Knock sensor trouble
If mine isnt working correctly, what kind of symptoms will it give. I have a code 43. My ECM is new.
Any detailed ways to check and see if its bad before I change it? Its the factory sensor.
Car is a 92 Formula, L98.
Car: 4
Engine: 6
Transmission: 5
Easiest way to tell if it needs replacing:
Replace it. If the car runs better and quits throwing the code for it, it was bad.
Your cooling system probably needs the drain & fluch anyway.
