Front end rebuild .
Front end rebuild .
Looking into rebuilding the front end of my 92 Camaro convertible and would like to get advice on the following parts .
Hyper Flex Complete Bushing Set, Camaro/Firebird 82-92 Energy Suspension
from Hawks
83-92 UMI GM F-Body Boxed Style Weld-In Subframe Connectors ( UMI )
also from Hawks
Sub-Frame Connectors, 82-92 Camaro or Firebird
Brand: Alston
from TDS
car is all stock
from Hawks
also from Hawks
Brand: Alston
from TDS
car is all stock
Engine: 305 TBI/305 TPI
Transmission: World Class T5/missing
Axle/Gears: 3.08/G92 3.45 posi
Re: Front end rebuild .
Well for what it's worth, I have only one ES item installed on my car, the transmission mount. I am awaiting to put on ES rear sway bar end links and swar bar brackets. I have read very good things about ES stuff, and my transmission mount actually made a slight difference in some chattering I was getting, however my mount was broken and before that pretty worn out. I am starting with the rear on mine then moving to the front so let us know how it goes once you're done.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i have a 91 RS in my shop for a complete front end rebuild . i use moog ball joints , tie rod ends ,idler arm drag link. also i will be using KYB #236001 struts and moog camber plates. i use ES A frame bushings as well .and ES sway bar end links . i will be using moog #5662 front springs . gotta make the customer happy !
I am going with the Hyper Flex Complete Bushing Set, Camaro/Firebird 82-92 Energy Suspension and 82-92 Fbody BMR Fabrication Subframe Connectors (Outside Framerail Exhaust) [SFC009] also 82-02 Fbody BMR Fabrication Chrome Moly Tubular Rear Control Arms - Non Adjustable [MTCA001] and finally a wonderbar to tie it all off . I will be going through WS6store.com .
92rsvortec350
02-22-2016 09:32 PM
hotrodjames
Exterior Parts for Sale
11-22-2015 07:35 PM
tonythetoad
11-12-2015 01:36 PM
