Members post your RPO codes!
#151
Re: Members post your RPO codes!
Here is my "build" sheet, I think. I will try to get all of the RPO codes under the console lid and list them, but the car isn't with me right now, its hiding from the rain. If you can tell me anything from this sheet, please do. Thanks!
#152
#153
19T = Black VINYL Top according to the build sheet or order sheet I found in my car. Just FYI. But true, my car is a convertable so you are not wrong.
#154
RPO codes from my 1987 IROC-Z Convertable
#155
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
UB3 CLUSTER,INSTRUMENT(OIL,COOLANT TEMPERATURE,VOLTMETER,TACHOMETER,TRIP ODOMETER)(USED WITH BERETTA GT PKG Z21) GA(UB3)
UN6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK(EXPORT) STEREO CASSETTE(UN6)
UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1)
UX6 SPEAKER SYSTEM,FRONT DUAL DASH MOUNTED SPKR SYS(UX6)
VAN PLANT CODE VAN NUYS, CA, CPC VAN NUYS,CA PLANT CODE(VAN)
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VN9 FLEET PROGRAM - GUARANTEED 100% REPURCHASE
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
Y86 CAMARO "RS" PACKAGE(MERCHANDISING OPTION) RS PKG(Y86)
1AA SALES INCENTIVE - RETAIL AMENITIES -- DELETE
1SC PACKAGE-OPTION 03 (1SC)
1SZ PACKAGE OPTION- (1SZ)
10Q MOLDING COLOR,ARCTIC WHITE (10Q)
10U EXTERIOR COLOR,ARTIC WHITE (10U)
40P WHEEL COLOR,WHITE (40P)
41T VINYL TOP COLOR,BLACK (41T)
6XT COMPONENT FRT LH COMPUTER SEL SUP (6XT) SUSP(6XT)
7XT COMPONENT FRT RH COMPUTER SEL SUP (7XT) SUSP(7XT)
8UY SPRING-COMPTR SELECT RR LH SUSP(8UY)
82B TRIM COMBINATION,CLOTH,MEDIUM DARK GRAY (82B)
82I INTERIOR TRIM,MEDIUM DARK GRAY (82I)
829 SEAT BELT COLOR - MED DK GRAY (829)
9UY SPRING-COMPTR SELECT RR RH SUSP(9UY)
AJ3 RESTRAINT SYSTEM,FRONT SEAT INFLATABLE DRIVER SI INFL RST SYS(AJ3)
AR9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,MANUAL RECLINING(EUROPEAN STYLE) MAN RECL FRT BKT ST,DELUXE(AR9)
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
A31 WINDOW,ELECTRIC OPERATED,SIDE ELEC SI WDO(A31)
B34 COVERING,FLOOR MATS,FRONT,CARPETED INSERT(COLOR COORDINATED) FRT CPT INS FLR MATS(B34)
B35 COVERING,FLOOR MATS,REAR,CARPETED INSERT(COLOR COORDINATED) RR CPT INS FLR MATS(B35)
B84 ORNAMENTATION,EXTERIOR,BODY SIDE MOLDING(USED WITH TROFEO SPORT COUPE WL3) BODY SI MLDG(B84)
C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60)
D3V GEAR-SPEEDOMETER DRIVEN (25513046) (D3V)
D35 MIRROR,O/S LH REM RH DIRECT CTL,PAINTED PAINTED O/S MIR(D35)
D8N SENSOR VEH SPD (10456088) (D8N)
E5Z ADAPTER - SPEEDO - DELETE
E9Z KEY - SPEEDO - DELETE
FE1 SUSPENSION SYSTEM,SOFT RIDE(USED WITH RS PACKAGE Y86) SOFT RIDE SUSP(FE1)
FLT SALES PROCESSING - OPTION
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
IPB TRIM,INTERIOR DESIGN (IPB)
J41 BRAKE SYSTEM,POWER,FRONT DISC,REAR DRUM(CAST IRON) CAST IRON FRT DISC/RR DRUM BRK SYS(J41)
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
K60 GENERATOR,100 AMPERE 100 AMP(K60)
LH0 ENGINE,3.1L(3.1T),V6(EXPORT) 3.1T(LH0)(EXPORT)
MD8 TRANSMISSION,AUTOMATIC 4-SPEED(THM700R4/4L60) 4-SPD A/TRANS(MD8)
MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0)
NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5)
NK3 STEERING WHEEL,SPORT,SOFT RIM,SIMULATED LEATHER SIMULATED LEATHER STRG WHL(NK3)
N90 WHEEL,15X7(CAST ALUMINUM) AL WHL(N90)
QPH TIRE ALL- P215/65R15/N BL R/PE ST TL AL2 (9591591) TIRE(QPH)
so what does the codes VN9, 1AA, E5Z, E9Z stand for im confused
#156
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
My 89 GTA
T96: LAMP, FOG
K68: GENERATOR,105 AMP
D42: SHADE, RR COMPT SECURITY
A31: WINDOW, POWER OPERATED, SIDE
82D: TRIM COMBINATION, CLOTH, MED DK GRAY ( D) (91 )
VK3: LICENSE PLATE, FRT MOUNTING PKG
T93: TAIL & STOP LAMP, SMOKED
K34: CRUISE CONTROL, AUT0MATIC, ELECTRONIC
D3Y: GEAR, SPEEDO DRIVEN
AU3: LOCK CONTROL, SIDE DR, ELEC
8NL: SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
VAN: ASSEMBLY PLANT, VAN NUYS, CA
TR9: LAMP, GROUP
KC4: COOLING SYSTEM, ENG OIL
DG7: MIRROR 0/S, LH & RH, REM CONT, ELEC, PAINTED
AQ9: SEAT, FRT PASS A DRIV, RECL
7ZX: SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
U75: ANTENNA, POWER, RADIO
J65: BRAKE SYSTEM, PWR, FRT & RR DISC
DE4: SUNSHADE, REMOVEABLE HATCH ROOF
AM9: SEAT, RR, SPLIT, BACK, FLDG
6ZX: SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
U62: SPEAKER SYSTEM, DUAL COAXIAL
QLC: TIRE ALL, P245/50ZR16/N BL R/PE ST TL HW4
JG1: SHAFT, PROP, ALUMINUM
DC4: MIRROR I/S, R/V, TILT, DUAL READING LAMPS
AAA: 4-WAY MANUAL SEAT ADJUSTER
NK4: STEERING WHEEL, SPORT LEATHER W/ RADIO CONTROLS
FE2: SUSPENSION SYSTEM, RIDE HANDLING
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE
W62: ORNAMENTATION, AERO PACKAGE
UQ1: RADIO PROVISIONS, FOR STEREO
NA5: EMISSION SYSTEM, FEDERAL, TIER O
E9Z: SPEEDOMETER KEY (DELETE)
B20: ORNAMENTATION, INTR, LUXURY
WW1: APPEARANCE PACKAGE(WHITE), AERO #l
UK3: ELECTRONIC SYSTEM, ACCESSORY CONT
MXO: MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
E5Z: SPEEDOMETER ADAPTER (DELETE)
B2L: PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
9NL: COMPUTER SELECTED REAR RIGHTHAND SPRING
WS6: PERFORMANCE PACKAGE, SPECIAL
UF6: LAMP, INTR, CONSOLE, COURTESY
MD8: TRANSMISSION, AUTO 4 SPD, THM 700 R4
D9B: SENSOR, VEH SPD
BC8: ORNAMENTATION, INTR, DR MAP POCKETS
829: SEAT BELT COLOR, MED DK GRAY (91)
WS4: MODEL CONVERSION, TRANS AM
UB3: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
L98: 5.7 LITER V8 TPI ENGINE
D81: SPOILER, RR, AERO WING
A90: LOCK CONTROL, RR COMPT LID, REM CONT ELEC RELEASE
821: INTERIOR TRIM (DARK MEDIUM GRAY)
V73: ANTENNA, FIXED
52P: WHEEL COLOR, GOLD MET (91)
U29: LAMP, INTR I/P, COURTESY
PW7: WHEEL, 16 X 8, ALUMINUM, DIAMOND SPOKE
ILD: TRIM, INTERIOR DESIGN
C60: HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
40U: PRIMARY COLOR, EXTERIOR, WHITE (91)
U25: LAMP, INTR, RR COMPT, COURTESY
N64: WHEEL & TIRE,SPARE, SPACE SAVER, ALUMINUM
G80: AXLE POSITRACTION, LIMITED SLIP
C49: DEFOGGER, RR WINDOW, ELECTRIC
11Q: MOULDING COLOR, WHITE
UT4: RADIO, AM/FM-ST CASS, AUTO NR, TOUCH CONTROL, STEERING WHL CONTROL
N10: EXHAUST SYSTEM DUAL
GW6: AXLE REAR, 3.27 RATIO
CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
Y84: MERCHANDISED PKG, GTA, TRANS AM
UT1: TONE GENERATOR, WARNING
R9R: Not Found (Error)
T96: LAMP, FOG
TR9: LAMP, GROUP
V73: ANTENNA, FIXED
#157
From the 88 V6... and the 87 Formula.
I just noticed going over the codes that both are 23U paint code. They are not both the same color! The Formy is a darker blue, and it def looks factory. Not sure what is going on here!
#158
I'll post mine tmrw. I won't be suprised if mine is the least optioned 91 firebird v8.
#160
Car: 84 Trans Am
Axle/Gears: 10 bolt 3.73 factory
My 84 trans am rpo codes some pretty cool codes
AAA 4 way maunual seat adjuster
AC3 Adjuster, Frt St, Power, 6 way bkt, driver
AK1 Deluxe belt and shoulder harness
AM9 seat, rr, split, back,fldg
AR9 seat, frt bkt, european style, pass a driver recl
AU3 lock control, slide dr,elec
A01 windows, tinted, all shades, w/s
A31 Windows, power operated, side
A90 Lock Control,rr compt lid, rem cont elec release
BV8 ornamentation, extr dr handle, lock cylinder
B20 ornamentation, intr, luxury
B34 covering, frt floor mats carpeted insert
B35 covering, rear, floor mats carpeted insert
B48 Trim Equipment, luggage compartment
B97 ornamentaion, ext mldg, lower accent
CC1 Roof Hatch, removable panels, glass
CD4 wiper system windshield, pulse
C60 HVAC system, Air Conditioner frt man controls
DG7 Mirror 0/s, lh rh, rem cont, elect, painted
D03 Paint, Process, waterbase
D1t Gear, speedo Driven
D27 Cover, RR compt, trunk stow
D42 Shade, rr compt security
D53 ornamentation, extr hwd applioue
D80 spoiler, rr end pnl
D85 stripe, body side lower accent
E5Z speedometer adapter delete
GT4 Axle rear, 373 ratio
G80 Axle positraction, limited slip
J65 brake system, pwr, frt rr disc
K19 reactor system, air induction
K22 Generator, 94 amp
K34 cruse control, automatic, electronic
L69 Engine, gas, 8 cyl, 4bbl, HO
MD8 transmission, auto, 4 spd, thm 700 r4
MXO merchandised, trans, auto provisions, o/d
NB1 emission system, closed loop
NB2 emission system, california, tier o
N33 Steering column, tilt type
N65 wheel tire, spare, space saver, steel
N78 Wheel, I4x6, AL, hub cap, wheel nuts
QYH tire all, P215/65/r15 wol r/pe st tl hwy
TR9 lamp, group
T93 tail stop lamp, smoked
UP8 stero radio installment provisions
UT1 Tone generator, warning
UU6 Radio, AM/FM stereo, seek/scan auto rev cass
U21 cluster, inst, oil, cool temp, volts, tach
U23 cluster, inst, trim odom
U25 lamp, intr, rr compt, courtesy
U27 lamp, intr, I/p compt, courtesy
U29 lamp, intr I/P, courtesy
U75 Antenna power, radio
U81 speaker system, rr, dual
VAN assembly plant, Van Nuys, CA
VJ9 Label, emission, compliance, california
VK3 licence plate, frt mounting pkg
V73 atenna, fixed
WS4 Model conversion, TRANS AM
WS6 performance package special
W62 ornamentation, areo package
YR1 seat, frt custom
YS1 seat rr custom
YT1 build up dr qtr
YT9 ???
Y06 Ring gear, 9.50 in, saginaw, (s.p.o)
55A stripe color, accent, gold (91)
6ZW spring, computer selected, front, left hand
64C trim combination, cloth, lt beige (C) (92)
64I interior trim, light beige (i) (92)
649 seat belt color, light beige (9) (92)
7ZX spring, computer selected, front, right hand
75L secondary color, exterior, brilliant red bet (91)
75U Primary color, Exterior Brilliant red met (91)
8NM spring, computer selected, rear, left hand
9NB spring, computer selected, rear, right hand
TR9 lamp, group
V73 atenna, fixed
YS1 seat rr custom
YT1 build up dr qtr
YT9 ???
#161
Car: 1984 Pontiac trans am
Engine: stock 305 h.o.
i dont know why but i cant find a few codes out of my rpo if anyone can help it will be gretly appreciated yt9,59l,55p,wy6,ws5 and e6n my car is a 1984 trans am
#162
87 IROC:
74Q: MOLDING COLOR, FLAME RED MET (91)
74U: PRIMARY COLOR, EXTERIOR, VICTORY RED (91)????????????
86A: STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
What's up with the 74U? Is that correct?
Scott Moyer's is an 87 like yours and his window sticker says 74U Dark Red Metallic: http://www.users.uswest.net/~smoyer/...dowsticker.jpg
Also Camaro White Book says 74 for dark red-- Even on an 88 IROC like mine.
#163
try putting the others in the search bar
#164
AC3 PWR ST ADJ
AG9 POWER SEAT, DRIVER SIDE (ADJUSTER, SEAT, POWER, 6 WAY)
AR9 STD BKT ST (SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL)
AU3 ELEC DR LOCKS
A01 ALL TNTD GLAS
A31 POWER WDO
A90 POWR DECK LID
B18 CUST INTERIOR
B2L 5.7 LITER T.P.I. V8, 350CI, 230HP
B34 FRT FL MATS
B35 RR FL MATS
B48 LUGG COMPT TR / DELUXE LUGGAGE COMPARTMENT TRIM
B6R (DECAL PACKAGE, 03)
B84 BODY SIDE MLD
CC1 HATCH ROOF / REMOVABLE GLASS RF PNLS W/LOCKS
CD4 WASHER SYSTEM
C49 ELEC RR DEFOG
C60 AIR COND
C95 (LAMP, INTR, ROOF, COURTESY AND DUAL READING)
DG7 ELEC O/S MIR
D27 COVER / LOCKING REAR STORAGE COVER
D34 VISOR MIRROR
D42 (SHADE, RR COMPT SECURITY)
D6E (GEAR, SPEEDO DRIVEN)
D80 RR SPOILER
D88 SPORT STRIPES
E5Z (SPEEDOMETER ADAPTER (DELETE))
E7Z (KEY, SPEEDOMETER (DELETE))
E9Z (SPEEDOMETER KEY (DELETE))
FE2 (SUSPENSION SYSTEM, RIDE HANDLING)
GH3 (AXLE REAR, 2.77 RATIO)
G80 POSI AXLE
JG1 (SHAFT, PROP, ALUMINUM)
J65 WHL DISC BRA / POWER DISC FRONT & REAR BRAKES
KC4 COOL SYS OIL / ENGINE OIL COOLER
K34 CRUISE CONTRO
K68 105AMP GEN
L98 ENGINE
MD8 4 SPD AUTO TRA
MX0 AUTOMATIC TRANS W/OVERDRIVE
NA5 STD EMISSION
NP5 LEATHER ST WL
N33 TILT STEERING WL
N64 SPACE SVR TIR
N96 CAST ALUM WHL (WHEEL, 16x8, CAST ALUMINUM)
PB4 WHL LOCKS (LOCK CONTROL, WHEEL)
QDZ 245/50VR16 BW / P245/50VR-16 S/B RADIAL B/WALL
TR9 LAMP GROUP
TT4 HALOGEN LAMPS
T93 BLK TAIL LAMPS (TAIL & STOP LAMP, SMOKED)
T96 FOG LAMPS
UQ1 ST RADIO PROV
UQ4 BOSE 4 SPKRS
UU8 AMFM DOL CAS / DELCO-BOSE MUSIC SYS-ELEC TUNED AM/FM STEREO RADIO W/ SEEK & SCAN, CASS TAPE & DIGITAL CLK
U25 LUG COMP LAMP
U26 HOOD LMP
U29 COURTESY LITE
VAN (ASSEMBLY PLAN, VAN NUYS, CA)
VK3 FRT LIC MTG
V73 (vehicle statement usa/canada)
WW6 (APPEARANCE PACKAGE, AERO #6) (FLAME RED METALLIC firebird)
W62 (ORNAMENTATION, AERO PACKAGE)
YR1 CUST FRT SEAT
YS1 CUST RR ST
YT1 CUST DR & QTR
Z28 SPEC PERF PKG / CAMARO A28 SPORT COUPE
1AY (Stock orders processing option (DEALER ORDERED CAR))
1SC OPTION / IROC OPTION PACKAGE #3 includes: iroc-z performance package, air conditioning, tinted glass, comfortilt steering wheel, front & rear carpet floor mats, intermittent windshield wiper system, power door locks, power windows, power hatch release, body side mldgs, elec speed control w/resume speed, auxiliary lighting, halogen hi/low-beam headlamps, six-way driver power seat, auto isrv mirror, elec twin remote sport mirrors, interior roof console & elec tuned am stereo, fm stereo radio w/sk & sc, cass tape w/search & repeat, graphic equalizer, digital clock and ERSS
15P (WHEEL COLOR SILVER METALLIC (91))
6ZW (SPRING, COMPUTER SELECTED, FRONT, LEFT HAND)
7ZW (SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND)
74Q (MOLDING COLOR DARK RED METALLIC)
74U DARK RED METALLIC
8NL (SPRING, COMPUTER SELECTED, REAR, RIGHT HAND)
82C (TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91))
821 (INTERIOR TRIM (DARK MEDIUM GRAY)
829 (SEAT BELT COLOR, MED DK GRAY)
89A (STRIPE COLOR, ACCENT, TWO TONE, BLACK/RED)
9NL (COMPUTER SELECTED REAR RIGHTHAND SPRING)
CCCC WA- L8748 U8748 82C
stuff in "()" is from online sources.
AU3 ELEC DR LOCKS
A01 ALL TNTD GLAS
A31 POWER WDO
A90 POWR DECK LID
B18 CUST INTERIOR
B34 FRT FL MATS
B35 RR FL MATS
B84 BODY SIDE MLD
CD4 WASHER SYSTEM
C49 ELEC RR DEFOG
C60 AIR COND
DG7 ELEC O/S MIR
D34 VISOR MIRROR
D80 RR SPOILER
D88 SPORT STRIPES
G80 POSI AXLE
K34 CRUISE CONTRO
K68 105AMP GEN
L98 ENGINE
MD8 4 SPD AUTO TRA
NA5 STD EMISSION
NP5 LEATHER ST WL
N64 SPACE SVR TIR
TR9 LAMP GROUP
TT4 HALOGEN LAMPS
T96 FOG LAMPS
UQ1 ST RADIO PROV
UQ4 BOSE 4 SPKRS
U25 LUG COMP LAMP
U26 HOOD LMP
U29 COURTESY LITE
VK3 FRT LIC MTG
YR1 CUST FRT SEAT
YS1 CUST RR ST
YT1 CUST DR & QTR
#165
Car: 1986 Pontiac Trans Am, White
Engine: 305 -4Bbl
Transmission: 5 Speed Borg Warner
Axle/Gears: 3.23:1
My 86 T/A RPO Codes
AAA : 4-WAY MANUAL SEAT ADJUSTER
AK1 : RESTRAINT SYSTEM, FRT, CTR, RR SEAT, FRT SHLDR, AK1 : DELUXE BELT AND SHOULDER HARNESS
AM9 : SEAT, RR, SPLIT, BACK, FLDG
AR9 : SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 : WINDOW, TINTED, ALL SHADED, W/S
A31 : WINDOW, POWER OPERATED, ALL DOORS
BV3 : ORNAMENTATION, INTR, I/P, BLACK
B20 : ORNAMENTATION, INTR, LUXURY
B34 : COVERING, FRONT, FLOOR MATS, CARPETED INSERT
B35 : COVERING, REAR, FLOOR MATS, CARPETED INSERT
B60 : DECAL PACKAGE, 01
B67 : CONTAINER, RADIO CASSETTE TAPES
B84 : ORNAMENTATION, EXTR MLDG, BODY SIDE
B87 : ORNAMENTATION, EXTR EMBLEM FENDER---DELETE
B97 : ORNAMENTATION, EXTR MLDG, LOWER ACCENT
CC1 : ROOF HATCH, REMOVABLE PANELS, GLASS
CD4 : WIPER SYSTEM WINDSHIELD, PULSE
C41 : HVAC SYSTEM, HEATER OUTSIDE AIR, WITH FAN
DK6 : CONSOLE ROOF, INTERIOR
D14 : ARM REST, FRT DR, RH & LH
D35 : MIRROR, OUTSIDE REAR VIEW
D5R : GEAR, SPEEDO DRIVEN
D81 : SPOILER, RR, AERO WING
D88 : DECAL, STRIPE, SPORT
D9E : SENSOR, VEH SPD
E5Z : SPEEDOMETER ADAPTER (DELETE)
E9Z : SPEEDOMETER KEY (DELETE)
GU5 : AXLE REAR, 3.23 RATIO
J50 : BRAKE SYSTEM, POWER
K81 : GENERATOR, 66 AMP
LG4 : ENGINE, GAS, 8 CYL, 5.0L, 4BBL
MM5 : MERCHANDISED TRANS, MAN 5 SPD PROVISIONS
M39 : TRANSMISSION, MAN 5 SPD B0RG WARNER, 77MM, 2.95
NA5 : EMISSION SYSTEM, FEDERAL, TIER O
NK3 : STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
NOD: ASSEMBLY PLANT, NORWOOD, OHIO
N24 : WHEEL I5 X 7 ALUMINUM CAST, 5 INCH BOLT CIRCLE
N33 : STEERING COLUMN, TILT TYPE
QYZ : TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9 : LAMP, GROUP
T93 : TAIL & STOP LAMP, SMOKED
T96 : FOG LAMPS - FRONT
UF6 : LAMP, INTR, CONSOLE, COURTESY
UM6 : RADIO, AM/FM STEREO, SEEK/SCAN, AUTO REV CASS,
UP8 : STEREO RADIO INSTALLMENT PROVISIONS
UM7 : RADIO, AM/FM STEREO, SEEK/SCAN, CLOCK, ETR (BASE ON ALL MODELS)
UT1 : TONE GENERATOR, WARNING
U21 : CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U25 : LAMP, INTR, RR COMPT, COURTESY
U29 : LAMP, INTR I/P, COURTESY
U66 : SPEAKER SYSTEM, 4, DUAL FRT DASH MTD, DUAL EXTD RGE
VK3 : LICENSE PLATE, FRT MOUNTING PKG
V73 : VEHICLE STATEMENT, USA/CANADA
WS4 : MODEL CONVERSION, TRANS AM
WW1 : APPEARANCE PACKAGE(WHITE), AERO #l
W62 : ORNAMENTATION, AERO PACKAGE
YR1 : SEAT,FRT CUSTOM
YS1 : SEAT,RR CUST
YT1 : BUILD UP DR & QTR
YT9 : OPTION PACKAGE, FISHER FURNISHED PARTS
11Q : MOLDING COLOR, WHITE
40U : PRIMARY COLOR, EXTERIOR, WHITE (91)
6DB : SPRING, COMPUTER SELECTED, FRONT, LEFT HAND
7XY : SPRING, COMPUTER SELECTED, FRONT, RIGHT HAND
72C : TRIM COMBINATION, CLOTH, DK CARMINE ©
72I : INTERIOR TRIM, DK CARMINE (91)
729 : SEAT BELT COLOR, DK CARMINE (9) (91)
8NM : SPRING, COMPUTER SELECTED, REAR, LEFT HAND
80A : STRIPE COLOR, ACCENT, TWO TONE, RED/DK SAPPHIRE
84P : WHEEL COLOR, GRAY (91)
9NB : SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
I had to find these from online sources which is why there are 2 descriptions for some. I was disappointed to see that WS6 is not in there because the car has had WS6 center camps on the wheels since I found it. Oh well. It runs and drives nice but I can't wait to get into it to fix it up since I had to rescue it from sitting in NH with multiple water leaks.
TR9 : LAMP, GROUP
YS1 : SEAT,RR CUST
#166
Car: 87 Z/28
Engine: 5.0L
Axle/Gears: 9 Bolt posi
here's mine. 87 Z28 (Canada)
Ar9: SEAT ASM,FRT BKT RECL(EUROPEAN STYLE)
A01: WINDOW,DEEP TINTED GLS(ALL WDOS)
A31: WINDOW,ELEC CONT
A90: LOCK,RR COMPT LID,REM CONT,ELEC REL
B34: MATS,FRT FLR(CARPET INSERT)
B35: MATS,RR FLR(CARPET INSERT)
B9K: MOULDING DOOR EDGE GUARD
B94: EMBLEM,BODY
B97: MOLDING,EXTR LWR ACCENT
Cc1: HATCH ROOF,REMOVABLE GLS PNLS
Cd4: WIPER SYSTEM WINSHIELD, PULSE
C41: HEATER,W/DEFR,O/S AIR
C49: DEFOGGER,RR WDO ELEC
D08: PAINT,HIGH-GLOSS FINISH
D34: MIRROR,VISOR VAN
D35: MIRROR,O/S RR VIEW(CUST)
D6F: SPEEDOMETER DRIVEN GEAR
D80: SPOILER,DECK LID RR
D88: STRIPE,HOOD & DECK Lib(PASSENGER CAR)
E7Z: KEY, SPEEDOMETER (DELETE)
F41: SUSPENSION,SPL H.D. -FRT & RR
GU5: AXLE,RR 3.23 RATIO
J50: BRAKE SYSTEM,VAC PWR
K05: HEATER,ENG BLOCK
K99: GENERATOR,85 AMP
LG4: ENGINE, 305 C.I.D. V8 (305H)
MD8: TRANSMISSION,4-SPD AUTO (THM700R4)
MX0: MERCHANDISING OPTION ONLY-DO NOT CATALOG
NM5: EMISSION SYSTEM,NON-CLOSED LOOP(CANADA
NP5: WHEEL,STRG (LEATHER WRAPPED)
N33: COLUMN,STRG(TILT TYPE)
N90: WHEEL,15 X 7(CAST ALUM)
PB4: LOCK KIT,ALUM WHL
P20: CAP,STYLED WHL HUB
QYH: Tires, P215/65R15 White Letter
TR9: LAMP GROUP
TT4: HEADLAMPS,TUNGSTEN QUARTZ HALOGEN
T93: LAMP.TAIL & STOP(SPECIAL)
T96: LAMP.TAIL & STOP(SPECIAL)
UA1: BATTERY,H.D.
UM6: HADIO,AM/FM STEREO CASSETTE ETR
UQ1: RADIO,STEREO INSTL PROVISIONS
U21: CLUSTER,I/P(CLNT TEMP,VOLTS,TACH)
U25: LAMP,LUG COMPT
U26: LAMP,ENG COMPT
U29: LAMP,I/P CTSY
U75: ANTENNA,PWR(CHROME)
U79: SPEAKER,4 DUAL FRT COAX,DUAL EXTD RR
VK3: MOUNTING,FRT LIC PLT
V73: ANTENNA, FIXED
X06: CANADIAN GROUP
YT9: OPTION PACKAGE, FISHER FURNISHED PARTS
Z28: PERFORMANCE PACKAGE,SPECIAL
Z31: ADVANCED PRICE SHEET, CANADIAN MODELS
Z49: BASE EQUIP MODIFICATIONS
1AY: Stock Orders Processing Option (DEALER ORDERED CAR)
1PV: COMPONENTS OF Z28 PERFORMANCE PACKAGE(CHEV)
13U: : PRIMARY COLOR, EXTERIOR, BRIGHT SILVER MET (91)
6ZW: SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
7ZW: SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
72B: TRIM COMBINATION, CLOTH, DK CARMINE (B)
72I: INTERIOR TRIM, DK CARMINE (91)
729: SEAT BELT COLOR, DK CARMINE (9) (91)
82P: WHEEL COLOR SATIN SILVER
84A: STRIPE COLOR ACCENT, TWO TONE, DK GARNET/LT GRAY (93)
9NL: SPRING, COMPUTER SELECTED, REAR, RIGHTHAND
B94: EMBLEM,BODY
TR9: LAMP GROUP
UA1: BATTERY,H.D.
U25: LAMP,LUG COMPT
U26: LAMP,ENG COMPT
U29: LAMP,I/P CTSY
V73: ANTENNA, FIXED
X06: CANADIAN GROUP
#167
Bit of a fun story. Years ago my daughter got a hardcover book on the morning of her 16th birthday. She sat there dumbfounded until she opened it and a key fell out onto her lap. Looked across the street and saw a black 1986 IROC with a big red bow on it. Which started her love for IROCs. In time the car met a tragic end but we swore "one day...". Well, that day has come. Just bought this one. Two owner, clean Carfax, 1987 IROC, 5.7 TPI, 4-wheel disk brakes, posi, T-Tops, Bright Blue on gray custom interior. A little worn but all original everything (codes, dates). Console lid RPO decode:
RPO DESCRIPTION
AR9 SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
A01 WINDOW, TINTED, ALL SHADED, W/S
B18 ORNAMENTATION, INTR, DELUX
B2L PERFORMANCE PACKAGE & ENGINE PACKAGE V8 5.7LPFI
B4Z IROC PACKAGE
B94 FENDER EMBLEM, Z28
B97 ORNAMENTATION, EXTR MLDG, LOWER ACCENT
C49 DEFOGGER, RR WINDOW, ELECTRIC
C60 HVAC SYSTEM, AIR CONDITIONER FRT MAN CONTROLS
D08 PAINT, HIGH GLOSS FINISH
D34 MIRROR, VISOR VANITY
D35 MIRROR, OUTSIDE REAR VIEW
D6M GEAR, SPEEDO DRIVEN
D80 SPOILER, RR END PNL
D88 DECAL, STRIPE, SPORT
E5Z SPEEDOMETER ADAPTER (DELETE)
E7Z KEY, SPEEDOMETER (DELETE)
E9Z SPEEDOMETER KEY (DELETE)
FE2 SUSPENSION SYSTEM, RIDE HANDLING
GW6 AXLE REAR, 3.27 RATIO
G80 AXLE POSITRACTION, LIMITED SLIP
J65 BRAKE SYSTEM, PWR, FRT & RR DISC
KC4 COOLING SYSTEM, ENG OIL
K68 GENERATOR,105 AMP
L98 5.7 LITER V8 TPI ENGINE
MD8 TRANSMISSION, AUTO 4 SPD, THM 700 R4
MX0 MERCHANDISED, TRANS, AUTO PROVISIONS, O/D (700-R4)
NA5 EMISSION SYSTEM, FEDERAL, TIER O
NOD ASSEMBLY PLANT, NORWOOD, OHIO
NP5 LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
N65 WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
N96 WHEEL, 16 X 8, CAST ALUMINUM
PB4 LOCK CONTROL, WHEEL
P20 HUBCAPS, WHEEL, STYLED
QDZ TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
T93 TAIL & STOP LAMP, SMOKED
T96 LAMP, FOG
UQ1 RADIO PROVISIONS, FOR STEREO
UX1 RADIO, AM/FM STEREO CASSETTE EQUALIZER
U21 CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
U79 SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
VK3 LICENSE PLATE, FRT MOUNTING PKG
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
YS1 SEAT, REAR CUSTOM
YT1 BUILD UP DR & QTR
YT9 OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 MERCHANDISED PKG, SPECIAL PERFORMANCE
1AZ Order Modification, Orders Sold (or CUSTOMER ORDERED VEHICLE)
1HV COMPONENTS OF IROC-Z PERFORMANCE PKG (CHEV)
1SA PACKAGE, OPTION 01
15P WHEEL COLOR SILVER METALLIC (91)
23U PRIMARY COLOR, EXTERIOR, BRIGHT BLUE MET (91)
6ZW SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
7ZW SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
8NL SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
82C TRIM COMBINATION, CLOTH, MED DK GRAY (C) (91)
82I INTERIOR TRIM, MED DK GRAY (91)
829 SEAT BELT COLOR, MED DK GRAY (91)
86A STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
9NL COMPUTER SELECTED REAR RIGHTHAND SPRING
RPO DESCRIPTION
B4Z IROC PACKAGE
T96 LAMP, FOG
V73 ANTENNA, FIXED
YR1 SEAT,FRT CUSTOM
#168
Car: 91 Camaro Z28
Transmission: Borg Warner 5 spd Manual
1991 Camaro Z28
AJ3 - Restraint System, Front Seat Infaltable Driver
AM9 - Seat, Split Back Folding
AN4 - Restraint, Child Provision
AR9 - Seat, Front Bucket, European Style, Pass & Driver Recline
AU3 - Power Door Locks
A31 - Power Windows
A90 - Power Rear Hatch Release
B18 - Deluxw Ornamentation
B34 - Carpeted Front Floor Mats
B35 - Carpeted Rear Floor Mats
C41 - HVAC System, Heater Outside With Fan
C49 - Rear Electric Defogger
DC4 - Mirror Interior Tilt, Dual Reading Lamps
DG7 - Mirrors, Remote Electric, Painted
D34 - Visor Vanity Mirror
D42 - Shade, RR, Comp security
D55 - Console Front, Comp - Floor
D8G - Sensor Vehicle Speed
D81 - Spolier, Aero Wing
E5Z - Speedo Gears - Delete
E9Z - Speedo Key - Delete
FE2 - Suspension System, Ride Handling
GU6 - 3.42 Rear Axle Ratio
G80 - Positraction Rear Axle, Limited Slip
G92 - Rear Axle Ratio, Performance
IPC - Trim Interior design
JG1 - Aluminum Driveshaft
J65 - Power Brakes Front, Rear Disc
KC4 - Engine Oil Cooling System
KO5 - Engine Block Heater
K68 - 1-5 Amp Generator
LB9 - 305 TPI
MK6 - Transmission Manual 5 Speed, Borg Warner 2.95 1st/OD
MM5 - Merchandised Transmission, 5 Speed Provisions
NA5 - Federal Emissions
NP5 - Leather Wrapped Steering Wheel and Shift ****
N10 - Dual Exhaust
N64 - Wheel & Tire, Space Saver, Aluminum
N96 - Aluminum Wheels, 16x8
QLC - Tires, P245/50ZR16 N BL R/PE ST TL HW4
R7U - COPO
T61 - Daytime Running Lights
UB3 - Cluster Instrument - Oil/Temp/Tach/Volts/ Trip
UN6 - Radio AM/FM Seek/Scan Reverse
UQ1 - Radio Provisions For Stereo
U19 - Speedo Kilometers, Odometer Kilometers
VAN - Van Nuys
VK3 - License Plate Front Mounting Bracket
V73 - Vehicle Statement Canada (or fixed antenna)
Z28 - Performance Package
Z31 - Advanced Price Sheet
Z49 - Export Canadian Modification Mandatory Base Equipment
ILE - Performance Package
IOU - Exterior color - Arctic White
11P - Wheel Colour Pink
19C - Trim Combination Cloth Black
191 - Interior Trim Black
199 - Seat Belt Color Black
6DB - Spring Computer Selected Front Left Hand
7DB - Spring Computer Selected Front Right Hand
8NN - Spring Computer Selected Rear Left Hand
9NN - Spring computer Selected Rear Right Hand
A31 - Power Windows
LB9 - 305 TPI
N10 - Dual Exhaust
R7U - COPO
VAN - Van Nuys
#169
Car: 1989 IROC-Z Camaro, T-Tops
Engine: L98 5.7 TPI
Axle/Gears: GH3 2.77 POSI
Can anyone help with the rpo codes 6ZW, 7ZW, YA7, and IPC (could be 1PC). They"re probably here, but maybe I can save some time. Thanks
#170
90 GTA Canadian car:
Unknown codes AN4, IL2, R7K, T61, U19, V73, WW4, W62, Z31, 1SA, 19I, 19Q, 199, 52P, 6ZW, 7ZW, 8NL, 8NL
Missing: PB4
Missing: PB4
#172
Car: 1988 IROC-Z
1988 IROC-Z
B6T APPEARS TO BE -- PACKAGE, GRAPHIC #4 -- BUT, IT'S AN 89 CODE
81U: PRIMARY COLOR, EXTERIOR, BRIGHT RED (91)
81Q: MOLDING COLOR, BRIGHT RED (91)
199: SEAT BELT COLOR, BLACK (91)
19I: INTERIOR TRIM, BLACK (I) (91)
19C: TRIM COMBINATION, CLOTH, BLACK (C) (91)
15P: WHEEL COLOR SILVER METALLIC (91)
1SC: PACKAGE, OPTION 03
Z28: MERCHANDISED PKG, SPECIAL PERFORMANCE
YT1: BUILD UP DR & QTR
YS1: SEAT,RR CUST
YR1: SEAT,FRT CUSTOM
YF5: CERTIFICATION, EMISSION, CALIFORNIA
YA7: TEST, EMISSION, CALIFORNIA ASSEMBLY LINE
WW8: APPEARANCE PACKAGE(BRIGHT RED), AERO #8
V73: ANTENNA, FIXED
VG8: VEHICLE, BUYER NOTICE LABEL
U79: SPEAKER SYSTEM, 4, DUAL FRT COAX, DUAL EXT RGE PKG
U26: LAMP, INTR, ENG COMPT, COURTESY
UX1: RADIO, AM/FM STEREO CASSETTE EQUALIZER
T96: LAMP, FOG
TT4: HEADLAMPS, HALOGEN, 4
TR9: LAMP, GROUP
QDZ: TIRE ALL, P245/50VR16/N BL R/PE ST TL HW4
PB4: LOCK CONTROL, WHEEL
N96: WHEEL, 16 X 8, CAST ALUMINUM
N33: STEERING COLUMN, TILT TYPE
NP5: LEATHER WRAPPED, STEERING WHEEL AND SHIFT ****
NN5: EMISSION OVERRIDE, CALIFORNIA SYSTEM, FEDERAL
GH3: AXLE REAR, 2.77 RATIO
E7Z: ??
D88: DECAL, STRIPE, SPORT
Thirdgen.org -- RPO Decoder
D80: SPOILER, RR END PNL
D6E: GEAR, SPEEDO DRIVEN
D34: MIRROR, VISOR VANITY
C95: LAMP, INTR, ROOF, COURTESY AND DUAL READING
CD4: WIPER SYSTEM WINDSHIELD, PULSE
B91: ORNAMENTATION, EXTR MLDG DR EDGE GUARD, COLORED
B6T: ?
B48: TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B35: COVERING, REAR, FLOOR MATS CARPETED INSERT
B34: COVERING, FRT FLOOR MATS CARPETED INSERT
B18: ORNAMENTATION, INTR, DELUX
A01: WINDOW, TINTED, ALL SHADED, W/S
AR9: SEAT, FRT BKT, EUROPEAN STYLE, PASS A DRIVER RECL
AG9: ADJUSTER, SEAT, POWER, 6 WAY
AC3: ADJUSTER, FRT ST, POWER, 6 WAY, BKT, DRIVER
YS1: SEAT,RR CUST
V73: ANTENNA, FIXED
T96: LAMP, FOG
TR9: LAMP, GROUP
E7Z: ??
B6T: ?
#173
Car: 1991 Z28 conv
Engine: 5.0L V8
Transmission: auto
I know this is an older thread but just found my tag. I've got almost everything except -
R8T, WDV
Any thoughts?
R8T, WDV
Any thoughts?
#176
Car: 1989 IROC-Z / T-Top -1987 GTA
Engine: 305 (LO3) _350 (L98)
Transmission: 700R4 _ 700R4
Axle/Gears: 2.73 L.S. - ???
i must be about the only poor sucker that got an L03 in an iroc ... and this is sure a lot of codes for nothing good to be in my car ... LOL
B84: ORNAMENTATION, EXTR MLDG, B0DY SIDE CC1: ROOF HATCH, REMOVABLE PANELS, GLASS
D35: MIRROR, OUTSIDE REAR VIEW
D6D: COLOR OVERRIDE, TRIM AND PAINT COMPATABILITY
E72: BODY LENGTH, INCR I8 INCH
GU2: AXLE REAR, 2.73 RATIO
IPC: TRIM- INTERIOR DESIGN
J50: BRAKE SYSTEM, POWER
K60: GENERATOR, 100 AMP
L03: 5.0 LITER V-8 TBI ENGINE
N65: WHEEL & TIRE,SPARE, SPACE SAVER, STEEL
PF2: WHEEL, 15 X 7, ALUMINUM
QYZ: TIRE ALL, P215/65R15/N BL R/PE ST TL HWY
TR9: LAMP, GROUP
T96: LAMP, FOG
UA1: BATTERY, HEAVY DUTY
V73: ANTENNA, FIXED
1AY: ??? 1SC: PACKAGE, OPTION 03
16P: WHEEL COLOR, BRT WHITE (91)
19I: INTERIOR TRIM, BLACK (I) (91) 199: SEAT BELT COLOR, BLACK (91)
TR9: LAMP, GROUP
T96: LAMP, FOG
V73: ANTENNA, FIXED
#177
Early 1988 Iroc ordered in Jan, delivered end of February.
#178
Car: 1987 Iroc-Z28
Engine: L98 (soon to be LT1)
Transmission: 700R4 (soon to be 4L60e)
Axle/Gears: 3.27 LS
My New 87 Iroc-z
she's got a little over 62K miles on her
B4Z: IROC PACKAGE
B94: FENDER EMBLEM, Z28
B97: ORNAMENTATION, EXTR MLDG, LOWER ACCENT
DD8: MIRROR I/S, R/V, LT SENSITIVE
DK6: CONSOLE ROOF, INTERIOR
D08: PAINT, HIGH GLOSS FINISH
D6M: GEAR, SPEEDO DRIVEN
P20: HUBCAPS, WHEEL, STYLED
TR9: LAMP, GROUP
T96: LAMP, FOG
U21: CLUSTER, INST, OIL, COOL TEMP, VOLTS, TACH
V73: ANTENNA, FIXED YR1: SEAT,FRT CUSTOM
YS1: SEAT,RR CUST
YT9: ???
1AY: ???
B4Z: IROC PACKAGE
TR9: LAMP, GROUP
T96: LAMP, FOG
YS1: SEAT,RR CUST
YT9: ???
1AY: ???
#179
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Straight off the 1987 build sheet for my car.
Last edited by NowhereFast; 12-14-2014 at 06:46 PM. Reason: less obnoxious and easier to read picture
#180
1992 Pontiac Trans Am GTA, built 10/91.
I have my build sheet, just not scanned.
AAA EQUIPMENT 4-WAY MANUAL SEAT ADJUSTER
AJ3 RESTRAINT SYSTEM FRONT SEAT, INFLATABLE, DRIVER
AQ9 SEAT FRONT BUCKET, PASS, DRIVER, RECLINE
AU3 LOCK CONTROL SIDE DOOR, ELECTRIC
A31 WINDOW POWER OPERATED SIDE
A90 LOCK CONTROL RR COMPT LID, REM CONT ELECTRIC RELEASE
BC8 ORNAMENTATION INTERIOR, DOOR MAP POCKETS
B84 ORNAMENTATION EXTERIOR MOLDING, BODY SIDE
CC1 ROOF HATCH, REMOVABLE PANELS, GLASS
C49 DEFOGGER RR WINDOW, ELECTRIC
C60 HVAC SYSTEM AIR CONDITIONER, FRONT MAN CONTROLS
DC4 MIRROR INSIDE, R/V, TILT, DUAL READING LAMPS
DE4 SUNSHADE REMOVABLE HATCH ROOF
DG7 MIRROR OUTSIDE, LH & RH, REM CONT, ELECTRIC, PAINTED
D42 SHADE RR COMPARTMENT SECURITY
D7C GEAR SPEEDOMETER DRIVEN
D8N SENSOR VEHICLE SPEED
D81 SPOILER RR, AERO WING
E5Z ADAPTER SPEEPOMETER (DELETE)
E9Z KEY SPEEDOMETER (DELETE)
FE2 SUSPENSION SYSTEM RIDE, HANDLING
GU2 AXLE REAR, 2.73 RATIO
IL2 TRIM INTERIOR DESIGN
JG1 SHAFT PROP, ALUMINUM
J42 BRAKE SYSTEM POWER, FRONT DISK, RR DRUM, ALUMINUM
K34 CRUISE CONTROL AUTOMATIC, ELECTRONIC
K68 GENERATOR 105 AMP
LB9 ENGINE GAS, 8CYLINDER, 5.0L, TPI, HIGH OUTPUT
MD8 TRANSMISSION AUTO 4 SPEED, THM 700R4
MXO MERCHANDISED TRANS, AUTO PROVISIONS, O/D
NA5 EMISSION SYSTEM FEDERAL, TIER 0
NN5 EMISSION OVERRIDE CA SYSTEM, FEDERAL OFFSET VEHICLE
NP5 STEERING WHEEL LEATHER WRAPPED
N64 WHEEL & TIRE SPARE, SPACE SAVER, ALUMINUM
PW7 WHEEL 16 X 8, ALUMINUM, DIAMOND SPOKE STYLE
QLC TIRE ALL P245/50ZR16/N BL R/PE ST TL HW4
R8I CONTROL SALES ITEM NO. 59
T93 LAMP TAIL & STOP, SMOKED, SPECIAL
T96 LAMP FOG
UB3 CLUSTER INST, OIL, COOL TEMP, VOLTS, TRIP ODOM, TACH
UQ1 RADIO PROVISIONS FOR STEREO
UX1 RADIO AM/FM STEREO CASS, SEEK/SCAN, AUTO REV, EQ
U62 SPEAKER SYSTEM 4, DUAL COAX FRONT, DUAL COAX PACKAGE SHELF
U75 ANTENNA POWER, RADIO
VAN PLANT CODE VAN NUYS, CALIFORNIA
VG3 VEHICLE LABEL, NOTICE TO BUYER
VK3 LICENSE PLATE FRONT MOUNTING PACKAGE
V73 VEHICLE STATEMENT UNITED STATES/CANADA
WS4 MODEL CONVERSION TRANS AM
WS6 PERFORMANCE PACKAGE SPECIAL
YA7 TEST EMISSION, CALIFORNIA ASSEMBLY LINE
YF5 CERTIFICATION EMISSION, CALIFORNIA
Y84 MERCHANDISED PACKAGE GTA, TRANS AM
1SA PACKAGE OPTION 1
18Q MOLDING COLOR SLATE GREY (91)
18U PRIMARY COLOR DK. JADE GREY MET. PRIMAR (91)
52P WHEEL COLOR GOLD METALLIC (96)
6ZX SUSPENSION SPRING, COMPUTER SELECTED, FRT, LEFT HAND
7ZX SUSPENSION SPRING, COMPUTER SELECTED, FRT, RIGHT HAND
8NM SUSPENSION SPRING, COMPUTER SELECTED, REAR, LEFT HAND
9NM SUSPENSION SPRING, COMPUTER SELECTED, REAR, RIGHT HAND
82I INTERIOR TRIM MEDIUM DARK GREY (91)
822 TRIM COMBINATION LEATHER, MEDIUM DARK GREY (91)
829 SEAT BELT COLOR MEDIUM DARK GREY (91)
COMPONENT PART/NUM BROADCAST
ENGINE ASSEMBLY DBP
TRANSMISSION 2FZM
REAR AXLE ASSEMBLY 6HE
RIGHT FRONT HUB ASSEMBLY OF
LEFT FRONT HUB ASSEMBLY OF
ELECTRONIC CONTROL MODULE 3091
IR-MODULE ASM-INFLATOR 8696
IR-SENSOR-PASSENGER COMP 8841
IR-SENSOR-FORWARD 8821
IR-SENSOR-ARMING 8831
IR-MODULE ASM-DIAG ENERGY RESERVE 1221
T96 LAMP FOG
ENGINE ASSEMBLY DBP
TRANSMISSION 2FZM
#181
Car: 1986 Firebird Trans Am
Engine: 305 4BBL
Transmission: 5 speed
Axle/Gears: 9 bolt LSD 3.27
Hi guys. I'm new to this site and from Australia. I have recently purchased a black & gold 1986 TA with 305 4BBL, 5 Speed Manual, 3.27 LSD, C&C T-Tops and custom 3" dual exhaust. 75,250 original miles. Everything on this car works and goes well for a 305! Oh, it was converted to RHD in 1991 by Greenback Conversions. Here are my codes -
AAA AC3 AK1 AM9 AR9 AU3 A01 A31 A90 BS1 BV3 BX5 B20 B34 B35 B48 B67 B84 B87 B91 B97 CD4 C60 C95 DD8 DG7 D14 D27 D34 D42 D5R D81 D88 D9E E5Z E9Z GW6 G80 J65 K22 K34 LG4 MM5 M39 NA5 NP5 N09 N33 N65 N90 PB4 QYH TR9 T93 T96 UA1 UF6 UM6 UQ7 UT1 U21 U25 U29 U75 VAN VK3 V73 WS4 WW5 W62 YR1 YS1 YT1 YT9 19Q 41U 6ZW 60P 6ZC 621 629 7DB 8NB 9NB
BC/CC WA-U8555
Sheer driving pleasure! Well...there are a few rattles and squeaks
Cheers Bruno
#182
1987 Sport Coupe
AR9
A01
B84
C60
D35
D6H
D80
D86
D98
E5Z
E7Z
E9Z
GU6
J50
K60
LB8
MD8
MX0
NA5
NK3
N33
PC5
P06
P20
QYH
UM6
UQ1
U21
U79
VAN
V73
YT9
05A
1AY
1SB
19Q
28U
6XR
7XR
8UX
82B
821
829
97L
9UX
AR9
A01
B84
C60
D35
D6H
D80
D86
D98
E5Z
E7Z
E9Z
GU6
J50
K60
LB8
MD8
MX0
NA5
NK3
N33
PC5
P06
P20
QYH
UM6
UQ1
U21
U79
VAN
V73
YT9
05A
1AY
1SB
19Q
28U
6XR
7XR
8UX
82B
821
829
97L
9UX
#185
Car: 1991 Camaro RS
Engine: 350, Edelbrock Pro Flo efi
Axle/Gears: 4.10 on a torsen diff
Low-optioned 91 RS
AJ3 AR9 CC1 C41 C49 D35 D5V D8M D80 E5Z E9Z F41 GU4
IPB J41 K60 L03 MM5 M39 NA5 NK3 N96 QMT R6V R8T UB3
UN6 UQ1 U79 VAN VK3 V73 Y86 1AY 1SA 6XT 7XT 8NL 81P
81U 82B 82I 829 9NL
81U 82B 82I 829 9NL
#186
Car: 1992 Firebird
Engine: LH0 3.1L V6
Transmission: Automatic 4 Speed w/Overdrive
I've had my Firebird for about a year. Got it from my brother who bought it new. Not sure what all this means although I have looked up some. It is in great shape, very tight, no rattles or squeaks. Interior is in excellent condition although the exterior is in need of paint. It now has about 144,000 miles on it and is my daily driver for my 90 mile round trip commute. I have added cruise control (digital, not OEM). The radio has been replaced and the pull down motor has been rebuilt so it is all in good working condition.
#187
Engine: 305 4BBL
Here's mine - 1986 Trans Am. Black/Gold. C&C T Tops.
AAA, AC3, AK1, AM9, AR9, AU3, AO1, A31, A90, BS1, BV3, BX5, B20, B34, B48, B67, B84, B87, B91, B97, CD4, C60, C95, DD8, DG7, D14, D27, D34, D42, D5R, D81, D88, D9E, E5Z, E9Z, GW6, G80, J65, K22, K34, LG4, MM5, M39, NA5, NP5, NO9, N33, N65, N90, PB4, QYH, TR9, T93, T96, UA1, UF6, UM6, UQ7, UT1, U21, U25, U29, U75, VAN, VK3, V73, WS4, WW5, W62, YR1, YS1, YT1, YT9, 19Q, 41U, 6ZW, 60P, 62C, 621, 629, 7DB, 8NB, 81A, 9NB, BC/CC, WA-U8555.
#188
Engine: 305 4BBL
[Here's mine - 1986 Trans Am. Black/Gold. C&C T Tops.
#189
Car: 1991 pontiac trans am Gta
Engine: Lb9 5.0 soon to be L98 5.7
Rpo code help
1985 pontiac trans am
#190
Car: 1992 Camaro RS 25th Anniversary
Engine: 305 TBI
what is f41 code on a 92 camaro rs read up on it still not completely clear what it means.
#191
86 IROC....................
#192
Car: 92 Camaro Z28 Heritage Edition
Engine: 350 5.7 TPI
1992 Z28
What exactly does the following codes mean in layman's terms?
FE2 - Suspension Special Performance
What is different about the suspension?
J65 - 4 wheel disc brake
Are these 10" rotors on front/rear?
B18 - Custom Interior
I don't see anything different in my interior than other 92 Camaros?
U79 - Ext Range SPE ?
Also, on the build sheet, line item 43 Propulsion Shaft is listed as AY 0198.
Is that a steel driveshaft or aluminum?
#193
1986 Iroc-Z, auto, ttop, 10 bolt rear end with drum brakes. No idea how many prev owners.
#198
This is the build sheet for my 84 trans am. Only a few codes I can't find yet.
D1C, E6E, MK6 (I think is something with the hyd clutch or 5spd), and WS8. I'll keep looking, but any help would be great.
#199
Car: 1986 IROC-Z28
1AZ - CUSTOMER ORDERED VEHICLE
6ZX - SPRING, COMPUTER SELECTED, FRONT, LEFTHAND
74Q - MOLDING COLOR, FLAME RED METALLIC
74U - PRIMARY COLOR, VICTORY RED
7ZX - SPRING, COMPUTER SELECTED, FRONT, RIGHTHAND
829 - SEAT BELT COLOR, MEDIUM DARK GRAY
82C - TRIM COMBINATION, CLOTH, MEDIUM DARK GRA
82I - INTERIOR TRIM, MEDIUM DARK GRAY
86P - WHEEL COLOR, GRAY METALLIC
86A - STRIPE COLOR, ACCENT, TWO TONE RED/GUNMETAL (91)
89K
8NL - SPRING, COMPUTER SELECTED, REAR, LEFTHAND
9NL - SPRING, COMPUTER SELECTED, REAR, RIGHTHAND
A01 - WINDOW, TINTED, ALL SHADED, W/S
A31 - WINDOW, POWER OPERATED, SIDE
A90 - LOCK CONTROL, REAR COMPARTMENT LID, REMOTE CONTROL ELECTRIC RELEASE
AR9 - SEAT, FRONT BUCKET, EUROPEAN STYLE, PASS DRIVER RECLINE
AU3 - LOCK CONTROL, SIDE DOOR, ELECTRIC
B18 - ORNAMENTATION, INTERIOR, DELUXE
B2G – COMPONENTS OF IROC-Z PACKAGE
B34 - COVERING, FRONT FLOOR MATS CARPETED INSERT
B35 - COVERING, REAR, FLOOR MATS CARPETED INSERT
B48 - TRIM EQUIPMENT, LUGGAGE COMPARTMENT
B4Z - IROC SPORT EQUIPMENT PACKAGE
B84 - ORNAMENTATION, EXTERIOR MOLDING, BODY SIDE
B94 - FENDER EMBLEM, Z28
B97 - ORNAMENTATION, EXTERIOR MOLDING, LOWER ACCENT
BS1 - INSULATION, ACOUSTICAL PACKAGE
C4B - PERFORMANCE PACKAGE, ENGINE UPGRADE
C49 - DEFOGGER, REAR WINDOW, ELECTRIC
C60 - HVAC SYSTEM, AIR CONDITIONER FRONT MANUAL CONTROLS
C95 - DOME READING LAMP
CC1 - ROOF HATCH, REMOVABLE PANELS, GLASS/LEXAN
CD4 - WIPER SYSTEM WINDSHIELD, PULSE
D08 - PAINT, HIGH GLOSS FINISH
D34 - MIRROR, VISOR VANITY
D6F - SPEEDOMETER DRIVEN GEAR
D80 - SPOILER, REAR DECK
D88 - DECAL, STRIPE, SPORT
DG7 - MIRROR O/S, LH & RH, REMOTE CONTROL, ELECTRIC, PAINTED
E5Z - SPEEDOMETER ADAPTER (DELETE)
E7Z - KEY, SPEEDOMETER (DELETE)
E9Z - KEY, SPEEDOMETER (DELETE)
FE2 - SUSPENSION SYSTEM, RIDE HANDLING
GC5
GC6
GU5 - AXLE, REAR 3.23 RATIO
J42 - BRAKE SYSTEM, POWER, FRONT DISK, REAR DRUM, ALUMINUM
J50 - BRAKE SYSTEM, POWER
K34 - CRUISE CONTROL, AUTOMATIC, ELECTRONIC
K90 - ALTERNATOR, 108 AMP
LB9 - ENGINE, GAS, 8 CYL, 5.0L, TPI, HO (1985-1992 ONLY)
MD8 - TRANSMISSION, AUTO 4 SPEED, 700R4
MXO - MERCHANDISED, TRANS, AUTO PROVISIONS, O/D
N33 - STEERING COLUMN, TILT TYPE
N65 - WHEEL & TIRE, SPARE, SPACE SAVER, STEEL
N96 - WHEEL, 16X8, ALUMINUM
NA5 - EMISSION SYSTEM, FEDERAL, TIER 0
NK3 - STEERING WHEEL, SPORT, SOFT RIM, SIMULATED LEATHER
P20 - WHEEL HUBCAP, BRIGHT ALUMINUM
QDZ - TIRE ALL, 245/50VR16
T63 - ALARM, HEADLIGHTS ON, WARNING SYSTEM
T93 - TAIL & STOP LAMP, SMOKED
T96 - LAMP, FOG
TR9 - LAMP, GROUP
TT4 - HEADLAMPS, HALOGEN (4)
U21 - CLUSTER, INSTRUMENTS, OIL, COOL TEMP, VOLTS, TACHOMETER
U25 - LAMP, INTERIOR, RR COMP, COURTESY
U26 - LAMP, INTERIOR, ENGINE COMPARTMENT, COURTESY
U29 - LAMP, INTERIOR, I/P, COURTESY
U75 - ANTENNA, POWER, RADIO
UP8 - STEREO RADIO INSTALLMENT PROVISIONS
UX1 - RADIO, AM/FM STEREO, CASSETTE, EQUALIZER
V73 - VEHICLE STATEMENT, US/CANADA
VAN - ASSEMBLY PLANT, VAN NUYS, CALIFORNIA
VK3 - LICENSE PLATE, FRONT MOUNTING PACKAGE
YE2 - RADIO, STEREO, CASSETTE, CLOCK, S/S, EQ
YR1 - SEAT, FRONT CUSTOM
YS1 - SEAT, REAR CUSTOM
YT1 - BUILD UP DOOR & QTR
YT9 - OPTION PACKAGE, FISHER FURNISHED PARTS
Z28 - MERCHANDISED PACKAGE, SPECIAL PERFORMANCE
89K
GC5
GC6
T96 - LAMP, FOG
TR9 - LAMP, GROUP
#200
No, no side moldings on this car.
It's an unusual car altogether, look at the RPO list, it has a lot of deletes and all of the performance options yet it's not a 1LE. It only has power windows, no power mirrors, no power locks, no power seats, no AC..it's bare bones. Has 5 speed, LB9 high output (5500 redline), 9 bolt axle w/ perf ratio, J65 discs.
Look at the redline and metric gauges, even the oil pressure is in Kilo Pacals. odo is km not miles.
This is a weird car and it's in pristine condition with onl 50K on the odo. It's completely original and unmolested. The only issue is the exhaust is shot so I'm replacing it with the stainless edelbrock system that came off the 87 and keeping the stock tip sections.
i am looking at a very nice 88. 50.000kilometers. Is everything basically the same just the guages?
