i need LS1 wiring help
Old Jan 10, 2005 | 01:45 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
could someone help me figure this out?
i have a 2002 Fbody drivetrain, this harness thing is from a 99.. it SHOULD still be correct though.. little help?
Code:
 LS1 Harness						3rdgen wires				Question/Location
White (220) Plug
A TAN Oil Pressure					Tan oil pressure wire on 3rdgen		Stock Oil pressure wire
B GRY PCM 32 Clutch Anticipate Switch Signal								to clutch down switch. ?? what does the other half of the clutch switch goto? (doesnt need for running)
C PNK C105-B IGN Power for TCC Stop Lamp Switch		nothing on 6spd
D PPL PCM 33 TCC/Cruse Brake Switch			nothing on 6spd
E BLK/WHT Ground					ground					whatever good chassis ground is nearby
H ORN/BLK PCM 34 PNP Switch Signal								to clutch down switch. ?? I thought pin B goes there? (doesnt need for running)
J YEL/BLK Low Coolant Indicator				nothing
K DK GRN/WHT PCM 50 VSS Output				speedo pulse				speedo input wire
Blue (230) Plug
A GRY PCM 46 5V Feed (Fuel tank pressure)			nothing
B Brown w/Stripe PCM 25 MIL Lamp Control			SES light on dash				Tap into SES light in gauge cluster (reminder to self: bulb is out)
C WHT PCM 45 EVAP Canister Vent Valve Control		nothing
E Blue PCM 55 Theft Deterrent Fuel Enable			for VATS pulse (not needed if deleted in PCM)	nothing, but use HP tuners
F DK GRN/WHT PCM 17 A/C Request			nothing (AC delete)
G GRY PCM 23 Fuel Ground				nothing. fuel gauge on LS1 car.
H DK GRN PCM 64 Fuel Tank Pressure			nothing
J PPL PCM 54 Fuel Level Input				nothing
K DK GRN PCM 58 Serial Data (Class 2)			ALDL					get ALDL connector and wire this into it.
99 LS1 PCM to Front Harness
Large Plug C100 Plug
A PNK Hot in Run and Start (IGN/INJ Bank 1 15A)		+12v Ignition only power			Run from factory injector power #1(with 15A injector fuse)
B DK GRN/WHT PCM 43 A/C Clutch Relay Control		nothing
C DK GRN PCM 18 A/C Clutch Status				nothing
D GRY TPS +5v to TCS					nothing
E DK BLU TPS signal to TCS				nothing
G PNK Hot with IGN 1 Relay Engaged (Tranny/EGR 15A)		+12v ignition				Run from ignition triggered relay. (15A fuse)
H DK BLU PCM 33 Cooling Fan 2 and 3 Relay Control		nothing					Run to neg(ground) trigger of high speed fan relay (if equipped)
J DK GRN PCM 42 Cooling Fan 1 Relay Control			to GROUND on fan relay.			Run to neg(ground) trigger of low speed fan relay
K BLK TPS sensor low to TCS				nothing
C101 Plug
A YEL/BLK Low Coolant Sensor				nothing
B PNK Hot in Run and Start (IGN/INJ Bank 2 15A)		+12v Ignition only power			Run from factory injector power #2 (with 15A injector fuse)
C BRN PCM 36 Air Pump Relay Control			nothing
D DK GRN/WHT PCM 9 Fuel Pump Relay Control		Ground Trigger for fuel pump relay		Run to neg(ground) trigger of Fuel pump relay
E PNK/BLK PCM 19 Ignition Positive Voltage for PCM		+12v Ignition only power			Run from factory ECM power
G ORN PCM 57 Battery Positive Voltage for PCM		+12v hooked straight to batt via inline fuse.	10A fuse
H BLK/WHT Ground					ground					Run to chassis ground.
K GRY/BLK PCM 53 TCS Spark Retard Signal to Brake Control Module	nothing
C105 Plug
B PNK Hot with IGN 1 Relay Engaged (TCC Stop Lamp Switch/MAF/O2 20A)	 + 12v				Run from ignition triggered relay. (20A fuse)
D DK GRN PCM 37 Cruise Control Inhibit			nothing
F WHT PCM 13 Cruise Engaged Signal			nothing
G WHT PCM 10 Tach out to Brake Control Module		this is what goes to the Tach (and tach signal driven components) Connect to Tach wire
H PPL PCM 4 AIR Solenoid Relay Control			nothing
Old Jan 10, 2005 | 01:57 PM
Ace's Avatar
Ace
Car: 92 quasar gta
Engine: Nothing
Transmission: Nothing
Axle/Gears: 4.11s
which ecm do you have.. the 99 or 02? the drivetrain shouldnt matter unless the sensors have changed between 99 and 02
Old Jan 10, 2005 | 02:21 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
everything i have is from a 2002... the pinout chart i got that from is for a 99 but ive been told that the 99-02 connector pinouts are the same except for EGR.
Old Jan 10, 2005 | 06:50 PM
StngKlr's Avatar
Car: 89 RS
Sent PM. Should we copy and paste it in here, or will you sort it out up top?
Old Jan 11, 2005 | 08:18 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
i think i sortted it up out top.... i did have a couple more questions i asked in a PM...
but i changed what you told me.
thanks dude.
Old Jan 11, 2005 | 08:26 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
the only pins in question now are 220-B, 220-H, and the other half of the C105-B circuit.
C105-B trips a relay for the MAF and O2s... but where does the power that relay is switching goto?
Old Jan 11, 2005 | 01:52 PM
StngKlr's Avatar
Car: 89 RS
220 H - I didnt use so...
220 B - I have an auto, didnt use...
Maybe theres a misunderstanding, but C105 B does not trip a relay, but recieves power FROM a relay to supply power for those 3 things.
Wiring is so hard to explain to someone face to face, let alone over the net. Please tell me you guys are getting this.
Old Jan 11, 2005 | 02:06 PM
StngKlr's Avatar
Car: 89 RS
This where the 3 front LS1 harness connectors used to be. I think the best thing to do is get the other side of the connectors with the wires cut off and make your splices there. Its something I didnt do, just got in too much of a hurry. The 220 230 connectors will route inside the car, just use the factory hole in the firewall where the stock HVAC wires go into the car for those. Then all of my relays are wired up in the factory location on the drivers side, and I think 5 or 6 wires run from there to the PCM to tie everything in. I hope this helps a little more, and dosent confuse.
Old Jan 14, 2005 | 03:04 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ok, ive decided to drop the idea of keeping the OEM connectors...mostly because getting connectors that plug into there is a total PITA.... i am however going to use weatherpack connectors between the harness and car.
now theres several ways i can do this.. im posting this up because im looking for feedback and ideas:
method1:
put only the used wires in each OEM connector to each weatherpack connector
example:
220 would have 5 wires used - so the5 would be on one weatherpack connector
230 2 wires
C100 would have 4 wires
C101 5 wires
C105 2 wires
method2:
sort them by logic
one connector has gauge outputs: oil pressure, water temp (stick 98 sensor into engine harness), tach, speedo...
one connector has remaining outputs/inputs: fan triggers, fuel trigger, backup lights,starter
final connector is bigger with main power feeds: injectors/coils, constant ECM power, ign ECM power, MAF/O2, ect...
method 3:
sort them by physical layout
these wires are close together so they goto connector A, ect... i dont have it here to see whats "close", so i would be working that out when i get there.
anyone have some feedback? im kinda leaning toward option #2 right now. athough i can see how option1 would let me "trace back" my wiring easier......
Old Jan 15, 2005 | 03:29 AM
StngKlr's Avatar
Car: 89 RS
I think either 1 or 2 are very good ideas. In my case I just have to undo the big red and blue connectors at the PCM to trace/test any wiring, should I need to. Having those connectors will save a little bit of time down the road.
Caspar
Jun 19, 2016 11:19 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
reiderz iroc
Aug 13, 2015 04:57 PM
