HID Headlights?
Car: 1989 Bright Red GTA
Engine: Grand Sport LT4
Axle/Gears: 10 bolt 3.73
HID Headlights?
Anyone know where to get HID conversions for the sealed beams on a GTA?? I have found ALOT of companies that sell the conversion for halogen bulb cars, but not for the sealed beam. I know that they are very expensive, but I would like to have them. If none knows, I will post it if I do find a company that does do the conversion.
I have seen the kits on ebay, around $40 I believe for each set of sealed beam HIDs.
'86 IROC 5-speed
305 LG4
edelbrock performer rpm intake
edelbrock 600 cfm carb
msd pro billet hei distributer
'95 3.23 rearend
hotchkis rear suspension
PST front polygraphite suspension
"speed kills. buy a f@&d, live forever."
'86 IROC 5-speed
305 LG4
'95 3.23 rearend
There's a lot of bulb's and lamps sold on eBay that are advertised as "HID" that only use a standard type of bulb or lamp that shines a bit brighter. These, of course are not real HID(one sure tip-off is if the bulb isn't replaceable, i.e.,... sealed beam).
Sylvania makes an upgrade to HID for 3rdgen Camaro's and Firebird's. They are quite pricey($800+). You might want to get a replaceable bulb halogen type lamp, and use a xenon-charged bulb to get brighter output without killing the budget.
p.s. The above links will get you to the replacement bulb page. Look for the "Xenarc" icon to get the correct HID upgrade kit for your car.
[This message has been edited by 88IROCs (edited October 03, 2001).]
Thanks for the link. You're right on in your assumption about the bulbs on E-bay being just replacement bulbs and there are alot of colored bulbs also. The latter blbs are actually DIMMER than the traditional sealed beam halogen that came factory in third-gens.
