How do you secure door panel rail?
Old 07-30-2016, 09:07 PM
Sichno's Avatar
Car: 1986 Iroc Z28
How do you secure the do or panel rail to the door?? When I bought my car they were missing so I went to the junkyard and bought a pair, how do I secure the panel onto the door?
My door panel has a thin leather going over it, but the cardboard felt behind it has dried up and doesn't hold right, how can I glue it back onto its cardboard felt?
Old 07-30-2016, 09:48 PM
Matt trans am's Avatar
Car: 1985 trans am
Re: How do you secure door panel rail?
Those are two seperate pieces. They are attached togethere behind the panel. Somebody destroyed the carboard backing where they are joined.
Old 07-31-2016, 05:22 PM
SouthSide2's Avatar
Car: 1990 RS Camaro
Engine: 406
Transmission: TKO 600
One way to inprove what are working with is hot glue. Im sure it will work better than tape. Of course new panels are best. You can find them. Question is... Is the car worth the money?
I started my money pit Camaro four years ago. I'm still dumping time and money into it. And not done yet.
All cars are made to go together once. Taking somethings apart and reassemble requires new parts.
Hot glue guns are cheap. Nice to have one around the house for many sticky needs.
Hope this helps.
Old 08-02-2016, 07:42 AM
greenyone's Avatar
Car: 91 G92 Z28
Axle/Gears: 342
Mine were like that too. I wish I would have taken pictures. The plastic piece was no longer attached due to the holes in the cardboard being ripped through. I took some pieces of thin .040 polystyrene modeling plastic and gorilla glued them over the ripped holes on the backside of the door panel and then re-drilled the holes for the door plastic to accept. New door panels are in my future. But this got me down the road for the time being.
This stuff.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old 08-29-2016, 03:24 PM
navy02ws6's Avatar
Engine: LS1, LB9, L03
I'm pretty sure I've seen several members on here just reattach them from the back of the door panel with that expensive shiny aluminum duct tape (not to be confused with regular duct tape as it's much more heat resistant). From what I've read, it's supposed to be a fairly permanent fix, at least from a cosmetic standpoint. The door panel will need to be removed from the door first of course.
Old 08-29-2016, 04:12 PM
scottmoyer's Avatar
Car: 87 IROC-Z, 82 Pace Car
I've not seen the duct tape used on a door panel that was completely destroyed. To strengthen the connection, I added duct tape to mine, but the cardboard is still in mint shape and the studs/caps were all tightened. The cardboard has holes larger than the studs, so there is movement on the top cap, unless you overtighten the caps. You can shear off the stud though by doing that. I tightened mine up as tight as I was comfortable going, then held the top piece in place while I duct taped it together. It's tight now, no movement and no rattles.
gt4373
04-14-2016 11:35 PM
gt4373
04-14-2016 11:33 PM
gt4373
04-13-2016 11:33 PM
gt4373
03-31-2016 11:10 PM
xbmx89
South Central Region
03-29-2016 02:14 PM
Quick Reply: How do you secure door panel rail?
