Need help selecting wiper blades/inserts.
Car: 92 Z28
Engine: 357 TPI (L98)
I've had a lot of bad luck choosing wiper blade inserts. I always get the ones that are supposed to fit but half of them didnt and the rest sucked. I'm assuming that we all have the same wiper setup for all thirdgens, so what do you guys use? I'd like to replace the blade and the inserts, so which brand/part number should I get? Thanks guys.
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
http://www.supersportperformance.com/ultrasilblade.htm
i use these. guaranteed for 5 years.
Car: 05' GTO
Engine: 6.0L
Transmission: A4
ive had the bosch blades on my car for almost over 1yr and there holding up like they are new. Dont bother with the refill blades just buy the whole new whiper blade and be happy and plus it takes like 2 mins to change the blades instead of woundering if you got the right refills or not.
1Aauto
Sponsored Vendors
Sep 23, 2015 01:09 PM
