Stock Fuel Pressure for an 85 2.8 V6 TPI is?
Car: 1985 Camaro Sport Coupe
Engine: 2.8 - Bored/Stroked, Pacesetters
Transmission: 5 spd Manual
Axle/Gears: Stock
Did a search but was unable to find the answer. Any help would be greatly appreciated!!
Car: check
Engine: check
Transmission: check
Re: Stock Fuel Pressure for an 85 2.8 V6 TPI is?
With engine running and vacuum line off: 43.5 psi nominal
40.5 - 47.0 psi service range.
RBob.
RBob.
Axle/Gears: Stock
Thank you RBob!! Last question. Is the fuel pressure adjustable once the plenum/throttle body is back on? That is the only issue I foresee with getting it all set final.
Axle/Gears: Stock
Anybody know what the fuel pressure should be when not running? Mines around 45 psi when just turning the key one position prior to starting (ACC). I can hear the fuel pump energize in this key position and that's when I am getting the 45 PSI reading.
Car: check
Engine: check
Transmission: check
The 45 psi not running is OK. The reason I state running is that at key-on, engine-off the pump only runs for a couple of seconds. Hard to get a good stabilized reading.
RBob.
RBob.
Axle/Gears: Stock
Perfect!!! Thanks for all of your help, RBob!!! This community has ALWAYS been invaluable. I am now one step closer to this LONG project becoming complete.
