Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD adjustable Timing Control
Old Mar 15, 2001 | 08:55 PM
Havoc's Avatar
Anyone considering getting this I highly reccomend it.It easily allows you to advance or retard timing from the drivers seat.It really helps if you have to buy cheap gas in a pinch.If anyone has installation questions send me an Email.If I cant answer I know MSD tech can help he answered me all my questions.
Old Mar 22, 2001 | 11:39 AM
FastBroker's Avatar
I have been using these items for YEARS and they are AWESOME! Extremely helpful with PROM tuning on computer-controlled distributors, too, when used along with MSD's Audible Knock Sensor.
Old Mar 22, 2001 | 07:24 PM
bad camaro RS's Avatar
what timming i jus got mine today but to my understanding you can jus retard your timing can you also use it to give u more advance? thanks
1992 camaro RS
195cc AFR heads with compition port work milled to 58cc "10-1 compression"
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.65 full roller rockers
497-510 LIFT 214-220 duration
msd6AL
1 3/4 hooker long tube headers
4" mufflex system
k&n filters gutter air box gutted maf"no fins no screens"
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit edelbrock water pump
new best ET 13.5 @104.66
no times with new afr heads hoping for 12's on motor
Nos installed but no times yet
about:blankhttp://www.nav.to/badass355tpi
Old Mar 22, 2001 | 09:03 PM
Havoc's Avatar
Yes you can use it to either advance or retard it depends on where the rotary **** is when you install it.For example if you set it up where the **** is in the middle which is 7.5 degrees you can then advance or retard 7.5 degrees depending on which way you turn the ****. Hope this helps clear things up.
Old Mar 30, 2001 | 01:34 PM
FastBroker's Avatar
I got mine years ago and I think youare right in that they did not describe how to make it "advancing"... I believe this was for lawsuit purposes, my friend. 15deg of possible advance could cause a serious hurtin'.
As stated above, you are supposed to install it with the **** at "0" retard (all the way counter clockwise) and set your initial timing as you would normally. Then, when you crank the ****, you RETARD the timing. You can only turn the **** towards retarding (clockwise) with this method of installation.
What you CAN/could do is set the **** to, say 5 degrees of retard and THEN installing it by setting your initial timing normallly, as you did above. Now, you have 5 degrees of possible advance (turn **** counter-clockwise) and 10 degrees of possible retard (turn **** clockwise). Get it? Pretty cool, eh?
[This message has been edited by FastBroker (edited March 30, 2001).]
9192camaro
16
Feb 3, 2019 12:21 AM
toronto formula
Nov 10, 2015 06:17 AM
midias
Aug 15, 2015 05:07 PM
tartagliaz28
Aug 15, 2015 10:59 AM
