leaking speedo sender
Old 12-01-2008, 07:48 AM
maroon88iroc's Avatar
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
anyone else have this problem? i am using a t5 with a cable speedometer. i bought the speedo housing new not long ago, now it is leaking where the speedo cable screws into it. i havent got it up on the lift yet, i was just curious if anyone else had this problem and what they did to fix it thanks
Old 12-01-2008, 07:54 AM
doc221978's Avatar
Car: '81 Z-28
Engine: Soon to be a 383
Transmission: Muncie
Re: leaking speedo sender
Out of where the cable comes out or around the adapter?
If it is around the adapter, just replace the o-ring. I don't remember if it is another o-ring inside along the shaft of the gear.
Old 12-01-2008, 08:19 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Yes. Sometimes when the gear shaft is installed, this seal is torn a bit.
JamesC
Old 12-02-2008, 10:09 AM
Car: 88 IROC
it isnt coming out around the adapter, fluid is coming out where the speedo cable screws onto the adapter
Old 12-02-2008, 10:27 AM
JamesC's Avatar
Fluid is leaking through and/or around the sleeve and dripping through the connection. Can't imagine where else the fluid would come from.
JamesC
FormulasOnly
07-23-2018 08:47 AM
Mark_ZZ3
05-24-2018 01:02 PM
jrdturbo
03-31-2016 02:58 PM
tommy z-28
10-06-2015 10:58 PM
mfp189
09-27-2015 09:25 AM
Quick Reply: leaking speedo sender
