Difference Between 85-88 and 89-92 Fuel Rail Tube Kit for Yellow 92 GTA resto
Car: 91 GTA & 92 GTA & 92 GTA
Engine: 305 TPI & 350 TPI & 350 TPI
Axle/Gears: 3.42 & 3.23 & 3.23
I am in the process of doing a partial engine bay restoration on my Jamaica Yellow 92 GTA 350. I have acquired almost off the parts needed to build a new fuel rail but one part I have had difficulty acquiring is the tube kit, part #: 17113253. I was wondering if the 85-88 tube kit would be 100% identical other than a couple extra seals for the cold start injector. It is part number 17113252. Thanks.
Re: Difference Between 85-88 and 89-92 Fuel Rail Tube Kit for Yellow 92 GTA resto
The book lists the contents of the tube kit or pipe kit, but it doesn't differentiate the contents of the two part numbers. Basically the kit is just the crossover tubes, O-rings, and tube clamps.
Gotta admit, I've never even heard of anyone having the tubes and clamps fail, which leaves the O-rings which should be easy enough to come by.
Car: 1989 Pontiac Formula 350
Axle/Gears: BorgWarner 3.27 Posi
Why do you always mention the color of your car in your posts? No offence, but nobody cares what color it is when we're answering questions about fuel lines.
Engine: 4++,350 & 305 CIs
Because Jamaica Yellow rocks !!!
