Fuel Filter Replacement; how often
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Guys, I have TPI in my 87 Monte Carlo SS. It has been at least 3 years since I installed the motor and I have never replaced the fuel filter. She gets about 500 - 1000 miles a year, during the summer, and is in storage winters. I use Stabil during the winter storage. How often should I replace the fuel filter?
Thanks,
Fred
Thanks,
Fred
Re: Fuel Filter Replacement; how often
I looked through the maintenance schedule for the Camaro and it doesn't even list a replacement interval for the fuel filter.
I've found that when crank times get longer than "normal", replacing the fuel filter restores it back to "normal". I have no idea how long this takes.
I'd replace the filter every 30k miles with fuel system inspection. More often if you feel like it. Filters are relatively cheap enough.
Car: '87 FIREGOOSE!!!!
The late, great John Lingenfelter said he changed the fuel filter every time he did maintenance on a vehicle, cheap insurance. So I try to do mine every year. Barely drive it, so change the oil/filter start of every summer and fuel filter too.
John was a guru and legend, guys like that give pointers, easy to follow it.
Transmission: 2004r
Thanks guys. Easy enough to change it every year prior to the summer driving season.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
When i was at gm it was every 15k
