Baseline Service Help
Greetings all, just picked up an 89 IROC convertible survivor with 17K on the odometer. Want to do a few baseline services but am finding the Official GM manual lacking in a few bits of info. Maybe you guys can help
Anyone know the approximate capacity of the power steering fluid? I don'twant to overbuy the pricey GM fluid.
Since DEXTRON II tranny fluid is no longer made, what should I use? Should Ihave it flushed by a machine and exchanged or just drop the pan and change thefilter and re add fluid. I'm not too keen on mixing different versions offluid.
I already have the fuel filter changed and am going to flush the brake fluidand coolant.
Car is minty fresh and just want piece of mind in regards to her service. Anythingyou all could add or recommend is appreciated.
JOn
JOn
Received 1,672 Likes
Re: Baseline Service Help
No need to buy GM PS fluid. Any brand will do just as well. Total system takes something near 2 qts.
Any commonly available Dexron ATF will work fine. Again, not critical what brand or any of that. As far as flushing, that depends on what what's there now, looks like. Be on your guard though: the places that flush it are transmission shops, and they REALLY like to sell transmissions, so don't be too surprised if they (a) refuse to do it because it's too old, or (b) put the hard sell on you, or (c) "accidentally" do something spurious to it that causes you to need a new one real soon.
Pan drain takes around 6 qts. Mixing doesn't matter.
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
If you are going to flush the power steering system, buy a gallon. If you are just topping off, a quart will be more than sufficient.
Use Dextron III. Do NOT flush the trans. I have always found that to be a bad idea......
With that few miles, it has apparently been sitting for quite a while.... wouldn't hurt to change the fluid in the rear diff, repack front wheel bearings, etc.
Thanks for the info guys. I think a pan drop and tranny filter change is what I will do. As for the rear dif, I have to hit that as well. I read in the manual about the need for an additive. I'm not sure what rear end the car has. The window sticker was not with the car.
Also, do you all know what temp the thermostat is? I figured I'd swap that out too while I had the coolant drained. The car is a TBI 305 Auto.
The guy I bought if from drove it 2k in four years. He bought from a fancy classic car dealer in NC with 15K on it. It has original paint, top and interior and looks brand new.
Just plan to go thru it, keep it nice and drive it when I can.
Engine: 5.7 TPI
I *Think* it's 195, but, don't quote me on that. Your local parts store will know. Don't bother with the 'failsafe' 'stats, they fail in pretty short order.
Check the tag on the rear diff. Might be two of 'em.... one should tell you the gear ratio, and if it's LSD, there will also be one referring to that. Just to be safe, I always get the gear lube that already has the additive in it.
Drop the pan and change the filter. I wouldn't bother with a flush or a fluid exchange. I would use Dexron VI. It's backward compatible with Dexron II. No issues with mixing different versions.
