What Next?
Old 11-18-2001, 06:13 PM
Hype's Avatar
What Next?
Ok so the 350 is in and broken in enough to pull a few full throttle runs. It hauls pretty nicely, but I'd like to add a bit more before I'm satisfied (or broke). Here's what I've got:
350 bored .030,
flattops, 882 heads (cleaned up, no porting)
with the deckheight and head gasket ~8.9CR.
Comp Cams XE 262 grind.
Edelbrock Performer Manifold, Stock Qjet. (B hanger, CK rods)
Edelbrock TES headers (!!Lg4 version!!) /w some sorta aftermarket cat, feeding into some sorta 3" catback, noisy "flo-pro" muffler.
3.73 gears, phat tyres, manual tranny.
Timing set at 8*. Did I miss anything?
Anyhow, I'm assuming the bottlneck is at the Ypipe collector/cat conv, so I'm looking at a replacement Flowmaster (2.25" in / 3.00" out) Y-pipe collector with a high-flo cat, or maybe just a test pipe as its not required, but most likely a high-flo since un-catalyzed(sp?) exhaust stinks and sounds a little too *******.
Better ideas? Anyone?
Later,
Hype.
Old 11-18-2001, 07:35 PM
breathment's Avatar
i would say ur exhaust is holding u back. and i wouldn't go with flowmaster unless u just want them for sound, they don't .FLOW as good as many others out there
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old 11-19-2001, 01:22 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Try working on your ignition curve. You don't say what you have for a distributor but if it is HEI go to the Tech Articles on this site and get the one dealing with them.
