Apparently I got screwed...
Old 08-12-2014, 10:15 PM
  #101
Joe Tag's Avatar
Re: Apparently I got screwed...
Because collapsing just like that is a problem with the lower hose like I said earlier. If the pump is spinning the wrong way it is pumping in reverse flow which would cause suction on the upper hose.
Old 08-12-2014, 10:19 PM
  #102
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
I think I get it now, the pump not only sucks, but blows as well. Attributing to the lower pressure in the bottom hose, and higher pressure in the upper hose. (In a properly working system, at least) I was thinking the block was the start of the system, when actually the radiator is the start.
and good night!
Old 08-12-2014, 10:21 PM
  #103
MintWS6FORMULA's Avatar
Location: Michigan [Bodacious Member with the Bodacious TA'TAs (Trans Ams)]
Car: 91 Formula - Authentic and REAL
Engine: 5.0 Liter
Originally Posted by Hawkeye1980
DONT and I mean DONT send it to the crusher. PLEASE! These cars took a beating at that stupid cash for clunkers BS that went on a couple of years ago. I remember going to a junk yard looking for some parts. The owner told me, oh yeah, we had a bunch of 3rd gent birds and camaros, but we go cash from the gov. to crush them. I wanted to cry, lol.
And those are the people who will be kicking themselves in 10 years. And those 81 year olds who cut the split window out of their '63's back in the mid 60's will be kicking their a**es for them wondering why they don't learn from other people.
Old 08-13-2014, 11:00 AM
  #104
tyeo098's Avatar
Car: 88 Chimera
Part number off the old pump:
10108451
Which says its for a serpentine belt system??
Well its nasty anyways.
Old 08-13-2014, 11:06 AM
  #105
Joe Tag's Avatar
I thought I saw an A/C delete pulley on the car. Check the routing of the belt. Does it go around the crank pulley on the passenger side and to the water pump on the drivers side? Or some other route that makes it spin clockwise? It absolutely should not collapse like that when revved.
Old 08-13-2014, 11:09 AM
  #106
tyeo098's Avatar
Car: 88 Chimera
Thus is what I wrote down:
I apologize for the silly drawing
Old 08-13-2014, 11:50 AM
  #107
Joe Tag's Avatar
That has it spinning the right way. Here is a similar problem to what you have and leads back to the things I mentioned. Pump cap and thermostat. Thermostats normally fail open and are designed to, but anything could be happening here. I don't buy the plugged radiator theory because it would collapse the lower hose.
http://chevroletforum.com/forum/gene...-revved-10514/
http://www.v8buick.com/archive/index.php/t-138086.html
and another
http://www.camaros.net/forums/showthread.php?t=20911
Old 08-13-2014, 12:01 PM
  #108
tyeo098's Avatar
Car: 88 Chimera
The way it was on seems to be the incorrect way according to this pic. If this pic is correct, anyways
Pulled from here for 1988?
http://sethirdgen.org/serpentine.htm
I got a new rad cap and thermostat too just in case
Old 08-13-2014, 12:10 PM
  #109
Joe Tag's Avatar
Scratch the, it is running the correct way routed like that
Old 08-13-2014, 12:13 PM
  #110
tyeo098's Avatar
Car: 88 Chimera
But then the image labeled 1989-92 has it the way I have it. PO said the engine was from a later bird?
I have no idea.
Old 08-13-2014, 12:29 PM
  #111
Joe Tag's Avatar
Beginning to doubt myself even. Go with what you have and the routing it was in before. I think we are overthinking it. If all this fails I'm at a loss other than a weak hose, but I have never seen an upper collapse like that.
Old 08-13-2014, 12:35 PM
  #112
Joe Tag's Avatar
Try just the cap first and see if it builds pressure in the system and stops that.
Old 08-13-2014, 01:03 PM
  #113
tyeo098's Avatar
Car: 88 Chimera
Well I already got the new pump on and the water neck off for the 180* tstat.
So I'm pretty much ***** deep in this one lol.
First time using a torque wrench though. So that was pretty cool!
Old 08-13-2014, 01:10 PM
  #114
Joe Tag's Avatar
Certainly won't hurt, but it would have been nice to know for future reference.
Old 08-13-2014, 01:19 PM
  #115
tyeo098's Avatar
Car: 88 Chimera
Sorry :/
This is what the old cap looked like btw
Old 08-13-2014, 01:24 PM
  #116
Joe Tag's Avatar
Go with your gut Joe. Pretty sure that was the first thing I said to check LOL.
Old 08-13-2014, 01:27 PM
  #117
tyeo098's Avatar
Car: 88 Chimera
would that cause the upper pipe to get squeezed down though though?
Old 08-13-2014, 01:35 PM
  #118
Joe Tag's Avatar
Once it builds pressure to 16 lbs that wont be a problem
Old 08-13-2014, 01:37 PM
  #119
tyeo098's Avatar
Car: 88 Chimera
ok so putting the belt on should I put it the original way or should I put it the way that was specified in the first picture?
Old 08-13-2014, 01:40 PM
  #120
Joe Tag's Avatar
The second pic is how you had it run before and it has the pump running CCW.
Old 08-13-2014, 02:29 PM
  #121
tyeo098's Avatar
Car: 88 Chimera
It liiiives! Kinda.
Tstat opened up nicely, top tube got nice and warm, revved the engine and it stayed rock solid! Then backfired and scared the shiz outta me. But I still havent done timing yet because apparently no one in the state of NY has a timing light taht works
Was it the pump? Was it the radiator cap? Tstat? Dunno, but 80$ later and everything seems to be working just fine.
Temps lookin mighty fine
The old 195 Tstat, for reference, it was pretty nasty and stuck in there.
Old 08-13-2014, 02:34 PM
  #122
Joe Tag's Avatar
I'd bet dollars to donuts it was the cap. You can put it back on and test the theory.
Old 08-13-2014, 02:40 PM
  #123
tyeo098's Avatar
Car: 88 Chimera
Eh, The old pump was pretty corroded anyways, and looked pretty old. It was probably going to fail soon anyways. Now I got one with a lifetime warranty!
I tested the old cap, and the engine got a bit hotter, but I shut it off since I don't want to idle away too much gas so I can go on a cruise later up and down the driveway and test how it does at speed.
Old 08-13-2014, 02:53 PM
  #124
Joe Tag's Avatar
Good way to look at it. In hindsight though, the cap held no pressure like that. When the pump sucked through the radiator the pressure was lower than the outside so it collapsed.
You were running good temps the whole time. The coolant just boiled at a lower temp at atmospheric pressure than it would at 16lbs. You will be fine IMO. Timing, and find out how that fan is run. If it doesn't have a relay operating it you can burn your car up.
Old 08-13-2014, 03:07 PM
  #125
tyeo098's Avatar
Car: 88 Chimera
Makes sense. Well now we can all better help the next guy Thank you for all your help!
So about this fan, would I start by unplugging or shorting the relay?
Should the fan come on when the car is off but keyed to 'ON' position?
And it seems my headers, Casting #10110810 are LO5 350sbc swirlport headers. Primary purpose: Boat anchor. Awesome.
Old 08-13-2014, 03:20 PM
  #126
Joe Tag's Avatar
You're welcome, sorry we got sidetracked.
As for the fan. Only when it's up to temp. If it comes on with the key when cold it's wired direct. Could have run a ground to trip the relay which would be ok (sort of). Also could have run a hot wire from the ignition to the fan, most common way people do it and very not ok. The relay should be mounted to the A/C box.
Old 08-13-2014, 03:23 PM
  #127
Joe Tag's Avatar
The sensor you see in the left of this pic is the one that controls the fan. The wires could be connected together somehow to make the fan come on too.
Old 08-13-2014, 03:29 PM
  #128
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
wouldn't it be a lot better to just replace the relay and the sensor with the correct parts? who knows, it might just work as designed.
Old 08-13-2014, 03:32 PM
  #129
Joe Tag's Avatar
Trying to figure out why it is constantly on. The PO may have jumped it to keep the fan on BC the thing was boiling over. The system may be functional when it's hooked up right. Trying not to throw money at it randomly since I'm sure a teen has little to waste.
Old 08-13-2014, 04:25 PM
  #130
tyeo098's Avatar
Car: 88 Chimera
And I'm listening very carefully since I just dropped 80$ on a water pump and friends when a 7$ radiator cap was the culprit
Here's the mapping of the fan relay
C A
F E D
Lines indicate which pins are connected internally (at least that multimeter cans till do that)
That look right?
Oh and I just got back from a drive and there were no bubbles when I was done!
Old 08-13-2014, 04:40 PM
  #131
Joe Tag's Avatar
They are pinned out to A, black and red 12v+ Supply to fan, E,orange 12v+ constant, F, Green/white ground signal from the ECM & coolant fan switch & D, brown 12v+ hot with ignition on. Just went through this the other day, if A and E are connected internally, relay may be bad or jumped inside. Check with the plug disconnected from it and check the A&E pins on the plug. Check F for resistance to ground on the plug.
Old 08-13-2014, 05:01 PM
  #132
tyeo098's Avatar
Car: 88 Chimera
I hope this makes sense.
Both D and F are grounded, but one has a higher resistance to ground than the other.
Old 08-13-2014, 05:06 PM
  #133
Joe Tag's Avatar
Sorry A&E won't be the culprit, that would keep the fan on without ignition. Looking for F grounded or A hot with ignition and relay unplugged. Unplug the sensor on the intake and test resistance on the two wires of the plug to see if it is jumped along the wires.
Old 08-13-2014, 05:16 PM
  #134
Joe Tag's Avatar
So F is grounded on the plug side? Pull the connector on the sensor by the thermostat and test it again, test resistance between the 2 wires on the sensor plug
Old 08-13-2014, 05:20 PM
  #135
tyeo098's Avatar
Car: 88 Chimera
Oh, and all these tests are done with the car and key in OFF.
Old 08-13-2014, 05:31 PM
  #136
Joe Tag's Avatar
PM sent
Old 08-13-2014, 06:32 PM
  #137
tyeo098's Avatar
Car: 88 Chimera
So moral of the story:
Pin F on the relay was grounded to the chassis via some random wire installed by PO, aka Red Neckerton.
This wire being important as when it is grounded the fan starts.
So I need to figure out where pin F was SUPPOSED to connect to, and reconnect it there.
Old 08-13-2014, 06:43 PM
  #138
tyeo098's Avatar
Car: 88 Chimera
Aha! I think.
Bottom right, it does connect to the ECM. I'm guessing rando wire that was shorted to ground was actually supposed to connect to pin E8 on the ECM, with the other side of the relay being connected to 'HOT IN RUN'
Now I just have to find out where the ECM and E8 are... and mate the 2 back together.
Old 08-13-2014, 07:02 PM
  #139
Joe Tag's Avatar
You said it was an 88 89? throttle body. Diagram says it has a single wire temp switch. It would be in the passenger side head between 6&8 plugs not ECM controlled. If it's there connect the black wire you took loose to it and you're good.
Did I give you another diagram than this one?
Old 08-13-2014, 07:10 PM
  #140
tyeo098's Avatar
Car: 88 Chimera
This? Its so far down the only way I figured it was there was by sticking my phone down between the wheel well and the engine and snapping a pic! In order to connect it I'd probably have to pull the engine out! lol
Old 08-13-2014, 07:12 PM
  #141
Joe Tag's Avatar
BINGO Now you need a connector
Old 08-13-2014, 07:15 PM
  #142
tyeo098's Avatar
Car: 88 Chimera
This?
http://www.summitracing.com/parts/pc...kzQaAs7g8P8HAQ
Order of business tomorrow is to do this and get the casting number.
I'm starting to get the feeling its a '94 C2500 350TBI Truck engine, based on the headers at least. Its def. not the original engine.
Old 08-13-2014, 07:18 PM
  #143
tyeo098's Avatar
Car: 88 Chimera
Wait, isnt that the knock sensor?
Old 08-13-2014, 07:22 PM
  #144
Joe Tag's Avatar
That's it. You can hook the black back how you had it for the time being. Naturally, be prepared for it to run a little hotter with the fan not constantly on. .
This is one too
http://www.ebay.com/itm/Coolant-Fan-Switch-Connector-Pigtail-Wiring-88-92-TBI-Temperature-Camaro-/121256701898?pt=Motors_Car_Truck_Parts_Accessories&hash=item1c3b766fca&vxp=mtr
Old 08-13-2014, 07:24 PM
  #145
Joe Tag's Avatar
Knock sensor is in the block not the head
Old 08-13-2014, 07:31 PM
  #146
TheExaminer's Avatar
Car: 92 Formula WS6, T-top
Engine: 5.7L T.P.I.
Axle/Gears: Limited slip, 3.23 10 bolt
This is one too
Coolant Fan Switch Connector Pigtail Wiring 88 92 TBI Temperature Camaro | eBay
Yip. I bought that exact connector a few months back because my secondary fan was running all the time. The old one crumbled in my hand when I took it off, and had insulation missing in parts of the wires. "Well THERES yer problem......." The hardest part was trying to marry the car wires to the new connector. Not much room to move around down there.
Old 08-13-2014, 08:28 PM
  #147
tyeo098's Avatar
Car: 88 Chimera
What are the downsides to having the fan run all the time?
Will it affect highway driving or something?
Old 08-13-2014, 08:51 PM
  #148
Joe Tag's Avatar
If it runs too cold, poor(er) mileage, more stress on the alt, possible fail on emissions if you have them in your state, damage the cat with more unburnt fuel, condensation in the oil. Running too cold can be damaging just like too hot on a daily driver, especially if you winter drive.
Old 08-13-2014, 09:17 PM
  #149
Car: 86 IROC
Engine: 5.0 TPI
well having it "correct" is WAY more satisfying than ... the other option. try and remove as much of "Mr. Neckertons" fixes as you possibly can. the obvious reward is not having to constantly be noodling with it. cuts down on creative profanity too!
Old 08-13-2014, 11:43 PM
  #150
Engine: 5.7L T.P.I.
....not to mention premature fan motor burnout.... I didn't like mine doing that either, so I fixed it. I think the guy who owned my car was cousin to the guy who worked on yours. They did their own kind of fixes. I found a bolt stuck in the end of the vacuum line that runs into the heater bypass valve. Apparently, something was wrong with the controller, and this is the only way they could get the heater to work. Joy. They also moved the top hinge of the drivers side door backward 1/8" and shimmed the bottom hinge to match, mis aligning the entire door for no apparent reason. I still have no idea whatsoever why, because I took the shim out and moved the top hinge back, and it looks fine now. Whatever they did had window alignment, latch and everything else about the door screwed up. People just slay me sometimes. If you're going to fix it, fix it right.
Quick Reply: Apparently I got screwed...
