Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
this do any good?
Old Nov 18, 2002 | 12:24 AM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
this do any good?
I have a stock (as far as I know) 305 TBI and am looking to upgrade the engine.....is this gonna help/worth it???
http://store.summitracing.com/partde...rt=14469&v=EDL
thanks!
Old Nov 18, 2002 | 09:08 AM
HamSpiced's Avatar
Car: 89 Camaro I-Roc z
Transmission: Th700r4
a pal of mine just had a new camshaft put in. he did a neutral drop at about 35 and twisted his frame like a pretzel. do a search for subframe connectors, strut tower arms and stuff or go to the suspension and chassis sections they got some awsome ways of making the frame sturdy.
Old Nov 18, 2002 | 11:36 AM
x_wolf's Avatar
Car: 91 Camaro RS
changing the camshaft can affect it THAT much? MY ***.....I hadn't realized it coulddo that much thats amazing...so what is it just addnig a helluva lot more torque? or HP or what? Also how the hell can it bend a steel frame!!!!
laters!
Old Nov 18, 2002 | 01:15 PM
MdFormula350's Avatar
Originally posted by HamSpiced
a pal of mine just had a new camshaft put in. he did a neutral drop at about 35 and twisted his frame like a pretzelways of making the frame sturdy.
neutral drops are not good...
Old Nov 18, 2002 | 04:20 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Looks like a flat tappet cam... and the figures aren't any better than the LT1 cam really. If you've got a roller block, then save yourself about $65 and just buy a used LT1 or LT4 cam. You might see 25-30hp more with stock heads 30-40 more if you've got aftermarket heads. Changes will be more dynamic if you have the exhaust done as well.
Old Nov 18, 2002 | 04:26 PM
x_wolf's Avatar
Car: 91 Camaro RS
ok since Im new to all this, can someone explain to me the cam meanings and why you have to have new heads and stuff? I really wanna learn, could you maybe point me to some good websites?
thanks!!!
Old Nov 20, 2002 | 03:05 PM
Shagwell's Avatar
Car: projects.......
Duration - how long(measured in degrees) the valve is open
Lift - how far the valve opens
Duration @ .050 - actual duration, with normal cam install(more important #) - the larger the duration, the higher RPM your power band will start and end.
A stock cam is tiny. Better used as a bat. A TBI intake's power band is low. If you have a stock hydraulic roller, then stick w/ the roller. Then you don't need lifters, just the cam.(use your old)A roller will make more power, run smoother, and give you a wider power band. Horsepower is made by achieving the maximum ratio of air/fuel in and out. That maximum depends on your engine. A large cam on stock heads will defeat the purpose, because the cam is allowing for more air/fuel than your heads can flow. I'd look into Comp Cams. They make a quality cam. Give them a call. They can recommend a camshaft that will suit your set-up.
later, justin...
Old Nov 20, 2002 | 10:43 PM
BikertrashDude's Avatar
stupid
"A stock cam is tiny. Better used as a bat."
thats funny
biker
Old Nov 21, 2002 | 11:23 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
do a search on the classifieds board for my name . i only had to posts in there but i have an edlebrock cam for u to use and lifters that are used but in very good shape. check it out for the specs
here it is
Old Nov 21, 2002 | 02:58 PM
CHRISMAN2000's Avatar
Car: 1991 Camaro Z28
Engine: 350 L98
What your going to want to do is search for a cam that best suits your needs. Go check out comp cams and crane cams web sites. See if they have any high performance cams made for your 305.
E-mail Them or even phone them and ask as meny questions untill you fill happy about your choice.
If you don't mind spending a couple of bucks get your heads ported and polished. And have a 3 angle valve job don on your valves to.
By then you'll start noticing some nice improvements. Then later add some headers and a free flowing exaust.
Old Nov 22, 2002 | 01:33 AM
firebirdpl's Avatar
Car: 89 Formula
Engine: 305 TBI
your better off soing exhaust first, headers and a catback with a high flow cat will be a great improvment, and help all other upgrades, such as cams and heads
Old Nov 24, 2002 | 06:34 AM
philoldsmobile's Avatar
Car: 2009 Volvo V50 R Design
Engine: 2.0 turbo diesel
Transmission: 6 speed auto
Axle/Gears: yes, both
Uh, what's a neutral drop?
Old Nov 24, 2002 | 07:40 AM
ddamm's Avatar
Reving your motor up into its torque range or beond while the cars in N and then droping it down into drive.
Even more brutal is the old R to drive.
Old Nov 24, 2002 | 11:53 AM
oooooooooh that's a bit harsh isn't it?
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
