S10 tranny behind a 350
I'm restoring an 85' Trans Am. It used to have a T5 behind a 305, but I was given the car with no engine or transmission. I picked up a 350 from my uncle who just so happened to have one laying around, and I need to know if a T5 out of an S10 will bolt up. I did a lot of research and I think it will swap with just a bell housing swap. I've attached a picture of the transmission. Note: I do not plan to be racing this car or driving it too hard, and I'm on a budget, which is why I'm opting for a T5 instead of a T56 or Muncie 4 speed.
Re: S10 tranny behind a 350
No S10 T5 bolts to a small block with just a bellhousing change.
Input length,
Input spline count,
Fairly easy speedometer setup,
Bellhousing bolt pattern,
Shifter location,
Torque arm hook-up,
Trans. mount location
are all matched by buying an 84-92 V8 F-body T5.
If it's not one of those, and you don't know how to change those things, then just buy what fits.
Input length,
Input spline count,
Shifter location,
Torque arm hook-up,
