Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Proform Distributor
Old Apr 23, 2002 | 06:27 PM
brian89transam's Avatar
Proform Distributor
From Jegs
-$170
I figure why buy an ignition box when you can get a whole distributor for $170. Would I see an improvement on a basically stock motor? (with a high output coil, plugs, and 8mm wires)
Old Apr 23, 2002 | 07:00 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
You are right. The Proform distributor is a good deal. I use the coil myself.
Old Apr 23, 2002 | 07:37 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
proform is cheap. for a little more money you can get a pertronix or msd distributor. also, there is a large difference between distributors and ignition boxes. a box will give you better combustion, a good distributor can do that too, but the proform is probably more like a step above stock replacement.
Old Apr 23, 2002 | 11:00 PM
Mark 89Formula's Avatar
Second what unknown_host said except it's not as good as OEM. Put one of their small cap distributors in my car and the module crapped out on startup and the baseplate that holds the module worked loose from the main body when trying to set the timing for the first time. Returned it for credit, got a stock rebuild, and was much happier.
Old Apr 24, 2002 | 02:10 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I wouldn't pass up an ignition box for a dist. I have the kit from Proform that includes the cap, rotor, coil, module, and advance kit. It has worked flawlessly for me since I put my engine in. I have buzzed the car to 6800 a few times, and it hasn't so much as popped once. I am very happy with it. If I was comparing a box to a dist. though, I would get the box.
Old Apr 24, 2002 | 03:01 PM
Karps TA's Avatar
Car: 1985 Trans Am
Axle/Gears: 3.70
I would buy a good coil and a set of wires before doing either. You'll see more of a difference from that alone than either of the others.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
