4th gen steering shaft
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
Ran a few searches and could not find any topics on this. Does anyone know if the steering shaft from the 4th gen cars can fit in ours? I know the Jeep or Astro shafts are popular, but has anyone tried the 4th gen shafts?
(Image sourced from LS1tech)
Car: 1992 Z28 Z03
Engine: LB9
Axle/Gears: 2:73
Re: 4th gen steering shaft
Yup, you are correct. Maybe this can serve as a sticky somewhere, but the 4th gen steering shafts are around 13" and non adjustable for length, and ours are around 18".
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the 4th gens have rack and pinion steering, which probably has a different shaft size and spline count on top of being in a totally different location than the Saginaw steering box in the older cars.
1 Post
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
It does not fit. The 4th gen column will fir but you have to fully collapse the shaft.
dennisbernal91z
04-14-2016 05:42 AM
