Underdrive Pulleys March New In Box
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
I AM SELLING MY SET OF MARCH PULLEYS.
DON'T SETTLE FOR CHEAP IMITATIONS!
BRAND NEW IN BOX. $90 SHIPPED.
I ACCEPT PAYPAL TOO.
CHECK OUT LINK BELOW.
PART # MCH-4400
Designed for superb performance.
March Performance Late GM Power and Amp series pulleys are designed to give superb performance, while maintaining perfect electrical charging, even at idle. They create about 11 HP at the rear wheels by reducing accessory drag. These pulley kits are ideal for vehicles with high amperage needs, such as towing or heavy stop-and-go driving.
http://www.marchperf.com/pg1.html
PART # MCH-4400
Car: '89 GTA
Car: Moving...
Engine: Running...
Transmission: Shifting...
No disrespect intended but Summit Sells the same kit for:
MCH-4400 $94
Jeg's has it available for:
655-4400 $94
Both of course have free shipping at the moment as well. I would certaintly be interested if the price savings over purchasing them brand new would be greater.
MCH-4400 $94
655-4400 $94
Car: '89 GTA
No disrespect received, but Summit sells the part for $94.88, and is on backorder till 7/18 at least.
I'm saving folks 5 bucks and will ship asap for free too.
Can only give so much of a deal on brand new parts.
It's not like the part has depreciated in value as a used item.
Car: 86 camaro
Engine: 350ci (245hp model)
i would like to see pictures and if i like them i will definatly buy them i got first dibs. shaddow_wolf169@hotmail.com
Car: '89 GTA
You can see what they look like at the page above or at the summit page.
http://store.summitracing.com/defaul...=egnsearch.asp
Let me know.
Let me know.
Car: Moving...
Engine: Running...
Originally posted by BlackphantomZ28
hmm it says on the site recommened for automatice tannys err what if you got a manual does it matter?
Car: Hers: 88 Formula 350
Engine: TPI
Axle/Gears: 10 bolt Posi
i guess they say auto recommeded because of the slower alternator speed
with a stick, i think your idle is slightly higher
or you can compensate with a slightly higer idle
hence the reason for the 1-2hp diff between the 2 kits
(unless the water pump pulley is smaller too)
none the less
auto or standard it should be fine
not sure what size belt it would need
personally
i love under drive pulleys for:
the few extra ponies
better gas mileage
nice looking
draw back:
low alt outputs at idle,
could over heat or get hotter (i know debatable)
these are results i gathered from putting them on my 79 TA and her 90 V6 3.1
it was an awesome gain on the 3.1 (10 hp to a V6 is alot, 10hp on an 8, ehhhh debateable)
on my TA, i did get hotter (true adding a 4 core rad, and hi out water pump helped (additional $$) and output at idle sucked badly
but a 140 amp alt helped, not alot, but it helped.
i used to use the pulleys on her V6 cause it really help mileage on trips, and gives that extra power when passing on the highway.
i've also used a stock alternator pulley too, and the idle output wasn't as bad. i just find EFI cars way more sensitive to lower alt outputs (the ECM's like solid voltage)
i am trying to see if this kit needs a shorter belt, i spend some good $$ on my goodyear belt.
none the less
personally
better gas mileage
nice looking
draw back:
Car: 91 T/A, 79 T/A
Engine: 305 TPI, '68 350 Olds SC'ed
Transmission: 700r4, 350 Streetfighter
Axle/Gears: stock, 3.42
Yeah, I put the March pulley kit on my motor. Now I just need to know what belt to get now. I measured the stock one, and it is 95". After the new crank pulley and alt. pulley was installed, I put the stock belt on. It is very loose, so I tried to measure that slack, which is about 2" roughly, but that is with the belt tensioner all the way down too. So I'm guessing take away 2 or 3 more inches for that. I think I'd need a 90 or 91 inch belt. If anyone knows for sure, please chime in.
Car: Caprice wagon
Engine: 5.7TBI
DJ
Car: 91 T/A, 79 T/A
I actually found along enough string and ran it like a belt and I got 91". I bought a 91" belt and it seems to work fine so far. Next it getting rid of the smog pump and the A/C dummy pulley, so I'm going to have to drop another $30 on a belt again here in the near future. Oh well. Thanks though.
Car: '89 GTA
haha, you dork.
i sold those back in July for like $90.
you can keep your $20, lol.
you can't even buy a cheapo set of crappy ones on eBay for that.
Thirdgen89GTA
Nov 26, 2015 11:04 PM
bigjay89gta
Oct 15, 2015 08:04 AM
