Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
vortec heads.
Old May 8, 2001 | 02:01 PM
cursedz28's Avatar
vortec heads.
Im planning on buying vortc heads from Jim pace. My question is 10.2:1 compression too much for them. Also what would be a good cam with 1.6 rockers for road racing.
Old May 9, 2001 | 05:15 PM
JoelOl75's Avatar
Car: 88 Firebird WS6
You're 'on the edge' with compression, but running high test you shouldn't have any problems.
Old May 9, 2001 | 07:29 PM
Ray87Z's Avatar
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I run 10:1 approx and haven't had any problems w/ mine.
Just to make sure you're not buying the redrilled Vortecs from Jim Pace are you? If so don't, bad idea. I'll go into it if you were planning on getting those...
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Old May 9, 2001 | 07:34 PM
JJ's Avatar
JJ
Ray, I'm not in the market of any more vortec heads, but would like to know more about the re-drilled heads you are talking about. Thanks
Old May 9, 2001 | 08:43 PM
Joseph@SDSC's Avatar
Run 10.5-1 with mine. No problems.
The stock intake manifold ports will not line up with any redrilled vortec heads. The ports are taller, and kinda resemble the ports on the LT1 engines. There may be certain aftermarket manifolds that have enough metal to cover the port, but why run vortec heads if the port is going to be restricted by not lining up?
-Joseph
ASE Master Automobile Technician
Scoggin-Dickey Chevrolet
1967 Camaro (Vortec Heads, GM ZZ4 intake manifold, ZZ4 roller camshaft)
1992 Firebird (Weiler Vortec Heads, LT4 Hot Cam, GM ZZ4 Intake, Edelbrock 750, eventually will be Ram-Jet)
Old May 9, 2001 | 09:25 PM
Ray87Z's Avatar
Car: 94 Z28
Axle/Gears: 3.23s
He covered the main part. You're not gaining anything w/ the heads if your intake ports don't line up, and there isn't alot of material to be matching w/ there on most intakes. Some intakes apparently won't even cover the freaking ports (pics someone posted were of this). Once you have redrilled the holes the threads you end up with are not very deep either. You could easily have some problems striping them out as well. The guy I knew w/ the redrilled heads had this problem.
There is already a TBI and several carb intakes for the vortecs, and the TPI intake will be out soon so everyone should stay away from the redrilled heads...
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
[This message has been edited by Ray87Z (edited May 09, 2001).]
Old May 10, 2001 | 11:03 PM
drain89's Avatar
Car: 02 WS6 White/Ebony
Axle/Gears: Stock 3.42
Yeah right! I don't believe that SDPC is gonna release the TPI vortec manifold anytime soon...remember they said October 2K and it's now into May. I'm callin' bull**** on their manifold being out soon. I wish edelbrock (who makes it) will just sell the damn thing outright and forget about the middle man. I think we should rally together and bug them (edelbrock) until they do.
"Draino"
gixxer92
May 18, 2017 11:20 AM
69GTOby
Apr 18, 2016 02:34 PM
Chas91Z28
Oct 22, 2015 10:12 AM
monte87cortez
Sep 26, 2015 08:10 PM
BLK87Z
Sep 18, 2015 11:29 PM
