Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
Roller Cams
Old Jun 5, 2001 | 08:59 PM
85T\A's Avatar
Roller Cams
Has anybody put a full roller valve train in a LB9 what was the out come what kind of gains did you get?
85T\A 305 TPI Auto WS6 3:43 Edelbrock TES headers Jet Hot Coated,Air Foil,Hooker CatBack,SFC's,STB,AFPR,B&M Mega Shifter Ported Plenum&Manifold,High OutputCoil,Accel8.8,wires,180 deg stst,53000 org miles
Old Jun 7, 2001 | 09:46 PM
Dan87IROC-Z's Avatar
The LB9 is just about a full roller valve train. The only thing that isn't roller is the rocker arms, but that can easily be changed for about $200.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Borg Warner 7.75" 9 Bolt Rear End with 2.77:1 Gears.
Current Mods: LT4 HOT Cam, Comp Cams 1.52:1 Roller Rocker Arms, Edelbrock TES 1 5/8" Headers, Catco High-Flow Catalytic Converter, Hooker 3" Aerochamber Cat-Back System, Transgo Shift Kit, Performance Resource Chip, Accel Ignition, K&N Filters, JET TPI Air Foil, All Free Mods, Falken ZIEX Z-Rated Tires.
Best ET (w/o LT4 cam): 14.32 @ 97.7mph
(corrected for elevation)
Soon to Come: 7.625" 10 Bolt with 3.42s and Accel TPI Intake Base
Old Jun 16, 2001 | 12:07 AM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Not the 85 & 86 LB9's.
86 T/A 5.0 A4 & 2.77 gear
15.62 @ 86 mph
93 Civic 1.6L
13.5 @ 100 mph
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
