what i have in my 90 Formula: AAA, AH3, AJ3, AR9, AU3, A31, A90, BC8, B84, C60, DC4, DG7, D7C, D8E, D81, E5Z, E9Z, FE2, GU2, IPC, J41, K34, K60, L03, MD8, MXO, NA5, N36, N65, PEO, QLC, UB3, UM6, UQ1, U62, VAN, VK3, V73, WS6, WX1, W66, ZV1, 1SC, 12P, 6ZW, 75U, 8NL, 82C, 821, 829, 85Q, 9NL...... Throughout the message boards it looks like I can find most of them.. Oh BTW, I guess this is my first post. No need to post since everything Ive needed to know has already been said! TGO is pretty awesome.
#72
Here is my complete set of RPO codes. I have two that the RPO reader recognized but couldn't identify. I found that one of them (1AY) meant that it was a dealer ordered car and the other (1SZ) was some form of a discount or preferred savings package. The decoder did not recognize R6C and all I can find on it is that it stands for "control sales item 3." This looks suspiciously similar to what I've found on 1SD though, which was preferred Iroc-Z equipment 3, so I have a feeling they may go hand in hand.
AC3: ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
AG9: ADJUSTER, SEAT, POWER, 6 WAY
AM9: SEAT, RR, SPLIT, BACK, FLDG
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3: LOCK CONTROL, SIDE DR, ELEC
A01: WINDOW, TINTED, ALL SHADED, W/S
B18: ORNAMENTATION, INTR, DELUX
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B48: TRIM EQUIPMENT, LUGGAGE COMPARTMENT
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
CD4: WIPER SYSTEM WINDSHIELD, PULSE
C69: HVAC SYSTEM, RR, AIR CONDITIONER
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
D34: MIRROR, VISOR VANITY
D6D: COLOR OVERRIDE, TRIM AND PAINT COMPATABILITY
D80: SPOILER, RR END PNL
D88: DECAL, STRIPE, SPORT
E72: BODY LENGTH, INCR I8 INCH
GU2: AXLE REAR, 2.73 RATIO
IPC: TRIM- INTERIOR DESIGN
J50: BRAKE SYSTEM, POWER
LB9: ENGINE, GAS, 8 CYL, 5.0L, TPI, HO
N33: STEERING COLUMN, TILT TYPE
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
PF2: WHEEL, 15 X 7, ALUMINUM
QYZ: TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
R6C: Control Sales Item #3
TR9: LAMP, GROUP
TT4: HEADLAMPS, HALOGEN, 4
T93: TAIL & STOP LAMP, SMOKED
T96: LAMP, FOG
UA1: BATTERY, HEAVY DUTY
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
U25: LAMP, INTR, RR COMPT, COURTESY
U26: LAMP, INTR, ENG COMPT, COURTESY
U29: LAMP, INTR I/P, COURTESY
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
V73: VEHICLE STATEMENT USA/CANADA
WW8: APPEARANCE PACKAGE(BRIGHT RED), AERO #8
W62: ORNAMENTATION, AERO PACKAGE
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
1AY: STOCK ORDERS PROCESSING OPTION (DEALER ORDERED CAR)
1SD: OPTION PACKAGE 04 (IROC-Z PREFERRED EQUIPMENT GROUP #3)
1SZ: PREFERRED EQUIPMENT GROUP SAVINGS
16P: WHEEL COLOR, BRT WHITE (91)
19C: TRIM COMBINATION, CLOTH, BLACK (C) (91)
8NN: SPRING, COMPUTER SELECTED, REAR, LEFT HAND
81Q: MOLDING COLOR, BRIGHT RED (91)
81U: PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
86A: STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NM: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
TR9: LAMP, GROUP
T96: LAMP, FOG
#73
Car: 1985 Trans-Am
Engine: 305 LG4 4bbl
Axle/Gears: 3.27 Limited Slip
Here's my list for my '85 TA
AAA- 4 WAY MANUAL SEAT ADJUSTER
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR,
AM9 : SEAT, RR, SPLIT, BACK, FLDG
BS1 : INSULATION, ACOUSTICAL PKG
B20 : ORNAMENTATION, INTR, LUXURY
B35 : COVERING, REAR, FLOOR MATS, CARPETED INSERT
B67 : CONTAINER, RADIO CASSETTE TAPES
B84 : ORNAMENTATION, EXTR MLDG, BODY SIDE
C41 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
C49 : DEFOGGER, RR WINDOW, ELECTRIC
D02 : PAINT, ENAMEL MASTER
D35 : MIRROR, OUTSIDE REAR VIEW
F41 : SUSPENSION SYSTEM, FRT, RR, FIRM RIDE, HANDLING
GW6 : AXLE REAR, 3.27 RATIO
J65 : BRAKE SYSTEM, PWR, FRT & RR DISC
K64 : GENERATOR, 78 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N65 : WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9 : LAMP, GROUP
T96 : FOG LAMPS - FRONT
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UT1 : TONE GENERATOR, WARNING
U23 : CLUSTER, INST, TRIM ODOM
U27 : LAMP, INTR, I/P COMPT, COURTESY
U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
WS4 : MODEL CONVERSION, TRANS AM
WW2 : APPEARANCE PACKAGE(SILVER), AERO #2
W62 : ORNAMENTATION, AERO PACKAGE
YS1 : SEAT,RR CUST
Y99 : SALES, HANDLING PKG
Z49 : EXPORT CANADIAN MODIFICATION MANDATORY BASE EOUIPMENT
19Q : MOLDING COLOR (BLACK)
30U : PRIMARY COLOR, EXTERIOR, GRAY BLUE MET (91)
30L : SECONDARY COLOR, EXTERIOR, GRAY BLUE MET (91)
6DB : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
8UZ : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
82C : TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
829 : SEAT BELT COLOR, MED DK GRAY (91)
84P : WHEEL COLOR, GRAY (91)
9UZ : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
-OSS
TR9 : LAMP, GROUP
YS1 : SEAT,RR CUST
-OSS
#74
Car: '89 IROC conv.
Engine: 5.0L F
Transmission: T-6 world class
Axle/Gears: yes
So my addition to this fun listing is: a '89 IROC-Z conv.... Bought it a few years back and I've been slowly nursing her back to health. Previous owner made some 'interesting' improvement choices...
and here are my RPO's:
1FP67 Camaro IROC-Z Sport Coupe Conv
AC3 6-way Power Seat, Driver Side
AG9 6-way Power Seat, Driver Side
AR9 Seat Asm, front Bucket Recline(European Style)
AU3 Power Door Locks
A01 Tinted Glass, All Windows
A31 Power Windows
B18 Ornamentation, Interior, Deluxe
B34 Floor Mats, Front
B35 Floor Mats, Rear
B84 Moldings, Body Side
CD4 Windshield Wipers, Intermit
C60 Air Conditioning
DG7 Mirrors, Electric Twin Remote
DX3 Decal and Stripe Delete
FE2 Suspension System, Touring Ride and Handling
GU4 Axle, Rear 3.08 Ratio
G80 Rear Axle, Limited Slip
IPC Trim Interior Design
J50 brake Sytem, Vacuum Power
K34 Speed Control, with Resume
T96 Lamps, Front Fog
UA1 Battery, Heavy Duty
UB3 Cluster, Instrument(Oil Temp, Volts, Trip, Tach)
UQ1 Radio, Stereo Installation Provisions
UX1 Radio, Stereo, Cassette, Clock, s/s, eq
UX6 Speaker System, Front Dual
VAN Assembly Plant, Van Nuys, CA
VG8 Vehicle, Buyer Notice Label
VK3 Mounting, Front License Plate
V73 Antenna, Fixed
WW4 Aero Package #4 Black
W62 Aero Package
YA7 Emission Test, Req for CA
YF5 Emission Equipment
Z28 IROC-Z Option
1SD Option Package 04
1SZ UNK
15P Wheel Color, Medium Metallic Gray
191 Interior Trim, Black
19C Trim Combination, Cloth Black
199 Safety Belts, Black
41UExterior Color, Primary Black
6ZW Spring, Computer Selected Front Lefthanded
7ZW Spring, Computer Selected, Front Righthand
8NL Spring, Computer Selected Rear Lefthand
9NL Spring, Computer Selected, Rear Righthand
A31 Power Windows
V73 Antenna, Fixed
W62 Aero Package
Z28 IROC-Z Option
1SZ UNK
#75
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Too bad there aren't any V6 cars in this thread... I don't (and possibly never had from the time I bought the car) have an RPO label. I made a partial list from the description in my 92 FSM and from on here, but I know it's nowhere near complete. I still should go back to the J/Y and get a pic of the one on the Norwood car there that's very nearly identical to mine (except hardtop)...
Couple questions:
RPO for Medium Gray GTA style interior?
Floor mats (medium gray as well)?
Front springs had the original GM factory stickers on them, both with the same code: BXR. Does this mean anything to anyone?
Anyone know anything about some sort of stripe down the side of the car, down the top, from the nose to the tail? Seems like it was original, as I found it on both sides (even under the primer on the passenger's side and on the quarter on the driver's side) on my factory panels. It was a pin stripe, 1/8" wide at the top and 1/16" wide under it... No, I don't have pics, as even my decent cam might not have picked it out (found it and covered it a while ago now), but the stripe was a slightly darker red than the main body color (don't think that was Bright Red either as it seemed slightly orange?).
Couple questions:
#76
Hi
I will post all codes on my 85 IROC later but for now just one. Mine has a GU6 rear end code which I believe is a non positraction 3.42 gearset. This is not indicated as an option on the 85 camaro tech page but should be I think. Does anyone know how many IROCs were produced in 85 with that gear set? I have checked the ratio and it is a 3.42.
#78
My code sheet does not list G92 but only GU6. That is the puzzle to me. I am aware of the G92 option. I have, uh, road tested mine and can assure you it is not limited slip and the number stamp also indicates it is not. Any additional info would be helpful. You guys are terrific, thanks.
#79
Transmission: World Class T-5
Axle/Gears: BW 3.45
Apparently all '85 IROCs with the LB9 had the GU6 3.42 gears. My '85 has the GU6 3.42 and non posi.
#80
1991 Trans Am The following codes were not in the decoder R6P,R9Z
AH3- ADJUSTER, 4 WAY MANUAL, DRIVER SEAT
AJ3- RESTRAINT SYSTEM, FRT SEAT, INFLATABLE DRIVER
AR9-SEAT, FRT, BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AU3- LOCK CONTROL, SIDE DR, ELEC
A31- WINDOW, POWER OPERATED, SIDE
A90- LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
BC8- ORNAMENTATION, INTR, DR MAP POCKETS
B2L- PERFORMANCE PACKAGE ENGINE PACKAGE V8 5.7LPFI
B84- ORNAMENTATION, EXTR MLDG, BODY SIDE
C49-DEFOGGER, RR WINDOW, ELECTRIC
C60- HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
DC4- MIRROR I/S, RV, TILT, DUAL READING LAMPS
DG7- MIRROR O/S, LH RH, REM CONT, ELEC, PAINTED
D42- SHADE, RR COMPT SECURITY
D5X- GEAR, SPEEDO DRIVEN
D8I- SENSOR, VEH SPD
D81- SPOILER, RR, AERO WING
E5Z- SPEEDOMETER ADAPTER (DELETE)
E9Z- SPEEDOMETER KEY (DELETE)
FE2- SUSPENSION SYSTEM, RIDE HANDLING
GU5- AXLE REAR, 3.23 RATIO
G80- AXLE POSITRACTION, LIMITED SLIP
IPC- TRIM- INTERIOR DESIGN
JG1- SHAFT, PROP, ALUMINUM
J42- BRAKE SYSTEM, PWR, FRT DISC, RR DRUM, ALUMINUM
KC4- COOLING SYSTEM, ENG OIL
K34- CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K68- GENERATOR, 105 AMP
L98- 5.7 LITER V8 TPI ENGINE
MD8- TRANSMISSION, AUTO 4 SPD, THM 700 R4
MXO- MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
NA5- EMISSION SYSTEM, FEDERAL, TIER O
NP5- LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N10- EXHAUST SYSTEM DUAL
N64- WHEEL TIRE SPARE, SPACE SAVER, ALUMINUM
PW7- WHEEL, 16X8, ALUMINUM, DIAMOND SPOKE
QLC- TIRE ALL, P245/50ZR16/N BL R/ PE ST TL HW4
T93- TAIL STOP LAMP, SMOKED
T96- LAMP, FOG
UB3- CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM TACH
UQ1- RADIO PROVISIONS, FOR STEREO
UX1- RADIO, AM/FM STEREO CASSETTE EQUALIZER
U62- SPEAKER SYSTEM, DUAL COAXIAL
VAN- ASSEMBLY PLANT, VAN NUYS, CA
VK3- LIXENSE PLATE, FRT MOUNTING PKG
V73- ANTENNA, FIXED
WS4- MODEL CONVERSION, TRANS AM
WS6- PERFORMANCE PACKAGE, SPECIAL
Y83- MERCHANDISED PKG, TRANS AM
1SC- PACKAGE, OPTION 3
1SZ- ???
18P- WHEEL COLOR, CHARCOAL MET (91)
19Q- MOLDING COLOR (BLACK)
41U- PRIMARY COLOR, EXTERIOR BLACK
6ZX- SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
8NL- SPRING, COMPUTER SELECTED, REAR RIGHT HAND
82C- TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I- INTERIOR TRIM, MED DK GRAY (91)
829- SEAT BELT COLOR, MED DK GRAY (91)
9NL- COMPUTER SELECTED REAR RIGHTHAND SPRING
T96- LAMP, FOG
V73- ANTENNA, FIXED
1SZ- ???
#81
Car: 1988 Camaro IROCZ
Engine: 5.0L TPI LB9
Axle/Gears: 3.08 Posi
Here's mine
B6R: DECAL PACKAGE, 03
B84: ORNAMENTATION, EXTR MLDG. BODY SIDE
DE1: SUNSHADE, BACK WINDOW
D35: MIRROR, OUTSIDE REAR VIEW
D7L: GEAR, SPEEDO DRIVEN
E7Z: KEY, SPEEDOMETER (DELETE)
E9Z: SPEEDOMTER KEY (DELETE)
GU4: AXLE, REAR, 3.08 RATIO
J42: BRAKE SYSTEM, PWR. FRT DISC, RR DRUM, ALUMINUM
K68: GENERATOR, 105 AMP
LB9: ENGINE, GAS, 8 CYL 5.0L, TPI, HO
MM5: MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39: TRANSMISSION, MAN 5 SPD BORG WARNER, 77MM 2.95
NA5: EMISSION SYSTEM FEDERAL, TIER O
N64: WHEEL TIRE, SPARE, SPACE SAVER, ALUMINUM
N90: WHEEL, 15X7 ALUMINUM CAST 4.75 INCH BOLT CIRCLE
PB4: LOCK CONTROL, WHEEL
QYZ: TIRE ALL, P215/65R15/N BL/PE ST TL HWY
T93: TAIL STOP LAMP, SMOKED
T96: LAMP, FOG
UM6: RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS.
UQ1: RADIO PROVISIONS, FOR STERO
U79: SPEAKER SYSTEM, 4 DUAL FRT COAX, DUAL EXT RGE PKG
V73: ANTENNA, FIXED
WW1: APPEARANCE PACKAGE(WHITE), AERO #1
1SA: OPTION PACKAGE 01
11Q: MOULDING COLOR, WHITE
40U: PRIMARY COLOR, EXTERIOR, WHITE (91)
6ZW: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7ZW: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
72V: TRIM COMBINATION, CLOST, DK CARMINE (B)
72I: INTERIOR TRIM, DK CARMINE (91)
729: SEAT BELT COLOR, DK CARMINE (91)
89A: STRIPE COLOR, ACCENT, TWO TONE, RED/LT GRAY (91)
9NL: COMPUTER SELECTED REAR RIGHT HAND SPRING
BCCC WA L8554 U8554 72B
(BASE COAT, (WHITE) (WHITE) (INTERIOR, DK CARMINE)
CLEAR COAT)
T96: LAMP, FOG
V73: ANTENNA, FIXED
CLEAR COAT)
#82
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Might as well throw my 1990 GTA RPO's in
AJ3 Restraining System, Front Seat Inflatable.
AN4 Restraint Provisions, Child
AQ9 Ultima Seats, Passenger and Driver, Reclining
AU3 Lock, Side Door, Electric
A31 Window, Electric Control
A90 Lock, Rear Compartment Lid, Remote Control, Electric Release
BC8 Ornamentation, Interior Door Pockets
B2L Engine Package V8 5.7L PFI
B84 Body side moldings
C49 Defogger, Rear Window Electric
C60 HVAC System, Air Conditioner, Manual Control
DC4 Mirror, I/S R/V tilt, Dual Reading Lamps
DG7 Mirror, Outside LH & RH, Remote Control, Electric, Painted
D42 Rear Compartment Security Cover
D5X Spedometer Driven Gear
D8F Speed Sensor
D81 Rear Aero Wing Spoiler
E5Z Speedometer Adapter (delete)
E9Z Speedometer Key
FE2 Suspension System, Touring ride & handling
GU5 Axle, Rear 3.23 Ratio
G80 Differential, Limited slip
IL2 Trim, Interior Design
JG1 Aluminum drive shaft
J65 Brake System, Power, Front and Rear Disc
KC4 Engine Oil Cooler
K05 Heater, Engine Block
K34 Cruise Control, Automatic Electronic
K68 Generator, 105 Amp
L98 V8 - 350 CID (5.7 litre) Tuned Port Injection
MD8 Transmission Automatic Hydra-Matic 4L60
MX0 Transmission - Automatic O/D (Merchandising Option)
NA5 Federal Emission System
NP5 Steering Wheel, Leather wrapped
N10 Dual Exhaust
N64 Aluminum spare wheel with space saver spare tire
PW7 Diamond Spoke Aluminum Wheels 16x8"
QLC Tire, P245/50ZR16
R7K Folding rear seat
T61 Daytime Running Lamps
T93 Tail and Stop lamps, Smoked Lens
T96 Fog Lamps
UB3 Instrument Cluster, Speedo, Trip Odometer, Tach, Oil press, Eng Temp, Volts
UQ1 Stereo Radio Installation Provisions
UX1 UX1 - Radio, AM/FM Stereo Cassette, Equalizer, Clock, ETR
U19 Metric (Canadian) Instrumentation
U62 Speaker System 4, Dual Coaxial Front, Dual Coaxial Rear
U75 Antenna, Power
VAN Assembly plant Van Nuys, Calif.
VK3 License Plate, Front Mounting Package
V73 Vehicle statement US/Canada
WS4 Trans Am Package
WS6 Performance Package, Special
WW8 Aero package #8 (Bright Red)
W62 Aero Package - Rear fin, Ground effects, Front air dam
Y84 Merchandised Package - Trans Am GTA
Z31 Advanced Price Sheet
Z49 Canadian Modifications
1SA Option Package 01
52P Wheel color, Gold Metallic
661 Interior trim Medium Beechwood
662 Trim Combination, Leather, Med Beechwood
669 Seat belt color, Medum Beechwood
81Q Molding Color - Bright Red
81U Primary Color Exterior - Bright Red
D8F Speed Sensor
E9Z Speedometer Key
N10 Dual Exhaust
T96 Fog Lamps
U75 Antenna, Power
#83
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
I wish I could but some dumb-azz removed the sticker from the console. I've been looking for years to get one but no one does it anymore. PHS can only get an invoice which is not complete. Any hints?
#84
Did you look in the trunk side compartment? My sticker was in the hatch area.
#85
Community Administrator
On the 1992 Trans Am Convertible, such as watajob shows to own, the SPID was located in the center console wall. It differs from the hardtop/T-Top ThirdGens of the same year as those was located on the inside of the trunk compartment lid.
You could probably go to your dealership and pull up a list of RPO codes based from your VIN, as you could do that for approximately 1990 and newer ThirdGens.
#86
Car: 92 T/A 'vert
#89
Car: 1987 Camaro IROC Z-28
Engine: 305 T.P.I.
Transmission: 700 R4
These are the RPO Codes for the camaro i just got.
AM3 : SEAT, FRT BENCH, 2 PASS, CTR ARM REST
AR9 : RECLINING FRONT BUCKET SEATS
A31 : WINDOW, POWER OPERATED, ALL DOORS
B2L : PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B3W : INTERIOR. BLACK
B34 : COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B4Z : IROC PACKAGE
B48 : TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B91 : ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
DE1 : SUNSHADE, BACK WINDOW
D34 : MIRROR, VISOR VANITY
D6M : GEAR, SPEEDO DRIVEN
E7Z : KEY, SPEEDOMETER (DELETE)
L98 : 5.7 LITER V8 TPI ENGINE
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NN5 : EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL
NP5 : STEERING WHEEL, LEATHER WRAPPED
TR9 : LAMP, GROUP
UQ1 : RADIO PROVISIONS, FOR STEREO
UX1 : RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
U26 : LAMP, INTR, ENG COMPT, COURTESY
U75 : ANTENNA, POWER, RADIO
U79 : SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
YA7 : EMMISSION TEST, REQ. FOR CALIFORNIA
YS1 : SEAT,RR CUST
1AZ : CUSTOMER ORDERED VEHICLE
1SC : OPTION PACKAGE 03
15P : WHEEL COLOR SILVER METALLIC (91)
19C : TRIM COMBINATION, CLOTH, BLACK (C) (91)
199 : SEAT BELT COLOR, BLACK (91)
74Q : MOLDING COLOR, FLAME RED MET (91)
74U : PRIMARY COLOR, EXTERIOR, VICTORY RED (91)
8NL : COMPUTER SELECTED, REAR, LEFT HAND SPRING
86A : STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
B4Z : IROC PACKAGE
TR9 : LAMP, GROUP
YS1 : SEAT,RR CUST
#90
Car: Drive..94 Suburban, building 82 Z28
Transmission: Turbo 350
These are the codes from the invoice for my 82
A01 Tinted Glass
A31 Power Windows
BX5 Black Roof Drip Mldg
B32 Color Keyed Floor Mats-Front
B33 Color Keyed Floor Mats-Rear
B93 Door Edge Guards
CD4 Intermittent Windshield Wpr Sys
C49 Electric Rear Window Defogger
K35 Auto Speed Control W/Resume Spd
LG4 5.0 Liter 4-Bbl - V8
MX1 Automatic Transmission
N33 Comfortilt Steering Wheel
QYH P215/65R-15 S/B Rad W/Ltr
TR9 Auxiliary Lighting
TT5 Halogen Hi-Beam Headlamps
YE4 AM/FM St Rad W/St Cas TP & ERSS
Z28 Camaro Z28 Sport Coupe
78L Maroon Metallic
79R VRR2 Maroon Vinyl Bucket
This is the info I received from the GM Archive.
A01 Tinted Glass
A31 Power Windows
78L Maroon Metallic
#91
Engine: 2.7L V6
Axle/Gears: 4.41
I've got 2 sets here, one was the factory console in the 88 (well, at least the guy did SOMETHING right leaving the factory console/RPO sticker!), and the other was on the back of another console lid I found in it as well.
88 IROC-Z28, 1G1FP21E5JL114XXX:
AR9: European style reclining front bucket seats
B6R: Decal Package #3
C41: Heater with fan
C49: Rear hatch defroster
D34: Passenger's side vanity visor mirror (I think)
D35: Mirror, door outer
D7L: Speedometer driven gear
D80: Rear panel spoiler (3 piece)
D88: Sport stripe decal
E5Z: Speedometer adapter delete
E7Z (not in the VSS decoder): Transmission-mounted VSS delete
E9Z: Speedometer key delete
FE2: Ride/Handling suspension system
GU4: 3.08:1 rear end gear ratio
J50: Power assisted brakes with rear drums
K99: 85A CS130 alternator
LO3: 5.0L 305CI SBC, TBI, 170HP 255TQ
MM5: Borg-Warner WC T5 transmission provisions
M39: WC T5, 2.95:1 1st gear
NA5: Federal Emissions standards
NP5: Leather wrapped steering wheel and shift ****
N90: 15x7 wheel, aluminum
P84: (again, not in the RPO decoder) Going to assume this is for the ignition key lock mechanism in the non-tilt column... I hate that thing!
QYZ: 215/65/15 tires
T93: Smoked tail lamps (but neither of them are and nor are they a pair!)
T96: Lamps, fog
UM7: AM/FM stereo with ETR
UQ1: Provisions, radio
U79: Extended range 4-speaker stereo system
VAN: Van Nuys, CA final assembly plant
VK3: Mount, front license plate package
V73: Antenna, fixed
WW3: Aero appearance package, #3
W62: Aero ornamentation package
Z28: Special performance package
1SA: Accent stripe, medium gray metallic
16P: Wheel color, white
6DB (yes, it's a B, as it is on the spring tags): Spring, computer selected, Front, LH
7DB: Spring, computer selected, Front RH
72B: Interior, dark Carmine Red
72I: (same definition as above?)
729: Color, seat belts, dark Carmine Red
8NL: Spring, computer selected, Rear, LH
87U: Exterior color, Gunmetal Gray Metallic
89A: Accent stripe, 2-tone, red and light gray
9NL: Spring, computer selected, Rear, RH
T96: Lamps, fog
V73: Antenna, fixed
#92
Engine: 2.7L V6
Axle/Gears: 4.41
Second set, I'm going to assume this is an 87 Camaro Sports Coupe as I haven't found anything saying it's not. Don't know ANYTHING about this car other than there are a few parts from it I took out of the 88 IROC, all interior.
1G1FP21S9HN134XXX:
AR9: Seats, European style, Front, reclining
A01: Windows, tinted
C49: Defroster, rear hatch
C60: Air conditioning, manual
D35: Mirror, outside door
D6H: Speedometer driven gear
D86: Paint, Deluxe, 2-tone
D98: Stripe, Accent
E5Z: Adapter, Speedometer, Delete
E7Z: VSS, transmission mounted, Delete
E9Z: Key, speedometer, Delete
GU6: 3.42:1 Rear axle gear ratio
J50: Brakes, power assisted, with rear drums
K60: 100A alternator
LB8: 2.8L GM Corporate RWD 60* V6, 135H 160TQ
MD8: THM-700R4 automatic transmission
MX0: Provisions, automatic transmission
NA5: Emissions, Federal
NK3: Steering wheel, simulated leather
NOD: Norwood, OH final assembly plant
PC5: Wheel, styled, 15x7
P06: (wheels?)
P20: Hubcaps, Styled
QYZ: P215/65/15 tires
UM6: Stereo, cassette, auto reverse
UQ1: Provisions, stereo
U79: Speaker system, dual extended range 4-speaker
V73: Antenna, fixed
YT9 (not in the RPO decoder but in the master list floating around): Package, Fleet Incentive (don't know what that means...)
1AY: Modification, stock order
1SA: Package, option, #1
50A (not in RPO decoder): Stripe, accent, Doeskin tan
51U: Exterior color, sedona tan
6XR: Spring, computer selected, Front, LH
62B: Interior, cloth, Lt Saddle tan
62I: Trim, Interior, Lt Saddle tan
629: A little help here, guys? It's not in the Master RPO list OR the decoder!
7XR: Spring, computer selected, Front, RH
8UX: Spring, computer selected, Rear, LH
87L: Exterior color, Secondary, Gunmetal gray metallic
9UX: Spring, computer selected, Rear, RH
1G1FP21S9HN134XXX:
D98: Stripe, Accent
P06: (wheels?)
V73: Antenna, fixed
#93
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
AR9-SEAT FRT BKT, DELUXE
AU3-LOCK CONTROL SIDE DR, ELEC
A01-GOT R WINDOW TINTED ALL, SHADED WINDSHIELD
A31-WINDOW POWER OPERATED, ALL DOORS
A90-LOCK CONTROL RR CMPT LID, REM CONT ELEC RELEASE
B34-COVERING FRT FLOOR MATS, CARPETED INSERT
B35-COVERING REAR FLOOR MATS, CARPETED INSERT
B84-MOLDING B/S EXTERIOR
C60-HVAC SYSTEM AIR CONDITIONER FRT, MAN CONTROLS
D35-MIRROR O/S LH, REMOTE CONTROL, RH MANUAL CONTROL, COLOR
D81-SPOILER RR, AERO WING
D88-DECAL STRIPE, SPORT
E5Z-ADAPTER SPEEDO - DELETE
E7Z-SENSOR VEH SPD - DELETE
E9Z-KEY SPEEDO - DELETE
GU4-AXLE REAR 3.08 RATIO
J50-BRAKE SYSTEM PWR
K34-CRUISE CONTROL AUTOMATIC, ELECTRONIC
K60-GENERATOR 100 AMP
L03-ENGINE GAS, 8 CYL, 5.0L, TBI
MM5-MERCHANDISED TRANS MAN 5 SPD PROVISIONS
NB2-EMISSION SYSTEM CALIFORNIA, TIER 0
NK3-STEERING WHEEL SPORT, SOFT RIM, SIMULATED LEATHER
N33-STEERING COLUMN TILT TYPE
N90-WHEEL
P13-CARRIER SIDE MOUNTED, SPARE WHEEL
UM7-RADIO AM/FM STEREO, SEEK/SCAN, CLOCK, ETR
UQ1-RADIO PROVISIONS, AM/FM STEREO
U79-SPEAKER SYSTEM 4, DUAL FRT COAX, DUAL EXT RGE PKG SHELF
VAN-PLANT CODE VAN NUYS, CA, USA
VG8-VEHICLE LABEL, NOTICE TO BUYER
VK3-LICENSE PLATE FRONT FRT MOUNTING PKG
V73-VEHICLE STATEMENT USA/CANADA
WW2-APPEARANCE PACKAGE ACCENT #2
W62-EQUIPMENT GTO PERFORMANCE PACKAGE
YA7-TEST EMISSION, CALIFORNIA ASSEMBLY LINE
YF5-CERTIFICATION EMISSION, CALIFORNIA
1AY-ORDER MODIFICATION STOCK
1SC-PACKAGE OPTION 03
16P-WHEEL COLOR BRIGHT WHITE (96)
41U-PRIMARY COLOR EXTERIOR, BLACK (02)
6XU-COMPONENT FRT LH COMPUTER SEL SUSP (6XU)
7XU-COMPONENT FRT RH COMPUTER SEL SUSP (7XU)
8UX-COMPONENT RR LH COMPUTER SEL SUSP (8UX)
9UX-COMPONENT RR RH COMPUTER SEL SUSP (9UX)
N90-WHEEL
#94
Car: '83 Z28
Checked the window sticker of my '83 Z28 and here's what I got.
A01 - Tinted glass
A90 - Power hatch release
B34 - Front carpet mats
B35 - Rear carpet mats
B84 - Body side moldings
CC1 - Removable glass roof panels
CD4 - Intermittent wiper system
C49 - Electric rear window defogger
D42 - Rear compartment cargo cover
G80 - Limited slip differential
LG4 - 5.0 Liter 4-BBL V8
MX0 - Automatic trans w/overdrive
N33 - Comfortilt steering wheel
QYH - P215/65R-15 S/B RAD W/LTR
TR9 - Auxiliary lighting
YE4 - EL TN AM/FM ST w/CASS,CLK,ERSS
Z28 - CAMARO Z28 SPORT COUPE
19L - BLACK
60C - FQQ2 SAND GRAY CUS CLOTH BUCKET
A01 - Tinted glass
19L - BLACK
#95
Car: 85 Camaro IROC-Z
Engine: original 305 TPI
Transmission: 700R4 Auto
i have GU6 but dont have posi
AC3 AG9 AM9 AR9 AU3 AO1 A31 A90 B51 B18 B2G B3W B34 B35 B4Z B84 B9K B91 B94 B97 CC1 CD4 C25 C49 C60 DG7 DK6 DO2 D34 D42 D6H D80 D88 E5Z E72 E9Z FE2 GC5 GC6 GU6 G80 J65 K34 K90 LB9 MD8 MXO NA5 NK3NOD N33 N65 N33 N65 N96 QD2 TR9 TT4 T63 T93 T96 UA1 UE8 UP8 UX1 UO5 U21 U25 U26 U29 U75 U79 VK3 V73 YE3 YE2 YR2 YS2 YT1 YT9 Z28 1AZ 19C 19D 199 6ZW 7ZW 75L 75U 8NN 86A 86P 9NN
#97
#98
1 Post
Car: 1986 sports coupe, 1984 F41
Engine: 3.8L Turbo SFI, stock 305
Transmission: 700 R4, 700 R4
Axle/Gears: 3.42:1, 3.08:1
Here's mine, 1986 sports coupe V6.
AR9- SEAT - FRT-BKT european style PASS A DRIVER RECI
A01- WINDOW, TINTED, ALL SHADED
B9K- ???
C49- DEFOGGER, RR WINDOW, ELECTRIC
DX5- STRIP, 3 SIDE
D35- MIRROR, OUTSIDE REARVIEW
D6H- GEAR, SPEEDO DRIVEN
D80- SPOILER, RR END PNL
E5Z- SPEEDOMETER ADAPTOR (DELETE)
E7Z- code not found
E9Z- SPEEDOMETER KEY (DEELETE)
GA3- code not found
GA4- code not found
GU6- AXLE, REAR, 3.42 RATIO
J50- BRAKE SYSTEM, POWER
K61- GENERATOR, 97AMP
LB8- ENGINE, GAS, 6CYL, 2.8, MPFI, V6 LONGITUDINAL
MD8- TRANSMISSION, AUTO, 4SPD, THM 700R4
MXO- MERCHANDISED TRANS, AUTO PROVISIONS, OD
NA5- EMISSIONS SYSTEMS, FEDERAL, TIER O
N0D- code not found
PC5- WHEEL, 15 x 7 STYLED
P06- code not found
P20- HUBCAPS, WHEEL STYLED
QYZ- TIRE ALL, 215/65R15 BL R/PE ST TL HWY
UP7- RADIO PROVISIONS, FOR MONO INSTRUMENTATION
U63- RADIO, AM MTR
VK3- LICENCE PLATE FRONT MOUNTING PKG
V73- ANTENNA, FIXED
YT9- ???
Z31- code not found
Z49- EXPORT, CANADIAN MODIF, MANDATORY BASE EQUIP
1AY- ???
13U- PRIMARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
19Q- MOULDING COLOR, BLK
41L- SECONDARY COLOR, EXTERIOR, BLACK (91)
6XR- SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7XR- SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
8PH- code not found
82B- TRIM COMBINATION, CLOTH, MED DK GRAY (91)
829- SEATBELT COLOR, MED DK GRAY (91)
9PH- code not found
96A- code not found
There's a few that the RPO decoder couldn't find, or just came up as ??? that I'd like to know what they mean. I was really hoping to find the F41 suspension option, but I guess it was disscontinued in '86. too bad.
B9K- ???
DX5- STRIP, 3 SIDE
E7Z- code not found
GA3- code not found
GA4- code not found
N0D- code not found
P06- code not found
U63- RADIO, AM MTR
V73- ANTENNA, FIXED
YT9- ???
Z31- code not found
1AY- ???
8PH- code not found
9PH- code not found
96A- code not found
#99
Engine: 2.7L V6
Axle/Gears: 4.41
B9K- ???
DX5- STRIP, 3 SIDE
E7Z- code not found
GA3- code not found
GA4- code not found
N0D- code not found
P06- code not found
U63- RADIO, AM MTR
V73- ANTENNA, FIXED
YT9- ???
Z31- code not found
1AY- ???
8PH- code not found
9PH- code not found
96A- code not found
B9K- ???
DX5- STRIP, 3 SIDE
E7Z- code not found
GA3- code not found
GA4- code not found
N0D- code not found
P06- code not found
U63- RADIO, AM MTR
V73- ANTENNA, FIXED
YT9- ???
Z31- code not found
1AY- ???
8PH- code not found
9PH- code not found
96A- code not found
Seriously doubtful you would find the F41 on a V6.
#100
1 Post
Believe it or not, the F41 option was available on V6 cars, not common, but there are some out there. I did also see the that NOD is for Norwood Ohio, in a previous post. Thanks though!
