problem with MSD coil
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i got an MSD coil and installed it. i took the car out for a test drive. everything seemed to work fine. when i brought the rpm's up i noticed that the tach will not go up to 3500 rpm, then it will just shake. the motor will keep going, but that tach won't. i installed and then re-installed it just to make sure i did it right and i did. anyone ever have this problem. i also hooked all the wires up right to.
Car: '88 GTA
Engine: L-98
no problems when i installed mine, its pretty straight foward, dont know how someone could mess it up, it has to be something else besides the coil
Follow that wire for the tach back. Sometimes if you bend the end wire at the terminal you will get intermittent readings. I mean as long as the car is running properly over that RPM I dont see how it could be the coil.
92camaroJoe
Aug 13, 2015 06:07 AM
