Air Bypass Valve
Old 03-02-2005, 02:48 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Air Bypass Valve
I wonder how well it works.
Didn't someone here suck up a bunch of water this year????
AIR BYPASS VALVE
Protects against water ingestion!
Crafted from mineral-reinforced nylon and never corrodes
Eliminates the unlikely chance of water ingestion should the filter element become wet from deep puddles, rain, hail, sleet or snow-or any other scenario in which the filter element could encounter or become submerged in water. The valve installs along the upper portion of the inlet pipe on the same axis as the throttle body centerline. Should a drop in pressure occur within the pipe, the valve shuts down induction at the filter and routes incoming air through the valve's external orifices, eliminating any chance of water ingestion. Available in three sizes to fit every AEM intake diameter. Manufactured and assembled in the USA.
http://www.jcwhitney.com/autoparts/S...searchbtn.y=18
Old 03-02-2005, 02:58 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I just wonder how well the things flows, when its activated.
Can't really see how it works.
Old 03-02-2005, 07:41 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
That was me who tryed to make his camaro a boat
I have seen them before, but its more for splashes and mist type stuff. Where mine was, err. Basically submerged.
My friend had one of them on his eclipse and the joints kept coming loose. But I never understood how they work either.
Old 03-03-2005, 08:53 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I saw one of those in an import rag; they took an exotic car (like a Ferrari), hooked the valve up, to a wide clear tube, and stuck the tube in a fishbowl of water. Then they revved the snot out of the engine!
The car pulled water up the tube 2 or 3 feet high and they were all amazed at "how much water could be sucked in". Of course that was BS, a little elementary school science trick. (Remember cutting a drinking straw at the top, then blowing thru it, and the water would rise up in the straw?)
But all "gee whiz" demos aside, it might be a good idea, why not? I think there's just a flap in there around the edges, and it's easier to pull the flaps up then to pull water up. Know what I mean? Say you drive into a fishbowl of water (laughs)... the engine tries to breathe- and it creates a suction inside the valve. Instead of the valve collapsing, these little flaps open up. Water might rise up a little, but since water would be heavier than the flaps, the water never makes it all the way thru.
Old 03-03-2005, 12:44 PM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
i drove underwater through a flood last year car still runs fine
1992 Trans Am
05-10-2023 07:19 PM
stalkier
12-06-2015 11:25 PM
Bubbajones_ya
08-28-2015 02:17 AM
TheExaminer
08-26-2015 04:59 PM
db057
08-22-2015 08:17 PM
Quick Reply: Air Bypass Valve
