ATT: TomP, and anyone else intersted in fuel line patch kits
Old Nov 2, 2002 | 02:12 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
We all dread changing the fuel filter out of fear the fuel lines will break. Well, a few months ago, it happenned to me. I found some repair kits at Pep Boys, and I know Tom was curious obout them, so I finally took some pics.
In this pic you can see on the top right where the NEW fuel line attaches to the fuel filter just as the original would. On the left is the fitting that attaches the new and original fuel lines. You simply put a plumbing farrel (sp?) and nut on the lines, and tighten them onto the fitting.
(old post)
Attached Thumbnails ATT:  TomP, and anyone else intersted in fuel line patch kits-fuelline-001.jpg
Old Nov 2, 2002 | 02:13 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Anothwer view of the fitting, the curved line is new.
Attached Thumbnails ATT:  TomP, and anyone else intersted in fuel line patch kits-fuelline-002.jpg
Old Nov 2, 2002 | 02:14 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Last pic.
Attached Thumbnails ATT:  TomP, and anyone else intersted in fuel line patch kits-fuelline-003.jpg
Old Nov 4, 2002 | 12:03 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Figures. I lay down under my car in the cold to take these pics and no one appreciates it.
Old Nov 4, 2002 | 12:38 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Hey, gave me ideas for when I got to do my engine swap in the s10. How long is that tube that it comes with??
Old Nov 4, 2002 | 02:43 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Hey, thanks for the pics! (And thanks to Dale for bringing it to the top so my dumbass noticed!!) I really like how you didn't need to use any hose to make the repair.. no worries about the hose getting old and busting open. I'll have to take a trip to Pep Boys and grab 1 or 2 (or 5, haha) of those suckers. You said it was a 3/8" line, right? Did the kit come with everything? I think you said it did, just re-checking.
Hey you could probably write up a tech article and submit it to thirdgen.org !!
Old Nov 4, 2002 | 04:18 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I belive the one I used was 18", obviously I cut it. You can get them longer.
Old Nov 4, 2002 | 04:22 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
Yes, it was 3/8" line. Kit comes with everything you see in the pics. Obviosly the plumbing ferrels are under the nuts. The only additional thing I had to buy was a bender, $6 at Sears.
I also like how there's no rubber hose involved. Seeing how easily vacuum lines dry and crack, the thought of that on a gas line...
Old Nov 4, 2002 | 07:22 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I ended up just cutting both my lines and got the fuel filter with nippled ends, used some braided line and used doubble hose clams on each end. no worries mate.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
