Southern California Area Southern California Members.
cold start problem
Old Feb 26, 2004 | 02:37 PM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
cold start problem
I have a 89 gta auto with new 355 it seems only to happen when the car is cold. It runs really rough and hesitates then when it warms up its fine. It just started doing it since I just got the car fixed it had a bad fuel pressure regulator so I cahnged that and put it 24# injectors any thoughts
Old Feb 26, 2004 | 07:13 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you reprogram the PROM for those larger injectors?
Old Feb 27, 2004 | 12:01 AM
tealman92's Avatar
Car: 1992 Z28
Engine: 383
yes it has a custom burned chip specificly for my application I think i found the problem I had 2 plug wires burned on the headers and the fuel pressure needed a bump as it was I was running lean at idle so Ill try that in the morning and see how she does Ill keep you posted
92camaroJoe
Jul 29, 2023 07:57 PM
Wade787b
Sep 29, 2015 01:15 PM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
