Finally: Holley to produce LT and True Dual System
Old 03-23-2016, 07:35 AM
  #201
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Re: Finally: Holley to produce LT and True Dual System
Originally Posted by crazynights
Anyone with the dual exhaust kit installed have any sound clips? Overall opinion on the noise level? Thanks
Haven't heard of anyone getting it installed on a running car yet. There are some clips on youtube of the fourthgen kit. Should be fairly close if you are running an LS.
Old 03-23-2016, 08:02 AM
  #202
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Thanks, I just listened to some clips. Seems to be quieter than a Mufflex.
Old 03-23-2016, 04:02 PM
  #203
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Mines pretty quiet, but I do have dual cats per side.Even when crusing though it's not that loud.Only when I get on it does it wake up.
Old 03-23-2016, 04:36 PM
  #204
timonator's Avatar
I'm still waiting for the motor mounts. Word is that they're on backorder until April 6th.
Old 04-16-2016, 12:25 PM
  #205
timonator's Avatar
I bought this system with the headers and everything, but I decided to sell my car before installing if anyone is interested, I still have it all new in the box unopened.
http://chicago.craigslist.org/nwc/cto/5539634540.html
Old 04-26-2016, 08:31 PM
  #206
thunder57's Avatar
Car: 1987 IROC
Axle/Gears: 3:42, 10 Bolt LT1
What's the general consensus on the exhaust system? Worth the coin? Any exhaust clips?
Old 04-27-2016, 04:31 PM
  #207
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
This is what you want, trust me! If you drive your car everyday a loud exhaust will get old FAST.
Old 04-27-2016, 09:28 PM
  #208
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I'm not complaining.Nothing on my car makes one think its nothing more than just a Camaro with GTA wheels.
Old 05-18-2016, 07:39 PM
  #209
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
So I read through all of this thread and the one on ls1tech so im not sure if I missed it or not. But will the swap headers work with the 1 inch set back adapter plates and factory k-member? Trans-Dapt Performance Engine Swap Motor Mounts 4595 is what I used but with the 92 style motor mounts, not the ones shown in the link.
Old 05-18-2016, 07:49 PM
  #210
toddoky's Avatar
There's no way to say from an official standpoint as the headers were designed to function as an integrated part of the Hooker 3rd-gen swap system and not as a universal-fit components. You might get lucky and get them in, or you might end up in a messy situation.
Old 05-19-2016, 07:11 AM
  #211
Car: 92 Z28
I'm using the Spohn/Hawks engine mounts and factory K member. Fit just fine. I believe the spacing on those and the set back plates is the same, but I'm sure someone can clarify that.
Old 05-19-2016, 01:17 PM
  #212
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Thanks guys i appreciate it, im going to give it a shot and see what happens. Worst case scenario they don't work and i have to return them. Ill post up my results here in a couple weeks.
Old 06-09-2016, 04:19 PM
  #213
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Still waiting on the headers to show up, hopefully it will be here soon. Its the last piece to get my car back together, but ill let everyone know the outcome.
Old 06-13-2016, 01:14 PM
  #214
COTM Editor
BADNBLK's Avatar
Got my set up installed...
I don't have the car running yet, so sound clip and more pics will have to wait.
Old 06-13-2016, 11:07 PM
  #215
V6canvas's Avatar
Car: 1989 Trans Am GTA
Engine: Stock LS1
Axle/Gears: 3.70 9 bolt
Very nice looking! I'd love to redo mine for that extra ground clearance, my y-pipe goes under the trans x-member.
Old 06-14-2016, 04:44 PM
  #216
R13_Braz's Avatar
Car: 2014 Z28 #80
Damn, that's gorgeous... and the exhaust system is too! lol. I just sat here staring at your whole setup for a solid 10 minutes.
Old 06-15-2016, 08:52 AM
  #217
COTM Editor
BADNBLK's Avatar
Originally Posted by R13_Braz
Damn, that's gorgeous... and the exhaust system is too! lol. I just sat here staying at your whole setup for a solid 10 minutes.
Old 06-15-2016, 09:20 AM
  #218
Car: 92 Z28
Originally Posted by BADNBLK
Is that your fuel line running through the frame rail?
Old 06-15-2016, 04:02 PM
  #219
COTM Editor
BADNBLK's Avatar
Yes it is. Good eye.
Old 06-16-2016, 06:22 PM
  #220
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Can someone measure and post up here the driveshaft u-joint angles at ride height after installing these motor mounts and T-56 cross member? Better yet, engine, driveshaft, and pinion angles.
For ride height , a measurement from the top of the axle tube to the frame would be good..to compare apples to apples.
Thanks in advance.
Old 06-16-2016, 11:27 PM
  #221
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Well...they fit. Wasn't the easiest header install ive done, but the fit like a glove once in there. Other than having to undo the passenger side motor mount like the directions say. The only real issue i ran into was putting my starter in, didnt want to clear the headers and the stock fbody oil pan oil level sensor, but no biggy i got it to work. Ill post up some sound clips soon, ive got to do some tuning work for the heads and cam. But definitely a solid peice.
Attached Thumbnails Finally: Holley to produce LT and True Dual System-20160616_193447.jpg   Finally: Holley to produce LT and True Dual System-20160616_193431.jpg
Old 06-17-2016, 06:36 AM
  #222
Car: 92 Z28
Daughter throwing in some commentary lol. This is with the Kooks headers, but the hooker duals. My phone seems to even out the sound so it doesn't peak, it is actually pretty loud, I'm also cammed and PP heads and a few other things.
Old 06-17-2016, 09:39 AM
  #223
toddoky's Avatar
I'm glad to hear that worked out for you redmaroz. The headers were designed for use with the Holley 302-2 pan, so the issue you had installing them with your oil level sensor won't be encountered by someone using the 302-2 pan. See if you can get some undercar pics posted also when you get the chance.
Old 06-17-2016, 11:53 AM
  #224
COTM Editor
BADNBLK's Avatar
I'm running the f-body pan, and mine fit like a glove. I went in from the bottom, and didn't even need to pull the plugs out, but I did pull the starter before hand as it was obvious is wasn't gonna work with that installed... I guess like they say, every one is different.
Old 06-21-2016, 07:59 PM
  #225
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
toddoky, do you know what heads the headers are compatible with? Do they work with aftermarket heads that have plugs in different locations, or are they gm castings only?
Thanks,
Jay
Old 06-21-2016, 09:00 PM
  #226
toddoky's Avatar
Thanks,
Jay
I can't say what specific aftermarket heads they will work with, but they provide more spark plug clearance than any other headers I'm aware of...look closely at their bend geometry around the plugs and you can see that I invested a lot of effort to maximize clearance around every plug/boot.
Old 06-21-2016, 09:17 PM
  #227
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Ok thanks for the quick response. I didnt think there would be any issues, just wanted to check before i did anything.
Old 07-11-2016, 02:21 PM
  #228
91firebird5.0's Avatar
Car: 91Firebird Formula
Engine: 5.0 TBI / Now LS1
Transmission: Auto / Now T56 with stage 2 monster
Axle/Gears: 4/10
Has anybody had any success with using there original driveshaft with this holly system?
Thanks,
Old 07-12-2016, 03:20 PM
  #229
COTM Editor
BADNBLK's Avatar
Thanks,
I am using mine with my T56, and Moser 9" rear end. The 9" might be the key on this though, as it was nearly bottomed out prior to LS swap.
Old 07-14-2016, 09:01 AM
  #230
Axle/Gears: 4/10
Badnblk thanks for the info! I'm gearing up for my ls1 & t56 upgrade. Can't wait to get started. Love your set up for everything. Love the hooker exhaust!! I want the long tube but I may have to go with shorties to try and fit some small cats in next to the transmission. I would rather not!!
Old 07-14-2016, 11:29 AM
  #231
COTM Editor
BADNBLK's Avatar
With the t56 I bet you have more than enough space and clearance to install some high flow bullet cats on each side of the trans.
Old 07-15-2016, 06:24 AM
  #232
Car: 92 Z28
This is with the Kooks to the Hooker. Pipe I made is basically just a small tight bend and maybe 4" of straight pipe to connect the two. Doubt it is enough room for a cat. If you want the long tubes you might as well get them since either way you will probably have to cut the exhaust up a bit to fit cats.
Finally: Holley to produce LT and True Dual System-rwvi1ls.jpg
Old 07-15-2016, 05:44 PM
  #233
COTM Editor
BADNBLK's Avatar
I think bullet cats could be worked in next to the trans?
Old 07-16-2016, 11:10 AM
  #234
Car: 92 Z28
Yes, sorry if my post was confusing. You definitely have room for cats on the exhaust. Just not in a pipe from shorter headers to the exhaust, so you might as well buy the headers you want.
Old 07-16-2016, 03:59 PM
  #235
Axle/Gears: 4/10
Thanks guys for the info! I have decided to get the long tubes along with the rest of the system, mounts, cross member, exhaust. I like that there is a system that all works together. Do you know if Holly has had in the past a Labor day sale? I would love to buy the whole kit at one shot and if I could save a little that would be awesome!!
Old 07-16-2016, 04:06 PM
  #236
Axle/Gears: 4/10
Toddoky thank you for all your post hear and on the ls1 tech forums! It is great to have an insider that can help us with our builds and teas us with a really nice system!!
Old 08-17-2016, 06:27 PM
  #237
COTM Editor
BADNBLK's Avatar
Few new pics of mine on the ground....
I get so many compliments on the sound, and the look for those willing to lay on their bellies to see it beyond the tips haha!
Thanks again Toddoky! Those quarter panels were looking a lil empty
Old 08-17-2016, 07:25 PM
  #238
toddoky's Avatar
You've accomplished great end results with your car and the Hooker Blackheart decals look awesome on the quarter panels...congratulations on the award!
Old 08-18-2016, 07:42 PM
  #239
WTR388's Avatar
Car: 87 Trans Am
How about a few sound clips?
Whats the sound like when you're decelerating from higher rpm while in gear and not on the brakes? My Dynomax LM1 copy has a noise I hate in that situation around 2500rpm... And I want to build my own exhaust system similar to this.
Old 10-04-2016, 03:07 PM
  #240
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Hey Toddoky, is there an individual part number for the mufflers that come with the true dual exhaust kit?
Old 10-04-2016, 06:17 PM
  #241
toddoky's Avatar
We utilize these particular mufflers in a few different exhaust systems, but they are not available as stand-alone components at this point in time.
Old 10-04-2016, 06:55 PM
  #242
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
Ok cool, thanks man.
Old 10-28-2016, 08:22 AM
  #243
Car: 1982 Z-28
Engine: 383
Do you think the 70501426RHKR will be avail soon? I see it's backordered.
Old 11-10-2016, 11:17 AM
  #244
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
toddoky - Any idea what the flow rate is thru the true dual Black Heart system is?
I want to install this on my 390 SBC with an F1 Procharger pushing about 14psi. This should net me near the 700 HP mark and I want to make sure this has enough flow to support that. I think it does, but thought it would be nice to see if you guys over at Hooker had some hard numbers on flow to to along with the system.
Thanks for any help that you can provide.
Old 11-10-2016, 12:23 PM
  #245
skinny z's Avatar
Interested to know those numbers as well.
Old 11-10-2016, 12:48 PM
  #246
Lurbie's Avatar
Car: 89 Camaro
Engine: 383-Holley Terminator EFI
Transmission: 700R4 Pro-Built Street/Strip kit
Axle/Gears: Strange S60 3.55:1
Read post #18 of this thread
https://www.thirdgen.org/forums/exhaust/732243-hooker-blackheart-exhaust.html#post6035112
He answered this there. This won't support your setup.
Old 11-10-2016, 04:19 PM
  #247
skinny z's Avatar
Thanks for that Lurbie. I hadn't come across that thread before now.
Although he does offer an answer by way of comparison, it would be interesting to know how exactly he arrived at his conclusion. Being in his position he undoubtedly has access to all sorts of flow data regarding the CFM of his engineering efforts. And I would like to see them.
Short of that, it's a matter of taking the man at his word (and an educated, engineering word I should add) and go from there.
Fortunately for me, I don't have the same need as Dennis does. Or unfortunately depending on how you compare the two situations. I'm at best, about 450 HP.
Thanks again Lurbie.
Old 11-30-2016, 08:26 PM
  #248
COTM Editor
alan91z28's Avatar
Car: 91/89/85/82 Z28s, 88 TA, 88/88 SC
Engine: SBC and LS variations
so quick question regarding UMI tubular k-member... has anyone used the holley ls swap parts yet with this k-member?
my son and i are going to swap out his sbc for an ls3 in his formula that already has the umi k-member installed.
the holley motor mounts utilize mounting holes on the factory k member that normally where for the v6 in some spots vs the forward v8 holes... on the umi k-member the pad only was made for the v8 holes... i can fab something up, just wondering if anyone else has done this yet
i am thinking about taking the umi lsx mount adapter and basically grinding off their existing mount arms and fabricating arms to weld in the right spot...
Old 02-03-2017, 12:14 PM
  #249
LS2Swapped92's Avatar
Spohn kmember and motor mounts, with hooker crossmember. Redesigning my exhaust myself in my garage, not too bad imho.
Way better than anything else offered on the market right now. Worth the $300
Attached Thumbnails Finally: Holley to produce LT and True Dual System-16299315_238851996564116_1015190014353153718_n.jpg   Finally: Holley to produce LT and True Dual System-16266242_238851983230784_5652905637998227302_n.jpg
Old 02-03-2017, 09:24 PM
  #250
TORN's Avatar
Car: 88 IROC-Z
Engine: 6.9L TPI(FIRST) 421ci
Axle/Gears: Ford 9" Eaton truetrac 3.50
3 inch?
Quick Reply: Finally: Holley to produce LT and True Dual System
