New Head Problems
Car: 2001 VW Passat
Engine: 1.8 Turbo
Transmission: Automatic 5 speed with Tiptronic
Axle/Gears: Stock
New Head Problems
Hey, I just put new pocket ported heads on my 305. They have 1.94/1.50 valves and Z-28 springs and comp 1.6:1 ratio roller rocker arms. Well, it now seems the engine is bogging out. How could i adjust the timing or the carb which is an Edelbrock 600 cfm. Could the T.V. cable be loose or need adjusting..becuase the tranny doesnt shift like usual....but the problem is really off-idle to mid, then its all good. Thank you.
cory
cory
What's your timing set at? I usually run about 36@WOT. It sounds to me like your timing may be lazy and when you mash the throttle you don't have enough advance w/o the vaccum.
Car: 2001 VW Passat
Engine: 1.8 Turbo
Axle/Gears: Stock
Hey Guys. I got the timing where it should be and I had the distributor recurved by a friend. The T.V. cable was readjusted and the car is running excellent. Thanks!
84z96L31vortec
Aug 20, 2017 12:16 AM
theshackle
Mar 5, 2017 06:37 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
