Changing shock absorbers. Help!
Car: 1984 Camaro Z28, 1987 Z28 (R.I.P.)
Engine: 305 H.O.
Transmission: 5 Speed
Hey, both of my rear shocks are done and I have no idea how to change them, I see that there both detach and loose but I can't find where they're attach on top.. Can't someone tell me where I should be looking in the rear/trunk of my car? I bought 2 KYB GR-2.. that's all I can afford for now. Thanks..
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
Re: Changing shock absorbers. Help!
Remove the rear deck carpet or at least pull it back from behind the rear seat and you should see the mounts.
Engine: 305 H.O.
I finally got them off, thanks for your help.
Car: 84, 85 Camaro Berl. 1999 Corvette.
Engine: 305, 400, LS1 350.
Transmission: 700R4, 700R4, 6 Speed manual
Axle/Gears: Factory
1992 Trans Am
08-09-2015 04:32 PM
