Aftermarket Product Review Provide questions and answers about aftermarket parts for the Third Generation F-Body.
MSD coil
Old Sep 2, 2001 | 11:24 AM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
MSD coil
I have an 87 IROC with 350 A4. is the MSD Blaster Coil the best one out there? I need the one with dual connectors. After getting MSD 6A, MSD wires, new spark plugs, new coil, cap and rotor, what else should I get? Thanks.
Old Sep 2, 2001 | 01:04 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I believe the best coil available is Jacobs' Ultra Coil. It produces more secondary voltage (65,000) than any coil I know of and has a variable magnetic core (U.S. Patent). Also, it is compatible with the 6A box. This is the setup I use.
To top it off, it has a lifetime warranty. Can't beat it, in my opinion.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Former Paxton (6-psig) with 50-hp nitrous: 12.043 @ 112.86 mph.
ATI D1SC (10-psig): 12.056 @ 116.62 mph.
All stats are altitude corrected for 3,100 feet using NHRA's Altitude Correction Table.
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
Old Sep 2, 2001 | 02:00 PM
Where can I get that and about how much does it cost?
Old Sep 2, 2001 | 02:41 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
after getting msd, performance plugs, 8mm+ wires, and a high output coil how much horsepower gain is seen? i have heard it is just more throttle response, but i have also read that gapping your spark plugs adds horsepower? thanks
Old Sep 4, 2001 | 02:57 PM
SillyWabbit's Avatar
Car: '91 Formula
Theoretically, adding ignition components such as the MSD stuff isn't supposed to add any horsepower, but rather ensure complete combustion of the air/fuel mixture, improving driveability, mileage, and throttle response. But if the high performance equipment is combusting more air/fuel than the stock setup, wouldn't that cause an increase in horsepower? That's my line of thinking.
As for gapping the plugs to get horsepower, I've never really heard anything about that. From what I know though, if the spark plugs have too wide of a gap, then it will take so much initial energy in the spark to bridge that gap there won't be enough spark energy left to complete the burn in the cylinder, leading to unburned fuel, loss of power, driveability, and mileage. So if you have a voltage of 60,000 traveling to the spark plugs, and the gap is perfect, then it'll take "X" amount of that 60,000 to bridge the gap, and the rest of the voltage will be used to complete the burn. So if the gap is too large, there won't be enough voltage left to get complete combustion.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
meeklay812
Oct 1, 2015 03:46 PM
